Question about Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum
F6215-900 inner hose replacement
How easy is it to replace the inner hose (90001080) on the 6215-900? Anyone done it before?
    Problem Solver:
  • 7 Answers
It is not easy to replace at all. Especially if you have little previous mechanical knowledge. The best thing to do is to take to a service center to have the install it.
I have done about ten or twelve. None of which have been a fun experience.
Posted on Jan 09, 2008
6ya staff
SOURCE:
How to replace filler tube on Kirby G4 vacuum?
first take cloth bag off, held on at bottom with bag clamp, then wash cloth bag in washing machine at 40, inner hose is held on by 2 cable ties top and bottom, your new hose should come with 2 new cable ties, ask kirby agent when ordering, them simply refit.
Aug 25, 2014 | Kirby G4 Bagged Upright Vacuum
Split suction hose
try e spares on the internet they have most parts
and to replace is very easy
Mar 20, 2014 | Miele S7260 Bagged Upright Vacuum
Polti spare parts
i have a 950 and it does not heat up any more . the red light comes on but thats it
Feb 13, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
Brushes will not spin -- broken part
Did deeper, I finally just fixed mine today, I thought the same thing about it not wanting to come apart, but try one more time, and when your almost done, look underneath there is a long plastic piece with two screws almost side by side towards the front, take them out, remove the two rubber hoses on the top side and remove the turbine, opens real easy and clean it out, then wala it' work again...
Oct 16, 2008 | Hoover F7222-900 SteamVac Upright Vacuum
McCulloch MC1275
I had the same problem today. It turns out part of the steam hose was kinked. If you feel along the black tubing - this covers the actual steam hose, you may feel a hard spot where the inner hose may have kinked. Mine was near the end so I cut into it, cut out the kinked part, and reattached the hose to the endpiece - where it screws onto the body. If you do have a kink you will at least have to cut through the black tubing - careful not to cut the inner hose; you will see the nylon wrapped hose inside and can try to fix it. I was unable to unkink it without cutting it, you may have better luck, or you can do what I did. If you decide to, once you take apart the endpiece you'll see how it all goes together, pretty easy to figure out. Alternatively you might be able to buy a new hose through http://www.topinnovations.com
Hope this solves your problem, if you haven't already. Good luck.
Jul 22, 2008 | McCulloch MC1275 Steam Vacuum
Genie Wet/Dry Vacuum replacement part
Hi, you can find genie replacement parts on amazon, click here and take a look: WORKSHOP Vacs Suck It Up Get It Done. I hope this was helpful. Cheers
Feb 17, 2008 | Genie Company GV150 Wet/Dry Vacuum
Hoover Agility, No Suction!!!
I had the same problem. Lower the handle to the floor and check the black spiral suction hose at the neck of the machine. The lower hose in my Hoover split. Check and see if yours has done the same thing. If so, the lower suction hose will have to be replaced. Hope this helps.
Oct 04, 2007 | Hoover F6212-900 / F6215-900 SteamVac...
Hose breakage
The same thing happened to me last week. The inner hose does not have enough "extra" play so if you bend the handle down too low to reach under a dresser or bed the lower inner plastic hose snaps. I brought mine in to be repaired since it's under warranty. I did a long exhaustive search and came across this website1.gif https://www.mdappliance.com that has Hoover Agility replacement hoses and their prices are the best I have found so far. The smaller inner hose (part number 90001080) is only $9.99 (compared to $13.99 & $19.99) and the external hose attachment (part number 91001004) is only $25.99 (compared to $39.95). I specifically asked and the parts are brand new... not refurbished or used. Their phone1.gif number is 866-914-1252. Just in case you're wondering, I'm not a rep for the company nor do I have any affiliation with them. I just placed an order for the hose attacment and came across this webpage1.gif and figured I'd add my 2 cents. Hope this info is helpful. I tried to make it as complete as possible.
Goiod luck.
PS: They also offer a flat rate shipping fee of $7.95 regardless of what you order. No sales tax unles you're in Ohio. :)
Sep 21, 2007 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum Logo
154 people viewed this question
Top Hoover Vacuums Experts
Kirk Thompson
Level 1 Expert
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
