Question about Canon PIXMA MP210 Photo All-In-One Printer
Ive replaced the ink in my Pixma MP170 using a kit, but noe it does not print also the status of the quantity of ink shown on screen sats its empty, is there a reset button or function i need to activate?
    President:
  • 2,306 Answers
You need to reset the chip that is on the front of the cartridge, that chip says it's empty. You can get the chips and a resetter from the same place you find the refill ink.
Posted on Nov 13, 2009
Pixma 2200 series all in one
Don't use refill kits, they are no good in quality printers. Also the cartridges in the newer models have a chip in them that knows when the cartridge is empty. When it becomes empty, the chip has to be reset, and this is what those mall cartridge fillers do.
E, 1, 3 The ink may have run out. The function for detecting the remaining ink level will be disabled since the ink level cannot be correctly detected. If you want to continue printing without this function, press the machine's Stop (Reset) button for at least 5 seconds. Canon recommends to use new genuine Canon cartridges in order to obtain optimum qualities. Please be advised that Canon shall not be liable for any malfunction or trouble caused by continuation of printing under the ink out condition. Checking the Ink Status Checking the Ink Status with the Ink Lamps on the Operation Panel The ink level detector is mounted on the machine to detect the remaining ink level. The machine considers as ink is full when a new FINE cartridge is installed, and then starts to detect a remaining ink level. If you install a used FINE cartridge, the indicated ink level of it may not be correct. In such case, refer to the ink level information only as a guide. When remaining ink cautions or errors occur, the error code will be displayed on the LED (Light Emitting Diode) to inform you of the error. Check the error code and take appropriate action. -> [ An Error Code Is Displayed on the LED ] See[Checking the Ink Status ]
Oct 27, 2015 | Canon PIXMA Office Equipment & Supplies
Pixma mg3150 ink there but showing as empty
When using replacement or refill, Canon software will not detect them as new or filled with ink. Original cartridges have chips programmed with "counters" which determines how many times it could print. As long as it is printing, it is not really a problem just press the resume button.
Apr 25, 2014 | Canon PIXMA MP150 All-In-One InkJet...
I don't need to use a color cartridge in my printer..pixma mp170....how can I print with just a black cartridge?
You can't. The printer will not work unless all carts are installed and have some ink in them.
Sep 18, 2011 | Canon PIXMA MP170 All-In-One InkJet...
I am getting an on screen message
The waste ink absorber covers the whole bottom of the machine, under the printer. It is difficult to change, and you have to get into the diagnostic mode to reset the error. A shop repair...
Jul 09, 2009 | Canon PIXMA MP170 All-In-One InkJet...
The waste ink collector is full how do I empty it?
The absorber is under the print assembly, it is a pad and can't be emptied. It is a shop repair since you have to use Canon diagnostics to reset the count and clear the error.
Jul 01, 2009 | Canon PIXMA MP170 All-In-One InkJet...
How do I find waste ink collector
there no any waste ink collector, this printer have only a pad for waste ink, (you don't need to replace first time indication) only take the printer to service center to reset this indication.
or
for immidiate printing -
just switch off printer from main (power) swtich then push and hold the on key and paper key then switch on from power. (it's work some time in some pixma)
Jun 27, 2009 | Canon PIXMA MP170 All-In-One InkJet...
How do you find the waste ink collector on a printer/scanner ?
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
The waste ink absorption pads are inside the printer, in the very bottom. They are usually soaked with ink when full and are very messy.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you.
May 18, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Canon pixma mp110
Dear team2,
Code 5200 indicates 'Ink cartridge temperature rise' error occurs. This error commonly happens when cleaning operation is performed. First, please check if there is enough ink in ink tanks. Cleaning with empty ink tank may cause this problem. If you are sure that you have enough ink in ink tanks means that the print head of the printer is faulty and need replacement.
Hope this will be useful for you. Please rate me as Fixya.
Regards
Dec 02, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Ink problems col vol unknown and wont print
Something that worked for me, I opened the Conon MX310. took out both cartridges, and for 10 seconds I held the Reset. put the cartridges back in, closed the lid, and again, for another 10 seconds held the reset. SLOW seconds. this reset, ink levels recognised,, and it's working as it should be.
Regards
Shane (AKA Reef_Lex)
Jul 27, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Canon PIXMA MP210 Photo All-In-One Printer Logo
old marine
old marine
