Question about Panasonic KX-FL501 Plain Paper Laser Fax
Program fax phone number
How to program fax phone number
We have Panasonic TES 824. We connected 3-direct lines, one of them is for fax. However if I call the fax number, it goes to auto attendant. How to disconnect the fax number from auto attendant? Awaiting...
By programming. If the Auto Attendant is the DISA card, you can tell it to listen for the FAX tone and transfer it to the fax extension, or, you can program the 3rd number to ring only the fax extension and no others. Both require programming in the system cabinet.
Carl
Jan 18, 2011 | Panasonic KX-TA824PK Phone
Phone is plugged in to a fax machine and the phone rings too many times before answering machine picks up so the fax machine takes over. How can I reduce the number of rings so that the answering machine...
Change the answer machine rings to answer number to less than the fax number of rings to answer or increase the number of rings to answer on the fax machine. Would need exact model number of phone system to give more detail on programming steps. Info should be in manuals of phone system and fax machine.
Dec 07, 2010 | AT&T DECT 6.0 Cordless Phone System with...
Fax phone number
check the Cannon website for manuals on your model
Jul 09, 2009 | Canon FAXPHONE L80 Laser
I want to send a fax message using Brother 2820 fax machine, but I don't want the receiver to see my phone number when he receives the fax message print out. Is there any way I can do this?
The FAX machine will print the Tel number that has been programmed in your machine. It does not print on the basis of the caller ID received. So i think if you remove the number programmed in your fax machine
May 23, 2009 | Brother IntelliFax-2820 Laser Fax
Phone # on outgoing faxes
"user tools"
"fax features" ok
"general settings" ok
"program fax info" ok
"own fax number" ok
enter number..press "ok"
Please rate solution. thanks :)
Apr 23, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
How do i enter the distinctive ring sound for the fax?
click on menu/setup button
then advanced fax setup-ok
answer ring pattern-ok
chose from single, double, double and triple, none-ok
Feb 06, 2009 | Samsung SCX 4521F All-In-One Laser Printer
I need to send a mass fax once a week
you need to program the numbers you want to fax in the speed dials and abbr numbers, then you can use a program key to select them all.
function-7-2-start [this is where you program your numbers]
function-7-3-start-1-start- then push your p key enter a name then hit start then select your phone numbers
Nov 17, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Vodavi Telephone System Programming
The best way is to remove the phone line from the phone system and make it go direct to the fax. In the closet with the phone equipment. Find the fax telephone jack. Follow where the wires go(it will goto the phone system 25pr cable). Take the pair of wires off. Find the fax number that comes in from ATT. That is the location where you need to punch down the wires that come from the fax telephone jack. To test goto the fax machine pickup the phone on the side of the fax and call your cell phone to see what the caller ID is. God Bless. Jerry
May 01, 2008 | Vodavi IP7024LD Corded Phone
Panasonic KX-FL501 Plain Paper Laser Fax Logo
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
