Question about Maytag Washing Machines
Washer will not turn on when setting dial and
Maytag model LAT5914AAE - today washer will not turn on when setting dial and pulling ou, yesterday worked fine.
  • garybona Nov 13, 2009
    Thanks for the quick reply - I will order and install a new timer and see what happens.
  • 6,784 Answers
HI. The timer module will be the culprit here. If the unit dose not start when the timer dial is pulled, or set to the on position, this will usually mean that the timer mechanism has failed(Internal circuit failure). Once this damaged timer module is replaced, the unit will operate correctly.
Your Timer Part Number will be #22001252
Posted on Nov 13, 2009
My washer wont leave sensing mode maytag bravos x model # mvwx500xw1
Shift mode sensor Orange thing at bottom of washer stuck on spin not shifting for agitation common in Whirlpool & Maytag and few others
Jul 04, 2016 | Maytag Washing Machines
I have a roper washer 5 years old and it won't drain or turn on now it was working fine yesterday ive unplugged replugged pulled out all the clothes checked power supply and hoses what now?
I looked up your model number. You particular machine allows for wash with the lid open. You nothing happens. On that case I would check the motor capacitor.
Nov 13, 2011 | Roper RAS8445KQ Top Load Washer
I have a Kenmore 80 Series Washer (Model # 20802990) and it was working fine yesterday, and today it will go through the wash, fill up and go partway through the rinse cycle and then stops. It wont drain...
the lid switch is broken this video will show you exactly how to replace it....
http://youtu.be/MFsvLiuTniU
the part#for the switch is 3949238 you can order it by going to searspartsdirect.com or look in your local phone book and find a parts dist. in your area
Jul 20, 2011 | Kenmore 24032\24036 Top Load Washer
Hi, I have an Admiral Capacity plus washer model no LNC6764A71. Earlier today it ran fine, but now has filled and isn't running. I've tried turning the dial to another setting like agitate or...
Feel the motor. If it is real hot after it quit it could be toast. Or something in the pump could have over heated it. Take the belt off and turn the pump to see if it is hard to turn, look in it to see if something got in it. Tip the washer back and you will see this:
Check the motor shaft for play or stiffness. If it works after it cools down then the motor overload tripped it. Might be the pump might not be.
Maytag product single belt washer service manual
Jul 10, 2011 | Admiral AW22 Top Load Washer
Washer worked fine all week. Today. I went to use it and I pulled the knob out to start the machine and nothing happened. Just the little red light came on. It is a Maytag top loading model LAT9734AAE
door switch look where lid closes and depresses closed swich that swich has 2 wires on it un plugg them tape them together hit start it should work
Jan 24, 2011 | Maytag Washing Machines
Fuse blown on Maytag washer
Could have been a surge dont think its anything to worry about ....run and keep an eye on it ....
Apr 12, 2010 | Maytag PAV2300 Top Load Washer
Maytag Atlantis -won't spin
Find out where your filter is & clean it out thoroughly, refit.
May 10, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Washer Problem
Have you tried starting the wash cycle at several different time settings? Especially the shortest time setting, just before the start of the first spin? If it works at another setting, it's possible the dial/switch mechanism is worn and not making contact at your usual setting. In any case, a spray of a good electrical contact cleaner spray (NOT WD40 or similar) - with the power lead UNPLUGGED - sprayed into the switch mechanism might help. You would need to remove an access panel to get at the switch mechanism.
Ian from Australia
Dec 26, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
