Question about Optoma Office Equipment & Supplies
We have an Optima EP 719 projector. The bulb would not light after I plugged it in and pushed the on switch. The power switch illuminated and the fan came on for about 30 seconds. Then, the lamp indicator flashed red, the fan shut off and the projector went back to standby mode. I replaced the lamp unit and still have the same problem.
  • 2,237 Answers
If you hear a high-pitched whir, you have a ballast problem. if you don't hear it, you have a colorwheel problem.
Posted on Nov 16, 2009
Lamp comes on briefly and then goes out
Check poewer connection
Check if fan filder is dirty ( if it is just hoover it out)
If "lamp" light on top of the projector blinks or stays lit - lamp probably faulty
How old is the Projector/lamp (average lamp life is around 2000-3000 hours)
Mar 01, 2011 | Optoma EP719 DLP Projector
We have an Optima projector. The bulb would not light after I plugged it in and pushed the on switch. The power switch illuminates then I hear a "kudukudukudu" sound like its trying to get...
possibly the bulb is blown this is very expensive to fix most of the time.... maybe water damage but since it all turns on and apears to work then this is less likely then bulb blown..... if the bulb is definatly not blown you could take it apart and put a hair dryer on it from a distance... do not heat the boards up much just enough to get rid of any moisture.... best of luck and i hope you can get it going in time....
Feb 28, 2011 | Optoma Office Equipment & Supplies
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
Power on, no light...worked in the test run
can you enter the setting and check bulb life timer and if you can reset it?
please feeb back
Apr 18, 2010 | Optoma EZPro 719 DLP Projector
I have an optima EP 739 projector and I just replaced a bulb in it but it does not come on just green light whats up Any input would be appreciated
if the fans come on and the lamp doesn't, it's the ballast or the colorwheel. if no fans either, it's the power supply. also, did you reset the lamp timer?
Dec 07, 2009 | Optoma H30 Multimedia Projector
High temp light on when powering up
Remove the screws and check out the fan's working state.
EP759 have one big 92mm fan for the lamp, and three small, near 40mm, fan's for the optics.
Power of the bulb is very high, so just 1 broken fan can make that situation.
Apr 25, 2009 | Optoma EP759 - HDTV Compatible DLP...
Help needed for Optoma EP 719 DLP PROJECTOR
It's a setting in the menu. A few minutes poking around will fix it.
Jun 12, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optoma EP 738
You can test the power source if you are getting any power input from the power cord itself. Plug in your power cord and use an eletronic meter on the other end to see if you are getting the proper voltage (110/120) reading. If not, then the power cable is bad in itself. IF you are getting power from your cord, it could also be a fuse inside the Optoma and/or where the power plug on the Optoma meets the actual power source is out of alignment or may also be not making the proper contact to the main circuit board on the Optoma. Hope it helps....JGUAM
Jan 28, 2008 | Optoma EP716 Multimedia Projector
432 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
