Question about Acer Computers & Internet
Laptop wont turn on while connected through cable, tries using another acer cable but still nothing. please if someone has any ideas let me know. thanks!
    Problem Solver:
  • 18 Answers
Just check your laptop battery remove the battery once for 2 min
if this will not help try
step 2 check your Acer Laptop charger pin
roll the pin of your charger about 90 - 180 degree after attaching into
your laptop if it works then you have to contact your nearby service
center to alignment power jack of your laptop that attached to the
motherboard.
hope this can help you
if not
contact me with full details like
after attaching the power pin did you find any power light yes / no
did your charger show any light indicator yes / no
thanks
with regards
Dheeraj Singh Pundir
Posted on Nov 13, 2009
No display on hp 6345s laptop
Try to turn off your system. Then remove the cables and battery on the laptop. Then press and hold the power button for 8 secs. Then, reinsert the cables and battery on the laptop. Then, press the power button to turn on the laptop. If the HDD light flickers continuously, then the problem is on the Hard Drive. One way of resolving it is to Re-Seat the Hard Drive. If you know how to tear down the system, here's how. Turn off the laptop, remove the cables and battery at the back. Remove the screws located at the corners of it. Then remove and reinsert back the Hard Drive. If it still fails, contact ACER to immediately replace the Hard Drive. If you don't know how to tear down the laptop, then call ACER also for repair....
Jul 19, 2010 | Acer Aspire 9300 Notebook
Acer aspire 3610 power lead transformer green light is on before plugging into laptop then goes out when plugged in.acer has nothing working, totaly dead any ideas?
If the power LED is lit before connecting to your laptop and then goes out as soon as you connect to your laptop, then you either have a short circuit in the power supply module of your laptop, or you battery is causing the fault.
Remove the battery and try again. If it powers up the battery needs replacing. If the problem is still the same then you need someone to look at the power supply module in the laptop
Mar 09, 2010 | Acer Aspire 3610 Notebook
Wont start
Hi there, please explain what's you face. Also you can follow the steps.
1. plug on the the power cable. Is there green light are on in adepter? Is not then your power cable damaged.
2. if you r battery fully charged then turn on your laptop with out connecting power cable. If your laptop booting then system is perfect.
3. Try to plug on by a different Acer laptop users power cable. and see what's going. I need these information for further instruction. You just say "wont start" i don't want to give you any blind suggestion. so please let me know more about it.
Thanks.
Feb 11, 2010 | Acer Aspire One Netbook 8.9" Notebook
HP Printer Usb port in my Acer Laptop , shortcircuits my house
hello
Try using external USB HUB (POWERED) Adapter. It might fix this issue.
Use an other USB cable and see.
If the problem still exist do not plug in the printer again, you may damage your USB port or even burn your laptop motherboard.
hope this helped
TekSpotDotCoDotUK
Aug 26, 2009 | Acer Aspire 6930-6941 Notebook
Power cables loses wireless connection on Acer Aspire 5100
please check your power configuration profile under control panel.
the device might be disabled when the power input is on.
If you are using, Acer's e-manager then you can confirm there as well if the device is disabled under Power on mode.
Hope this helps.
Thanks.
Mar 17, 2009 | Acer Aspire 5100 Notebook
My acer laptop wont start up!
sure lets do one thing disconnect the power cable and also remove the battery and than hold down the power button for 12 seconds and than put the battery back in and also connect the power cable and than start the system that should work
Feb 14, 2009 | Acer Aspire™ T180 PC Desktop
How to connect acer aspire mini laptop to digital lcd tv?
You get the audio from PC: you must use a separate audio cable to your TV audio input.
Configure your PC Display properties to a lower resolution until you reach a format your tv can display.
If you use a flat digital screen check the manual to know the resolution to be used with VGA input.
Use Dual screen option or swittch main screen/external/both using FN key + blue key showing screen on your keyboard. (F4 or F7? check manual.)
Jan 07, 2009 | Acer Aspire 5100 Notebook
Cant connect to a tv as a second monitor
you are connecting it with what ?............. through s video cable
also press fn key along with the key that has marked monitor,
Oct 16, 2008 | Acer Aspire 3680 Laptop
Acer aspire 4315
if u get tired of that laptop just let me know ill buy it
Jul 19, 2008 | Acer Aspire 3680 Laptop
I CANNOT OPEN!!!
Hi, Try running you laptop with the battery and the AC adapter. If by plugging in your adapter there is no light indicator likewise or no powering up, then presumably there is a problem with the power supply circuitry in the motherboard. Normally the laptop should work with just the adapter, just the battery or both the battery and the adapter. If it will not perhaps your best bet is to seek professional repair service since this would require opening the motherboard. In most instances, this involves an smc fusible link, regulator transistors or even just cold solder or loose connections. Hope this be of some help/idea. post back how things turned up or should you need further information. Good luck and kind regards.
Sep 24, 2007 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
51 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
