Question about Homelite Consumer Products Backpack Blower/Vac, Carb
My Homelite backpack leaf blower runs until tank is 1/2 full
My Homelite backpack leaf blower runs like a charm until it is 1/2 to 1/3 full of gas and then it dies. I need to take it off my back and hold it at an angle to keep it running. I would think it's the fuel line in the tank but don't know how to go about attacking the problem
  • 486 Answers
I believe you to be correct in your diagnosis.
1) remove the fuel tank
*this will give you an idea of how lines are routed and fitted into tank
2) install a new hose through to tank fitting and make sure to retrieve the old hose & filter inside the tank, so that you can attach the filter to the new hose. The filter is weighted so that it falls to the lowest point to pick up fuel.
Posted on Nov 13, 2009
  • 475 Answers
Thats what it is try opening the gas lid look inside to see where the fuel line lies if its up high them try pushing it down to the bottom
Testimonial: "I appreciate the quick response and verification of the problem. When the wind dies down here (CT) I'll give it a try. Thank you."
Put a new carb on my stihl 400 backpack also a new fuel filter and air filter starts great and runs at full speed and then the rpms drop can bring back to full speed but will drop again no fun blowing
Lucy, the problem is that you have a blocked tank vent/ gas cap. Try just loosening the gas cap,just a crack not even one turn. You are bypassing the tank vent. Now start it and see if it runs longer with out boggind down.If this fixes it, you will need a new gas cap.
Let me know
Matt
Nov 05, 2011 | Homelite Consumer Products Backpack...
I need a gastank for my homelite-backpack leafblower, model#uto8580a.It leakes around the screw that holds it own. This is the second time i've had to replace it. There must be a defect in these.
There is a recall for leaking fuel tanks on your unit.
The Homelite #UT08580/UT08580A Backpack blower service recall and all related questions and issues, are being handled through the Homelite customer service phone staff at 1-800-242-4672, for records purposes.
Aug 22, 2011 | Homelite Consumer Products Backpack...
I have a Homelite BackPacker leaf blower. It runs fine until the gas tank is about half empty. Then it sputters. While it's running, I can remove gas cap and replace and it runs fine again for a little...
Great job with the description of the symptoms. What you are describing is a classic case of vapor-lock. In other words, a vacuum is forming in the fuel tank and not allowing the fuel to flow to the carburetor.
Look at the cap, it probably has a small vent built into it. With a little compressed air, blowing from the outside in, try to clear the obstruction. This may not work, but don't worry. Just replace the fuel cap. Your local lawnmower repair shop can probably get a new cap for you. Otherwise, go to www.homelite.com click on the parts tab, enter your model number (starts with a "UT") and order a new one.
Oct 29, 2010 | Homelite Consumer Products Backpack...
Bogs down at full thouldel tryed to adjust carberator
Hi
This is either a clogged muffler or carb. Take the off and see if it will rev. If not you need to clean carb and install a carb repair kit. Do not run long with muffler off.
Sam
Jan 06, 2010 | Homelite Consumer Products Backpack...
How do I adjust needle valves on a 25cc Homelite UT08111A Backpack leaf blower?
Set the lowend & highend needles to about 1 3/4 to 2 turns each. Choke the carb or prime it, until the carb is wet. Fire up the engine and let it warm up. Let's set the topend first since it's the easier of the two. Go to full throttle. Adjust the topend needle for peak RPM. Leave it wide open for about a minute to see if it changes any. Should the engine go lean, open the lowend needle slightly, if this dosen't work... you will have to adjust the needle valve inside the carb.( I will explain this later) If the topend runs OK, then slowly pull the throttle down until the engine begins to "four cycle" hold the throttle there. Adjust the lowend needle until the "four cycling" barely stops. Now lower the throttle more until it "four cycles" again, and adjust the lowend again. Keep doing this until you reach full idle. Now, from full idle begin to throttle up until the engine starts to bog or hesitate. Open up the lowend needle just enough to eliminate the bog or hesitation.
http://tech.flygsw.org/walbro_tuneup.htm
hope this helps :)
if it does please vote
Oct 23, 2009 | Homelite Consumer Products Backpack...
Homelite backpacker blower # uto08083 not running
fist thing is run both the carb screws all the way in then back them off 1 1/4 turn this will be your starting point then start the blower to fine tune the carb if it starts then your carb was off giving it to much or to less fuel
Dec 20, 2008 | Homelite Consumer Products MightyLite...
Blower runs fine for 30 or 45 mins, then will not come up to speed.
there is a fuel filter in the fuel tank that some times gets cloged try that and fresh gas -oil mix
Nov 01, 2008 | Homelite Consumer Products Backpack...
Homelite Consumer Products Backpack Blower/Vac, Carb Logo
508 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
