Question about Panasonic PT-52LCX65 44" HDTV
Pt-52lcx66 not very bright set on highest bright setting and in vivid mode
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 157 Answers
It is most likely your lamp. The lamps have around a 3-5 year lifespan depending on how often you watch the TV. You can check for this yourself by opening the lamp door and removing the lamp to check for a cloud around the bulb or stem of the lamp. There are step by step directions for lamp replacement in your user's manual. They made it so it is consumer accessible and should not take more than 15 minutes to replace.
If you see any imperfections on the lamp then the lamp should be replaced to get a picture as bright as the day you bought it.
Posted on Nov 13, 2009
Testimonial: "thats what i thought thank you"
Dark picture
Please check your TV's Picture mode setting. Use the VIVID picture mode to achieve the brightness video.
Mar 11, 2014 | Panasonic PT-50LC14 50" Rear Projection...
Tip
Panasonic PT-52LCX66 Manual Models No. PT-52LCX66 / PT-56LCX66 / PT-61LCX66...
Models No. PT-52LCX16 / PT-56LCX16 / PT-61LCX16
Have you lost the Operating Instructions for your Panasonic PT-52LCX66 Projection HDTV?
Click here to download a digital, searchable copy of your users manual / owners guide.
I hope that helps.
on Apr 11, 2010 | Panasonic PT-52LCX66 Projection Television
PS3 wont display using HDMI ports and Input connection on PT-52LCX66
It would seem either a setting at the ps3 or the set is not right.
Good idea to check all inputs and setup again--if something like a DVD works on rear input issue is with the PS3.
Mar 14, 2012 | Panasonic PT-52LCX66 Projection Television
My sony 42 inch seem to be dark always i have the bright at 85% and it still dark
It can be corrected by some adjustments at the video set up found at the settings menu. Just by pressing menu button on your remote commander, then go to settings then select video set up and press enter then select vivid or normal by pressing the enter button. this will automatically set your unit to vivid or normal mode.
Oct 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
My Samsung DLP HD tv's picture is starting to go dim. What can I do to make the picture bright like it used to be. Model Code - HLS6187WX Thank you for any help you can provide. Spencer
Has the lamp ever been replaced? As lamps age they get darker screens. First though check to make sure the TV settings aren't accidentally on a dark setting. Go into the menu and see if increasing the brightness helps.Different picture modes like movie, games, vivid have different brightness settings vivid usually the brightest.
Sep 11, 2010 | Samsung Televison & Video
Where is located the air filter component in the 52lcx66 tv set.
There are 2 filters located on the light engine assembly. One sits above the lens in a black plastic case. The other faces down directly under the lens. This is not consumer serviceable, and the ones I have run into that shut the set down have needed the optical block replaced. Goodluck.
Jun 27, 2010 | Panasonic PT-52LCX66 Projection Television
Best tv settings for samsung LE40A457
Best is kind of subjective since each person's eyes are different. If you are looking for a bright and vivid picture, you can go to the picture mode and change it to that setting. Usually it is called something like "Vivid" or "Dynamic." Besides that, it is all user preference. Most people prefer to just use the factory default settings.
Nov 09, 2009 | Samsung LE40M91B 40 in. LCD TV
Where do i get the replacement lamp for my 52" pt-52lcx66
I am not sure, but I think this set uses the "TYLA1001" lamp-- the little one, and it IS not too easy, or cheap to get. But it IS available on line, from a number of sources, about 225 or so.
Oct 10, 2009 | Panasonic PT-52LCX66 Projection Television
Polaroid FLM-3732 Can not change picture settings
select picture mode.press right arrow button to change your picture mode {vivid,sport,hi bright]to change sitting you much choose user mode.the other settings are factor settings.
Dec 31, 2008 | Polaroid FLM-3732 Television
Screen Brightness
What lamp did you replace it with? Some of the aftermarket bulb sources are not the original brand and do not work as well.
Dec 31, 2007 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic PT-52LCX65 44" HDTV Logo
140 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
