Question about HP PSC 950 All-In-One InkJet Printer
Hp psc 950
I can copy photo,s using photo paper but when i try to print from my computer
using the same paper it only prints a strip about 10mm wide i have tried various settings but no luck
  • 4 Answers
Reinstall the driver. There is a possibility that the divice driver is corrupt.
Posted on Jan 08, 2008
How do I print postcards on HP PSC 950
Here is your solution to print postcards size.. 1. Select your image and press mouse right . 2. Select print and select your printer. 3. There may be many sizes indicate there... but you must select 4x6 or 5x7 as it is postcard size. 4. Now select your paper quality (eg. Photo paper plus glossy ) 5. Press print.... That is it .... good luck
Sep 08, 2011 | HP PSC 950 All-In-One InkJet Printer
Have no manual; need help using scanner and fax
Here is the link given to the user manual. that contains the optimum solution to your problem and maximum guidance.
May 27, 2009 | HP PSC 950 All-In-One InkJet Printer
My HP PSC 950 prints anything from the Inernet too
Browser printing option is set to print small you need to check that and make sure you using landscape.. There should be no other reason why so check those landscaping options- thanks and please rate acordenly anything above a thanks for trying would be pleasureable..
May 15, 2009 | HP PSC 950 All-In-One InkJet Printer
HP PSC 2355 won't feed photo paper
You can't use the photo papers in this kind of printers
Aug 01, 2008 | HP PSC 2355 All-In-One InkJet Printer
My HP PSC 950 printer copies and scans in color but prints in black
normally when the color tank runs out 2 things happen.
1] not all the colors run out at the same time.
2] the printer complains the tank needs to ne replaced.
If the tank isn't dry, it could simply be clogged. I like to use rubbing alcohol or distilled water and a cotton swab.
Dip the swab, & then gently apply pressure in the nozzles.
I would expect to see the clog before the cleaning process, some color to come off & when pressed on a paper towel, hopefully 3 bands.
Jul 05, 2008 | HP PSC 950 All-In-One InkJet Printer
Hp psc 950ink cartridge alignment
In my experience, the <align cartridge> happens when you change ink, has a [don't do {HP chat would be a help}] and wouldn't let you print or scan either unless completed.
normally prints a [2] sheet, then asks to scan it.
for photo quality, override isn't reccommended.
does copy work at all?
scan, save, print might work
Jun 09, 2008 | HP PSC 950 All-In-One InkJet Printer
HP PSC 950 problem
Look in the printer software on the computer for paper size settings. If that doesn't help go into the settings menu on the printer it self. If you have HP Setup Assistant on your computer, use that to reset up your printer to your computer.
May 30, 2008 | HP PSC 950 All-In-One InkJet Printer
try to check the paper size from the printer and be sure that the paper with the same size...
the check out if the printer pick up the paper correctly
Feb 17, 2008 | HP PSC 950 All-In-One InkJet Printer
PHOTO paper
The HP printer was prepared to use HP's photo paper to print borderless pictures among other things.
If you use a third party photo paper, try using A4 size, position the picture in the paper using MS Word or another WYSIWYG program and, after printing, cut the picture in the right size.
Dec 31, 2007 | HP PSC 950 All-In-One InkJet Printer
HP PSC 950 All-In-One InkJet Printer Logo
54 people viewed this question
Ben Johnson
