Question about AT&T Siemens S46 GSM Cellular Phone
Can you back this laptop up to the first day i got it . i did my friends for them and i pressed f8 on start up and it let me do it from there does this laptop do the same .my friend had a dell mine is a fujitsu siemens v5535
My gateway laptop ne56r31u is stuck on a blue screen with please wait and a rotating thing on it. It has been like this for days and it won't reboot. It just comes back to this screen. I have tried...
If you press the power button until it shuts off, power it up and press F8 just before the boot sequence starts, select repair or safe mode from the menu.
Feb 19, 2014 | Gateway Computers & Internet
My laptop is stuck on the screen before the page for the login screen, it is a blinking dash, with a black backdrop, it has been stuck for 2 days, what is wrong with it? And how can i fix it?
If the DeLL Post screen comes up it means that your laptop is okay. Pretty much your windows is corrupted and that's the reason why it's not starting up.
Things that you can do: (for windows vista & windows 7 only)
1. Restart the PC and immediately press F8. (You need to tap/press F8 repeatedly while starting up). You should get a screen that says "Advanced option menu."
2. Select Last known good configuration. If it does not work. restart the pc and press F8 again.
3. Select Repair your computer.
4. Run start up repair. If nothing happens. Run system restore. If it fails, the boot manager file of windows is corrupted.
Last option, you could try Dell PC Restore by pressing CTRL + F11 at the same time while the system is starting up. (You could start pressing CTRL + F11 when the DELL flash screen comes up).
NOTE: Running Dell PC Restore will erase your files/data & put your system back to factory settings.
Dec 31, 2010 | Dell Inspiron 1545 Notebook
I just bought a hp laptop from a friend and tried to change the password and accidentally locked myself out of it i cant remember the username or password
Hi, Welcome to Fixya.
Did you try start the PC in safe mode & Administrator?
Restart your PC, press F8 , Select safe mode with networking prompt, Open the user Administrator, Go to control panel> Users> select the user > change password for it.
Let me know further.
Thanks for joining us.
Have a nice day.
Feb 03, 2010 | HP Pavilion dv6000z Notebook
I have a toshiba laptop and my camera can't operation
start ur laptop & press F8 BUTTON for 2 minutes only. it will come back in working condition before one day. but those work u r working on laptop, it will be lossed. if interested then do it.
thanks,
sanjeev,
+919876388918
Jan 02, 2010 | Toshiba Satellite Pro M300-S1002X Notebook
SONY VGN CS215J Shut down by itself
just start the laptop in safe mode with command prompt and run chkdsk /r/f command
how to go to safe mode with command propmt just press F8 KEY when you switch it on.
Sep 10, 2009 | Sony VAIO VGN-CS220J/W Notebook
Computer won't start
Check if the lock lights on top of the keyboard turns on or off when you press/toggle the capslock or the numlock key. If it does, you have an LCD or video card issue. Connect an external monitor to your laptop, if you have one. Turn the computer on. If both LCD and monitor dont have video, try pressing Fn F8 together once, twice or thrice. If you get video on the external monitor. the lcd screen may have loose connection or damaged. If no video on both, might be a bad video card.
Jan 02, 2009 | Sony VAIO VGN-FS640W Notebook
It shows installing updates
Try to start in safemode, (press f8 in start after popup of bios screen) then run system restore back one or two days, restart your computer and it should be fine.
Jul 01, 2008 | HP Compaq nx6310 Notebook
My computer keeps restarting itself
  1. Start laptop
  2. When the laptops Logo page closes, start to press F8
  3. You should get a Windows Start screen
  4. If you get a Windows Logo page (the kind you normally get when Windows loads, then reset it and start again.
  5. On the Windows Start page select "Last known good configuration" and press enter twice
Hope that solves it for you =)
Apr 12, 2008 | Acer Aspire 5500 5570-2609 Laptop
Laptop
when booting up press F8 and select safe mode ,then remove any software you installed just before this started to happen,
or use the restore function in system tools to restore back to an earlier time before the problem start.
good luck
Terry
Mar 08, 2008 | Computers & Internet
AT&T Siemens S46 GSM Cellular Phone Logo
20 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
