Question about Car Audio & Video
The carrier is stuck and will not come out it went to change discs and come up with error and now the eject button does not eject cartridge.
    Problem Solver:
  • 9 Answers
Need make and model of radio or what kind of car b4 I can help you
Posted on Nov 14, 2009
19 in. Coby TFT LCD TV with side-loading DVD player. How do I remove a stuck DVD?
Hi Joanne, The eject button ( micro switch ) on the TV is defective. Please get it changed and the stuck DVD will come out.
May 28, 2015 | Coby Televison & Video
Jaguar 6 disc player not working
If you are getting power to the unit and you hear it clicking and making a sound when you hit the eject button, the this means that a CD is jammed in the track and while it was changing it got stuck and now causes you to see an ERROR message.
What you do is while hitting the eject button, wiggle the CD MAGAZINE up and down and side ways. This will cause the CD to fall into place and your magazine will pop out.
KennyV
Jun 22, 2012 | 2005 Jaguar X-Type
My in-car cdc will not eject the cartridge?.
Press the eject button several times non stop.Like 10 to 15 times non stop and see,if the cartridge is getting ejected out.If its still stuck,then disconnect the car battery negative terminal for 15 minutes then reconnect the negative terminal and heck.If still the cartridge is stuck,then its problem with internal mechanism.You will have to disassemble the unit and manually eject the cartridge out and lubricate internal mechanism.-------------- Unplug the changer and use a flat metal ruler.And slide it alongside the cartridge. try sliding on both sides. You'll eventually trigger the manual switch and it'll pop out.Bif that is also not helping then:--- solution is to disassemble the CD changer and lubricating the mechanisms inside. This is the most common problem with CD changers. Take the unit out of car and try to release disc manually.Take the screws out on both sides of player then remove case . You will be able to manually push the big gear so that the disc goes back into the cartridge. And then it slides out. After that you lube all moving parts with a teflon grease and some parts with silicon spray. This will help.Thanks.Helpmech.
Feb 17, 2011 | Car Audio & Video
6 CD cartridge will not eject
KennyV
Jun 03, 2010 | 1997 Lincoln Continental
My cds are stuck and it wont play them it just keeps saying error
If you have a cd stacker,
Press and hold eject button,insert credit card under cartridge
Push card and move left to right
This will locate micro switch and release cartridge
You can then check discs are inserted correctly.
Dec 18, 2009 | 2004 Toyota Highlander
Changed cartridge--now paper gets stops by cartridge carrier. turned on and off, reinstalled cartridge, cleaned roller.
Press the OK button.
- If paper is being fed at error occurrence, the
error is indicated after the paper is ejected.
- If the error occurs, the print head alignment
values are not changed.
- After exit from the error by the OK button,
the automatic print head alignment will not
be re-done.
The error will occur when the print head
alignment pattern is not printed due to no ink
or non-ejection of ink.
Oct 11, 2009 | Canon PIXMA iP1800 Photo Printer
Ink light of my tx101 keeps blinking
Hello, Amit.
From FixYa, give this a try:
Lift up the scanner bed (top part) of the printer to expose the cartridges.
Push the red triangle button once. Wait for the cartridge carrier to move to the middle. On the housing of the printer (the non-moving part), there is an arrow that will point to the empty cartridge.
Push the red triangle button again to see if the next cartridge is empty. Repeat this step, noting which cartridges are empty, until the cartridge carrier moves to the right. Now you can replace each cartridge that is empty.
After replacing the empty cartridges, push the red triangle button again, and the carrier will begin moving back and forth (cleaning itself). Once it stops, it should be positioned on the far right side.
Lower the scanner bed to "close" the printer. The ink light should go off and you should be able to print.
Hope this helps.
Oct 04, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Six-disc cd player
I too have this problem. My alternator went out, however and when starting the car after having that replaced it must have reset my CD player and it worked again for about 2 months. I am back to the CD error again tho. Thinking of un-hooking my battery cables to see if that will reset it again.
Apr 01, 2009 | 2003 Mercury Mountaineer
My disc is not changing and is stuck ( CHM - S620 by Alpine )
hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent.
regards
Mark
www.carradiospares.co.uk
Feb 16, 2008 | Alpine CHM-S620 6-Disc CD Changer
Alpine CDM-9803 Cd Player
You need to visit Alpines' site to download the owner's manual for your unit. In the mean time here is some info from the troubleshooting guide for your error code.
• Mechanism error.
1. Press the "eject" button and eject the CD.
If not ejecting, consult your Alpine dealer.
2. When the error indication remains after ejecting,
press the "eject" button again.
If the error indication still does not turn off after
pressing the "eject" button for a few times, consult your
Alpine dealer.
Note
When the "- - - E" is displayed:
In case that the disc cannot be ejected by pressing the "eject"
button, press the RESET switch (refer to page 4) and
Good luck.
Feb 08, 2008 | Alpine CDM-9803 CD Player
Car Audio & Video Logo
117 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
