Question about Casio HR-100TEPlus Calculator
Need help w/ink
How to change the ribbon or ink on this product?
  • 2 more comments
  • Anonymous Jan 10, 2008
    how do you change ribbon on the Casio HR-100TE?
  • Edva Jan 10, 2008
    how do I change ribbon on Casio HR 100 TE?
  • Ivonne S
    Ivonne S Mar 28, 2008
    i dont know how to change/put the ink in?
  • TDSS 3950 Jan 29, 2009
    I have a HR-100TE. Does it take the same ink roll as the HR-100TEPlus. If so, where do you find them?
    Champion:
  • 204 Answers
Hi...This calculator takes a IR-40T ink roll.
Turn off the power.
Open the top cover,
There is a flat tab on the ink roller, lift up, remove.
Hold the new roller by the tab, line it up in the slot and snap in.
Turn on the power and test.
If it doesn't work you might not have it snapped in properly or all the way.
Good Luck........
Squipps
Posted on Feb 07, 2008
Why doesn't my new corrector ribbon/ink ribbon work? The wheel advances-nothing shows on paper.
Put in a multi-part form, type if the carbon is OK the problem is with the ribbon. Look at the ribbon if there is an impression on the ribbon but no ink transfer the ribbon is very ols, if there is no impression then the ribbon isn't lifting. THere ix a 2" black gear on the right side of the printer it should move easily if not wiggle it back and forth they get tooth for tooth with the drive gear.
DickyO
Oct 10, 2014 | IBM Wheelwriter 6 Typewriter
How do I change an ink ribbon?
lift the lid lift old ribbon cartridge off snap a new one in
Sep 11, 2014 | Brother Gx-7750 Correctronic Electronic...
I want to change the printer ribbon on Zebra s600 203 dpi, is there a way it will rewind existing ribbon off?
Thermal printers don't use ribbons or ink. They transfer images/text with heat on to special thermal paper.
Mar 23, 2011 | Zebra Stripe S600 Thermal Label Printer
How do i change the ink cartridge
No ink cartridge - the ink is on the ribbon. Replace the ribbon if out of ink.
Dec 14, 2010 | Sharp EL-1801P Calculator
The correction tape is not working properly. Wheelwriter 1000
If everything was working befor the ribbon & L/O change Either the L/o is not properly attached to the ribbon or the ribbon and or L/O are old. Make some corrections then remove and look at the L/o, if the letters are near the center of the L/O the problem is the ribbon or L/o is old, if the print is on the top of the tape it is not properly attached to the ribbon or not coming out or the cassette properly.
If you have a fresh set or another T/W that works swap the ribbons and look at how they are attached.
For a picture ngo to lexmark.com and click your way to publications you will find a downloadable manual there.
DickyO
Jan 23, 2010 | Lexmark Wheelwriter 1000 Typewriter
Printing is very faint. How to change or add ink printer device.
This is most likely a ribbon impact system. Any office supply store should have the ribbon you need, with information on compaitability on the package.
Remove the paper roll and gently but firmly pry on the bezel surrounding the paper exit path. Examine the sides of the ribbon casing for any clips or fasteners.
May 22, 2009 | Victor 1280-5 Calculator
Brother intellifax 770
Winding technique:
To wind a new ribbon, take the cartridge housing apart and remove the old ribbon and two cardboard cores. The new ribbon is fitted with the larger roll (the ink ribbon supply spool) at the rear side of the cartridge (as the housing is viewed when it is normally installed into the machine). The ribbon winds over the topside of the rear spool (the supply side) and feeds into the underside of the front spool (the take-up side). Make sure the ribbon is wound neatly, evenly and is tight. If the ink film has become detached or is too loose on the front spool it will not wind on and cause a machine error. If required, use a small amount of sticky tape to secure the ink film to the front cardboard spool and then neatly wind it on to the take-up spool a minimum of five turns, making sure the film does not overhang at the edges. Now reassemble the housing and refit into the machine.
If it’s still not fixed:
If problems persist after fitting a new ribbon, try replacing the entire ink ribbon unit (cartridge housing + a new ink ribbon) using a new, genuine Brother unit before requesting a service; this will be less expensive as the actual housing may have been damaged and is causing the problem and this unit is readily available as a consumable item through sales outlets. If the machine still has problems, book your machine in to be repaired with an authorised Brother Service Centre.
Feb 25, 2008 | Office Equipment & Supplies
VERIFONE OMNI 3740 INK RIBBON
We found that it was neither the thermal paper roll nor the thermal component. The cover did not close tight enough and that caused the print-put to be light or missing printed areas.
Jan 04, 2008 | VeriFone (M19755014US1) Magnetic Card...
Zebra 105SE
make sure the ribbon is installed properly. The thermal ribbons are only coated on one side with ink. Make sure the right side is facing the paper. If that is not the issue the thermal head might be bad.
Jun 26, 2007 | Zebra 105Se Thermal Printer
Casio HR-100TEPlus Calculator Logo
616 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
