Question about Nokia N70 Cellular Phone
MY n70 AFTER MORE THAN 2 YEAR GOOD SERVICE DOES NOT POWER UP, YET IT GETS POWER SUPPLY NORMALLY. ANY TIP APART FROM GOING TO ASSISTANCE AND HAVE ALL MY DATA ERASED?
My Samsung LCD TV will not switch on it is only 3 years old
Good day!!!!
That problem is cause of bad power supply..
If you wish to repair it to end that issue and your TV get back to normal operation you need to repair the power supply board..
If you need a step by step procedure on how to do that please try to get my service and I will do my best to repair your TV..
This is my service
LCD HDTV ASSUMED TO FIX..Please click that link and get my service..
Thank you for using fixya...
Oct 08, 2011 | Televison & Video
No power. We had power outages. Is there a fuse inside? thanks... Greg
Check that the Fuse F1 on the Power Supply Board has not blown.
jackpot00_106.jpg Download this service manual for Epson Stylus Photo R1800 ..>
http://www.resetters.ru/download/SM/R_1800_2400_B.pdf Go to page #206 .
Note:Note: Epson manuals are provided in .PDF format, which requires the free Adobe Acrobat Reader. If you wish to save the .PDF file to your computer for later use, right click over the link and choose "Save Link As" or "Save Target As.")
Jul 26, 2011 | Epson Stylus Photo R1800 InkJet Printer
Lg tv takes a long time to turn on. Flat panel 32" LCD 3 years old
Power supply board have those parts call capacitors are dying,have leakages gases capacitors parts.Take the tv aparts.The power supply board,that the board,where the power a/c cord plug into it.U know basic electronic,have all the tools?know basic soldering?Searches the power supply board for those dying capacitors,that have leakages of gases going to dead capacitors.These dying capacitors on the power supply board alway bulges up on it tops or puffing up on it tops.These dying capacitors,must be replaced.The tv power will power up as normal and faster.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Aug 04, 2010 | LG 32LG30 32 in. LCD HDTV
994 service density sensor
The 994 Density Error indicates that the printer's system card has encountered an unrecoverable error. The 994 Density Error can be caused by the density sensor becoming dislodged from the sensor board. This normally requires a service call. However, for basic troubleshooting, try powering the printer off, wait ten seconds, and then power the printer back on. If still no go, if possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages. If problem persists, I strongly recommend contacting your Authorized Service Provider or Lexmark Technical Support for assistance. I hope I can assist you more on this.
May 10, 2010 | Lexmark C912 Led Printer
Need NoviTech shredder customer service number or assistance
These are easy to take apart. Should be 4 screws maybe six. One might be behind a label. Just pull it apart and unclog the gears or cutters. Be careful not to cut yourself. Take pictures after shell is apart. That way you can unclog and put back together.
Apr 16, 2017 | Office Equipment & Supplies
No power. Completely dead.
can be a few things but most people claim the power supply unit is at fult, here
POWER SUPPLY UNIT QAL0756-001 JVC LT-26X506 usually that part will correct most issues with these TV's i ordered one for my client, i am a computer specialist but i work with almost every type of monitor/ system out their myself, and this is often a isue after a year or 2 with these. good luck.
Jun 02, 2009 | JVC LT-26X506 26 in. LCD Television
It's 945GCR Motherboard. When the jumper is kept in clear mode it is going on. when it is in normal there is no display. I've checked RAM and Power Supply. Everything is fine. Can anyone assist me!
Please check the capacitor near processor, 1000uf or 2200uf. do you see the the top of it is change shape i mean convex. if yes, just replace it. If not, turn on the pc without RAM, do u hear beep sound? if beeping its normal but the controller or chip set is not work good
May 04, 2009 | Intel D945GCL Motherboard
Monday afternoon I put some clother on to dry. My husband was at home so I left to go to my mother's home. When I got home i went to get the clothes out of the dryer and they were still wet. I pushed the...
Dear friend,
ngfam at you service! happy to assist!
A surge like that can destroy or fry many electrical appliances and computers too!
GET SERVICE.
But not if 10 years or older .
See my advice below too!
If the appliance is 10 years or older its not worth investing money to ix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 28, 2008 | Maytag Dryers
My 3 year old Westinghouse LCD TV is now going black. I have to turn it off and back on to get the picture up. Does this mean the bulb is going? I would think that if the bulb was bad it wouldn't work at...
The lights normally last for a very long time, the manufacturers claim that the could last up to 60000 hours.
In this case It appears that it could be the inverter board from where the lights get the power from, or the +24VDC are not being supplied; if the 24VDC are not supply from the power supply the inverter board ot lights will not work.
The 12VDC that supply the audio circuitry are working, since you can still hear it.
Let me know if you need further assistance.
Aug 20, 2008 | Televison & Video
Turns itself off
This might be a power supply failure or the beginning of the end for that power module. If your TV is 2 1/2 years old, chances are that the power supply ia about to fail completely until you will not be able to power the TV up anymore.
The first place to isolate the failure is by checking all the voltages from the power supply, if all of them appear normal then is a failure on the main board.
I service these power supplies since is becoming more difficult to find service parts for these TVs.
If you need any more assistance, my email is jah2mil@hotmail.com
May 13, 2008 | Protron PLTV-32 Television
Nokia N70 Cellular Phone Logo
29 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
