Question about Estate EED4300SQ Dryer
I HAVE CHANGED MY HEATING ELEMENT, THERMOSTATS, CIRCUIT BREAKERS, AND CHECKED THE HOSE AND MY DRYER IS STILL NOT WORKING. WHAT OTHER THINGS SHOULD I DO?
  • Estate Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to replace or check your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Posted on Nov 13, 2009
Whirlpool awz135 wont heat up
Check the circuit breakers and see if one has tripped.
There are two circuit breakers that run your dryer.
One does the heating element, one does the motor and controls.
Usually they are together side-by side in your "fuse box" wherever that is.
The circuit breakers may look fine , but still be tripped.
If you will switch them off and back on again, see if that fixes it.
It may take a few times, like 3 or 4.
Other than that, newer models have more thermostats and also a fuse.
Is it possible you could find an overheat element you missed, like not with the others?
Be blessed.
Be blessed.
Feb 18, 2013 | Whirlpool Dryers
Kenmore dryer bought in 2004 stops heating
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Thank You
Nov 01, 2008 | Kenmore 64852 Electric Dryer
Runs but does not heat up and does not dry. The service man showed me the reset button. It was tripped for him but does not appear tripped now. We have had this problem intermittently for a year. Every...
HI,
If your dryer doesn't heat, check these:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 11, 2008 | Asko Dryers
My maytag lde8824ace dryer has stopped heating. i replaced the heat element assembly about an hour ago and still no heat. vents and ducting are clear. dryer run as normal. was wondering if it was a...
The heating circuit is composed not just by the heating element alone but also the high-limit thermostat located on the heating element housing including the four-terminal cycling thermostat on the blower housing and the motor centrifugal switch. The most prudent thing to do first when a heating problem is experienced is by checking the continuity of these parts and making sure the dryer is getting 220VAC supply. Note that the dryer works both on 110VAC for the controls and drive motor while the 220VAC is solely for the heating circuit. The 110VAC supply may be present which will make the dryer run but the 220VAC may not be present and consequently there's no heat at all.
Check the circuit breaker including the power outlet and make sure the dryer is being supplied with 220VAC. Check the continuity of the components located on the blower housing and the heating element housing. All of those components must have continuity for the heating element to turn on. Note that the cycling thermostat has four terminals. Continuity check must be done between the two outer and "thick" terminals. Replace the part found to have no continuity and as a preventive measure, it is necessary to also replace the other part that comes side-by-side with the faulty part.
Aug 21, 2011 | Dryers
THE DRYER IS NOT GETTING HOT
Verify that all breakers (or Fuses) are fine, Electric dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Sometime, the dryer may heat, but it may not heat up as hot as it should. To repair, first check the vent hose. It must be clear for the dryer to work well. Make sure that the hose is not being crushed by the dryer. If the hose is very worn, or crushed, you'll need to replace it. The hose attaches to the back of the dryer and the outdoor vent with a spring clamp.
Another common cause of a dryer failing to heat is a faulty element (Heating Element). You'll need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 21, 2010 | Roper REX4634KQ Electric Dryer
I switched my Kithen Aid Electric dryer [KEYE664W] from mediun to high heat AND THE HEAT STOPPED! Now all temps have know heat. Blower works.
You may have had a short circuit between the heat selector switch and the element/thermostat!! Have a technician test the heat switch, and the element and thermostat.
Dec 14, 2009 | Amana NDE2330AY Electric Dryer
My Kenmore Elite (Whirlpool) HE3 elctric dryer is no
A dryer not heating usually means that either the heating element is burned/broken (open circuit); a thermal fuse in line with the heating element is blown or; a thermostat is faulty.
Dryer needs to be partially disassembled to diagnose with a multimeter.
Charlie
Sep 29, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My Kenmore electric dryer runs but no heat ....
Before I wish you luck i want you to review all of the possible reasons for your problem
Heating element
Thermal fuse
Wiring
May 29, 2009 | Kenmore 62602 Electric Dryer
Roper Dryer heats for 5 minutes then stops heating but still tumbles. I haven't a manual so there isn't a schematic to work with. Appreciate any suggestions;
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Sep 14, 2008 | Roper REX3614KW Electric Dryer
It runs, but no heat
i dont believe at this time its anything mentioned at top most people dont realize that dryers are split cuircuts
is this a 220 setup
and if its a 220
the cuircuit breaker for this is set by 110 each one for the heating element one 110 for the guages and motor
goto circuit breaker and flip the breakers this should return your dryer working ability
other thing is are the guages working properly
dryer doesnt have to run to test guages turn to the highest setting and let them run completly threw cycle if they stop on a particular setting for a long length of period then the guages are bad
May 29, 2008 | Whirlpool LTE5243D Top Load Stacked...
Estate EED4300SQ Dryer Logo
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
