Question about Nokia N95 Cellular Phone
Lock code to open - Nokia N95 Cellular Phone
Cant open lock code 5530xpressmusic
You mean the network lock code?To open this you need to give the unlock code.I suggest you can approach unBBlock.com (specially for Blackberry mobile model) or Simpleunlocking.com and specify the mobile make,model,country,locked network.Based on the availability you can get the unlock service along with free instructions.
Dec 20, 2013 | Cell Phones
Tip
Nokia contact service Tricks
Nokia dct4 contact service hardware or software easy to find<br /> <br /> <br /> NOKIA DCT4 CONTACT SERVICE HARDWARE OR SOFTWARE EASY TO FIND WITH UFS+HWK<br /> <br /> <br /> 1)CONNECT UFS+HWK<br /> 2)SELECT DCT4 TAB<br /> 3)USE INFO BUTTON(SOME TIMES PHONE NOT ENTER LOCAL MODE JUST LONG PRESS POWER BUTTON<br /> 4)CHECK INFO DETAILS<br /> <br /> <br /> <br /> 5)SL DATA CORRUPTED(MEANS SIMLOCK ENABLED)<br /> 6)JUST UNLOCK PHONE<br /> <br /> <br /> <br /> SEE SECOND PICTURE INFO DETAILS 100%DONE.BUT PHONE STILL SHOW CONTACT SERVICE<br /> 7)CONNECT SET<br /> 8)RUN SELF TEST<br /> <br /> <br /> <br /> SEE THIS SELF TEST DEIALS<br /> EAR _CLK_LOOP TEST----------NO SIGNAL<br /> RF CHIP ID TEST---------------FAILED<br /> THIS CONTCAT SERVICE HARDWARE PROBLEM<br /> HARDWARE CHANCE<br /> 60%UPP<br /> 30%UEM<br /> 10%OTHERS LIKE BSI ETC...........<br /> <br /> <br /> <br /> SEE ANOTHER SELF TEST DETAILS<br /> LCD TEST-----------FAILED<br /> RESONS LCD MISSMATCHED<br /> JUST CHANGE DISPLAY NO NEED TO FLASH&UNLOCK ETC.............<br /><br />or alternatively....<br /><br /><br /><br /> <b>SX4: SX4 <span>Smart Card</span>, is a tool or method which is developed by Nokia to<br /> write some data protection for a specific area in EEPROM is useful for<br /> preventing modification of the data.<br /> </b><br /> <br /> When SX4 PROCESS is Required ?<br /> <br /> <b>In the case of a loss (data corrupt) data charging (not charging), data<br /> network (no network). Dll.RF calibration calibration-charging.<br /> So, all these problems caused by mistakes in the process of flashing or after<br /> write RPL or erase process is done in a certain area <br /> </b><br /> <b><br /> <br /> <span>HOW DO I</span> KNOW THAT MY PHONE PROCESS SX4 needs to be done?</b><br /> <br /> <b>When the phone appears CONTACT SERVICE, CONTACT retailers, NOT<br /> charging after flashing, no network, etc. When the SELF TEST is done by<br /> using the box like JAF repair, etc. will be obtained is the result of failed "ST_SECURITY_TEST Failed"<br /> <br /> <b>How do I make a SX4?</b><br /> .</b><br /> <br /> <b>Plug the phone in the repair box (JAF, MTBOX, MXKEY, etc.)<br /> Write pm area with 309 results read from the normal mobile phone or can<br /> also write FULL PM area without 308 (<span>SIMLOCK</span> area). </b><br /> <br /> <br /> <b>What to do sx4 without internet connection?</b><br /> <br /> <br /> sure <span>Certificate</span> damaged area musti made first with the FLASH erase, or<br /> write RPL blank<br /> Reset NPC (when using mxkey)<br /> What is a Certificate Area?<br /> Press info on the box like JAF flasher, etc. and see the results LOG ...<br /> This is an example of the correct Certificate<br /> Default SN type:<br /> <br /> Code:<br /> <br /> IMEI plain: 351862xxxxxxxxxx<br /> IMEI spare to net: 3A 15 68 02 01 23 60 03<br /> IMEI SV to net: 33 15 68 02 01 23 60 03 F6<br /> LOCK STATUS:<br /> Config KEY: 0000000000000000<br /> Provider KEY: 2440700000000000<br /> Provider: AT &T; U.S.A. (3650)<br /> <span>Key Code</span> count: 0, FBUS Code count: 0<br /> Block 1:Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN<br /> <br /> Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN<br /> <br /> <br /> Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN<br /> <br /> <br /> Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN<br /> <br /> <br /> Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN<br /> <br /> <br /> Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN<br /> <br /> <br /> Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN<br /> <br /> <br /> This is an example Certificate of damaged<br /> <br /> Default SN type:<br /> <br /> Code:<br /> IMEI plain: 123456765321?<br /> LOCK STATUS:<br /> Config KEY: fffffffffffffffffffffff<br /> Provider KEY: fffffffffffffffffffff<br /> Provider: Unknown<br /> Key Code count: 0, FBUS Code count: 0<br /> <br /> Block 1: Lock 1: CLOSED<br /><img src="moz-screenshot-2.png" /><br /><br /><img src="moz-screenshot.png" /><img src="moz-screenshot-1.png" />
on Apr 26, 2011 | Cell Phones
Eminent luggage lock
TSA lock on Eminent Osmosis Luggage, three digit TSA lock (HOW to change it to YOUR personal number)
Put the code numbers to '000'
Take the lock levers OFF the lock
Push the round opening button UPWARDS.
IMPORTANT :
KEEP holding the button UP until you have changed the numbers
Change the TSA code numbers to what YOU want
Release the round opening button
Now your case combo lock numbers have been changed.
To lock the case put the two lock levers into the holes, spin the numbers and your case will be locked.
To UNLOCK the TSA code spin the numbers to YOUR lock code, push the lock button UP and, hey presto, your case will open.
If you forget your NEW lock number you will NEED to go through ALL the numbers, starting at '000' to '999', to be able to open the lock/case.
REMEMBER to PUSH the ROUND OPENING button UPWARDS on EVERY number change.
Only THEN, when it finds YOUR correct three digit number, will it eventually open the suitcase/luggage/baggage.
Good luck
Aug 31, 2013 | Luggage & Travel
I forget my screen lock code of samsung GT-B5512 please help me to open it? Read more: I forget my screen lock code of samsung GT-B5512 please help me to open it? - I want to open the screen lock of
Please try this link:
http://www.howardforums.com/showthread.php/1765029-How-To-Unlock-Samsung-GT-B5512-By-Unlock-Code-To-Work-With-Any-GSM-Network
Nov 12, 2012 | Cell Phones
How can i open lock nokia 6070
try code from Online site and open it...
Oct 24, 2011 | Nokia 6070 Cellular Phone
Nokia 6500 slide help i need restriction code
PLEASE READ FULL INSTRUCTIONS BEFORE DOING ANYTHING
TRY WITH NO SIM CARD IN THE PHONE
Doing this is at your own risk!
Every code unlocks a certain lock. Code number 7 usually unlocks them all but some phones are 'buggy' and will not accept code 7 at first then use code 1.
Usually you only have to use code 1 or code 7.
#pw+xxxxxxxxxxxxxxx+1#
1. Press ( # ) on your phone
2. To get ( p ) press ( * ) 3 times within 1sec
3. To get ( w ) press ( * ) 4 times within 1sec
4. To get ( + ) press ( * ) 2 times within1sec
5. Enter the 15 digit code
6. To get ( + ) press ( * ) 2 times within 1sec
7. Enter code number
8. Press ( # ) on your phone
Now your phone is unlocked!
If your phone isn?t unlocked after code 1 or code 7 then you have either entered the wrong IMEI or Network. Sometimes there could also be a problem with newer software versions. Then you can try another 'Boxserial' Remember! You have only five tries to enter the right code. After that you will need a cable to unlock your phone. So please, be aware
Phone type: DCT4
IMEI: 352027025104628
Model: 6500
#pw+319926630701132+1#
#pw+702310427045122+2#
#pw+754840072200550+3#
#pw+093433717136641+4#
#pw+199064315752575+5#
#pw+286305406405613+6#
#pw+307016424512121+7#
There is 4 locks on a Nokia DCT4 phone.
Lock 1: MCC+MNC (Network och landsspecific)
Lock 2: GID1 lås (SIM-card typ)
Lock 3: GID2 lås (SIM-card typ)
Lock 4: MSIN lås (SIM-card specific lock)
The generated codes open up one or several locks.
Code 1 open lock 1
Code 2 open lock 2
Code 3 open lock 3
Code 4 open lock 4
Code 5 open lock 1 and lock 2
Code 6 open lock 1 lock 2 and lock 3
Code 7 open lock 1 lock 2, lock 3 and lock 4
Let me know if you have any problem follow these instructions and you should be ok.
I think it needs to be done with no sim card in the phone remember you only get 5 goes after this if its still not unlocked then the only other option is with a lead and unlocking software.
This should solve your problem let me know how you get on ok
This is done at your own risk!
Aug 02, 2008 | Nokia 6500 Slide Cellular Phone
My samsung e250 doesnt open sim lock,please gve me the code
please help me my e250 doesnt open sim lock please provide me a code
Jun 17, 2008 | Cell Phones
Recorvery mobile lock code
download nokia unlocker from google search........
May 06, 2008 | Nokia N70 Cellular Phone
Nokia 6500 slide - RESTRICTION CODE
READ IT ALL BEFORE DOING ANYTHING TRY IT WITH NO SIM CARD IN THE PHONE AS THIS IS HOW ITS USUALLY DONE OK
Phone type: DCT4
Model: 6500
Code 1 open lock 1
Code 2 open lock 2
Code 3 open lock 3
Code 4 open lock 4
This is all done at your own risk!
Apr 26, 2008 | Nokia 6300 Cellular Phone
Nokia N95 Cellular Phone Logo
51 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
