Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
Help I have a WD Passport external hard drive and my computer cannot detect it anymore. If I plug it into the computer, I can see the light on, so it means that it is running, but nothing actually happens. I really have to recover all the information that I put on this hard disk. Can you help? Thanks
  • ioanasmiley Jan 08, 2008
    I tried all the USB ports.... they work fine with any other device, except for this hard disk....
  • accessdata Jan 16, 2008
    This really sucks. I have 2 years of data backed up and I have just tried about everything and it still doesn't work. The WD light comes on; the WD makes a weird sound; my computer does not recognize it. I've tried using it on other computers...same thing. I have no idea what else to do.
  • 233 Answers
Wiggle the cable connected to the drive gently up and down and side to side
I have the same problem with one of my drives lights up but no detect, by doing the above it works. I think the connector inside "the contacts" don't make good contact with the cable while doing this hold the drive in your hand you will know when it makes good contact becuse you will feel the drive spining and then you'll see windows display the folders.
thanks for rating
Posted on Jan 10, 2008
  • 21 Answers
I'm assuming your drive is connecting through a USB port? Does another computer see the drive if you plug it in? You may have to remove and reinstall your USB drivers through the Device Manager screen. Windows will automatically put them back in when you reboot (you don't have to do anything). Sometimes this clears up USB issues like you are having.
Did you try all of your USB ports?
Posted on Jan 08, 2008
  • cbri Jan 08, 2008
    Does the hard disk get its power from the USB port? Sometimes for whatever reason if there is not enough power available in the system it won't be able to power the drive. The worst case scenario is to remove the drive from it's external case and put it on the inside of your computer as a slave (switching the jumper on the drive to slave and connecting to a second IDE connector).
My WD my passport not working
maybe the cable plug of the WD my passport is broken
Apr 18, 2013 | Western Digital My Passport Essential...
Not detected in xp
hi
go to WD site and get drivers for XP downlod and run that then try hopw fully it will work
May 25, 2010 | Western Digital My Passport Essential...
I have a 120GB Western Digital Passport external hard drive and it will not open up on my pc. the WD passport will turn ''on'' and light up and the pc will detect that a usb is plugged in but it will not...
Sounds like your passport is not working anymore. The fact that it wont work on another computer is a solid sign that something has failed in the device itself. Its possible that both of your comptuers have USB 1.1 but I would think this is unlikely.
I would plug it in to one of the comptuers, then go into your administrator tools then open your computer management tool(start>control panel> administrator tools> computer management). This will allow you to see if windows is detecting the drive at all. Sometimes if the file directory is corrupt, or the hard drive is even partially damaged, then it will not show up under "my computer" but it might show up under your computer management tool. If you see it on there, then there is probably something wrong with the hard drive that is not allowing the computer to recognize the device, or at least install it properly. If you dont have any crucial data, you can just simply reformat the drive and it might start to work after that. If you do, then you might have to take the thing apart and transfer the data by using the hard drive like it was just another drive on the computer.
If your computer does not detect the drive at all, not even on comptuer management, then I suspect the drive, or at least the adapter part of it is not working, in which case, you will need to remove the drive from the casing and use it as if it was another internal drive, you might be able to reformat it, then put it back in its casing, and hope that it works after that, but I have never taken a WD passport apart before, so I would recommend doing a google search to see if anyone else has done this before.
FYI, when I bought my WD passport, I bought a replacement plan with staples beucase I knew that with all the traveling I did, I would eventually break it. I have dropped it about 3-4 times only after about 4 months, the thing still works without any problems, but that just goes to show how well WD builds their drives, however, I am sure that if I wasn't so lucky, that I would be calling them up right now asking for a new one.
Jul 03, 2009 | Western Digital WD Passport 250GB Portable...
Cannot detect external drive
Try the device on a different computer. or plug the device to the computer. Right click my computer/ manager/ disk management (left panel) & see if the device is there. If not you have may be a driver issue or the device itself is not working. ( you can rectify if the unit is having a issue when you plug it on to another computer)
May 15, 2009 | Western Digital WD Passport 250GB Portable...
WD 250 GB external hard drive is not being detected by system
Hi !
First check if your WD is running (spinning), no matter if the blue light is on. Can you hear it close with your ear, or feel vibrations on your hand when it starts.
If it runs, then check/replace the USB cable you are using with another.
Check the Power supply if it gives necessary power.
If you are familliar with disassembling/assembling, then open and remove the HDD from the box and try to connect the disc directly to your PC (using another HDD Data/Power cables).
If it runs, and you can acces it, then something is wrong with the Box.
If it doesn't, then the HDD is broken or damaged.
Please note that if your device is under warranty, DO NOT open the box ! Contact your seller for service/replacement instructions.
Regards.
Mar 25, 2009 | Western Digital WD Passport 250GB Portable...
My computer does not detect WD 500GB external hard drive
It may need to be plugged into a powered USB hub to get it to work.
I've had the same problem on certain PCs and plugging it directly into a powered hub resolves that problem. I picked up a small powered hub just for that reason that I keep with my drives.
Feb 03, 2009 | Western Digital Passport WDXML800UE...
WD My Passport Essential 250GB USB2.0 is not working in WIn 98SE
Try using a Usb 2 cable "The one that came with the WD My Passport " And put it directly to the PC...
In some cases, Like mine, I used an extended cable + the cable that came with the "WD My Passport" and i got the same problem ..
So i simply removed the extended cable and put the put "WD My Passport " directly to the PC with its own cable and the problem was solved to me ..
Samer.F
Dec 26, 2008 | Western Digital WD Passport 250GB Portable...
Need help to locate Western Digital Passport 160GB External Drive
Could be a hard drive logic board issue since the computer bios recognizes the drive but the computer operating system does not. Not good.
Jun 25, 2017 | Western Digital Passport 160GB External...
HELP WD PASSPORT
اعادة الهارد لحالة المصنع
Jul 30, 2008 | Western Digital Caviar WD2500BB 250 GB...
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
I had a similar problem with my WD passport 320GB. When I connected it to my laptop it never showed up on My Computer even though the blue light on the hard drive came on.
Here is what I did:  Right click on "My Computer" and click on "Manage" and then "Disk Management",. you should see your WD hard drive listed. then click on "change driver letters and paths"  and change it from the listed to another drive. I changed mine from G to F drive and it worked for me.
Jul 29, 2008 | Western Digital Passport WDXML800UE...
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
112 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
