Question about iLO MP3 Player
Memorex MMP3642A - SigmaTel format
Inserting a 1 gig SD card gives an error message that it must be formatted using SigmaTel Formatter. I cannot find such software and have tried what Memorex suggests to no avail. Any help will be appreciated.
  • 5 more comments
  • Anonymous Jan 19, 2008
    same problem as above i put a 2 gb memory card in and it gave the same error message sigma tel format how can i correct this
  • Ms_Williams Mar 01, 2008
    I have a Memorex MP3 (MMP3642) I keep getting this ERROR message. Reformat with SigmaTel formatter. HELP!!!!!
  • fairymajik03 Aug 15, 2008
    I have this same prob...where can I get the software if I cannot find the cd that came with the mp3 player??
  • Anonymous Oct 12, 2008
    says error
  • liz_rose Dec 21, 2008
    i tried to put pictures on to my MP4 and when i disconnected it from the computer and turned it on it flash the error reformt with Sigma Tel formatter message... so i need help
  • Anonymous Feb 26, 2009
    IT TELL ME TO REFORMAT INTERNAL MEDIA
  • Anonymous May 18, 2009
    Error page on front screen and fast forwards most of songs.
A few suggestions:
1] I’ve tried using a 1GB sd card in the MMP3642A with no success. Interestingly, I can transfer files to the 1GB card when it is in the MMP3642A, but when I turn on the player to listen to the files, I get the sigmatel formatter error message. I tried running the sigmatel formatter, but it doesn’t understand the 1GB size. Apparently whoever programmed this braindead formatter program only programmed it for up to 512MB sd cards. Interestingly, I tried flashing this player with the MMP8500 firmware, and then the player does play files off of the 1GB sd card, but the LCD is mostly cutoff and only 25% of the LCD shows up. So it seems the only obstacle to using a 1GB sd card is this stupid formatter program. I tried formatting the sdcard to fat16 instead of Fat32, but that did not help
2] If you want to use a card with more than 64MB, you need to use the CD that was with the player. DO NOT USE AUTORUN! Explore the disc, go into the "products" folder, run the stusbmscformat.exe application. It will show a the drive letter for the player, click the arrow and select the next drive letter down, then press start. This worked for me, I hope it will be useful. Why memorex doesn’t address this issue is beyond me.
3] How do I correct the error: Reformat external media with sigmatel formatter? If you have installed the software disc that you received with your MP3 player, you will need to follow these instructions; -- From your computer, click 'START' -- then 'PROGRAMS' -- then 'MEMOREX' -- then 'FORMAT' -- choose the 2nd drive If this doesn't correct your error, you will need to return the memory card to the retailer for an exchange. connect your memorex mp3 player , then turn it on and click start .....i did the same and its working now.
Posted on Feb 24, 2008
6ya staff
SOURCE:
Camera goes through format routine,but card but
The 4500 uses SD cards. Your 8GB card is actually an SDHC card. While it fits into the slot, it is not electronically compatible with the camera. You'll have to restrict yourself to SD cards 2GB and smaller.
Jun 28, 2010 | Nikon Coolpix 4500 Digital Camera
I have replaced the battery and memory card, the camera keeps saying I need to format the card, but then it says it is formatting, then gives another message saying the card needs to be formatted....
If the memory card replacement is an SDHC model card the Kodak z740 will not work with it. The memory card has to be a standard SD card of 2 gig size or less to properly function. Take card out and turn on camera. See if you get same error. You should get missing card error but otherwise be able to operate camera controls such as zoom, flash, etc. If that is fine find old card you used and place back in camera... or purchase a standard SD card from Walmart for 10 dollars
Jun 11, 2010 | Kodak EasyShare Z740 Digital Camera
SDHC Card 4 GB SanDisk will not format. get
The Z740 uses SD cards, not SDHC cards. SDHC cards will physically fit into the card slot but are not compatible. It's a hardware incompatibility, not updatable in firmware. You'll have to stay with 2GB and smaller SD cards.
Feb 06, 2010 | Kodak EasyShare Z740 Digital Camera
My memory card for my phone says it has an unrecognized format
have you tried formatting it in your phone and in the computer
Jan 14, 2010 | SanDisk 4GB microSDHC Memory Card
SD card - memeory card parameter error
Some camera's, especially older ones, have a limit as to the maximum size of the memory card that they support. Look in the manual to see what the camera can support.
Jun 12, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
SD Card (2GB YES Make) Gives Formatting error
If you have a card reader or a printer with an SD card slot in it, try formatting the card or deleting all files on it using a PC. My laptop has a slot built-in I'm able to use. Check out your options. Try formatting it outside of your camera. I've heard of some card swapping between brands of cameras doing crazy stuff as you are experiencing.
Jan 07, 2009 | Kodak EasyShare C315 Digital Camera
Memory card for motorola krzr k1
try formatting & inserting it again.......
it may solve ur prob
Dec 29, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Camera does not recognise 1Gig SD Memory Card
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Dec 03, 2006 | Rollei Prego DP5300 Digital Camera
    1,724 people viewed this question
    Top iLO Audio Players & Recorders Experts
    Ekse
    Siul Oyaratgam
    Inky Fingers
    Inky Fingers
    Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
