Question about Apple iMac 17" Desktop
When i turn on my imac it appears only blue scrin and i restart it again but still the same thing.please help
  • 281 Answers
Hopefully you've backed up your content. The best solution is to restore your unit with the Apple recovery discs that the unit come with. You can also hold down "D" to run a quick diagnostic to see if any hardware fails.
Posted on Nov 13, 2009
Imac intel blue screen
Can you start up in Single User Mode? Restart and hold down the command/Apple & the "S" key.
Apr 17, 2012 | Apple iMac G5 Desktop
Teach scrin
restart the phone 2 times
Apr 09, 2012 | RIM BlackBerry Storm 9530 Smartphone
My 21" mid 2007 imac periodically freezes, the
Try booting it into single-user mode holding down Command(Apple) and S buttons when powering up. Then in terminal console, use chkdsk -fy. Use it and use it again until comes back with something like "Volume appears to be OK". Then use command: mount -uw / and then type reboot and try booting normally.
If it does not fix your problem, it's most likely a hardware issue (logic board / graphics card), and you should take it to an Apple Authorized Service Provider.
-juuko
Nov 08, 2010 | Apple 24" iMac Desktop
I plugged my imac bondi blue in hit the power button and nothing happens. It seems to be ok it just won't turn on. Please help me.
First thing to do is test (and then almost certainly replace) your ten-year-old logic board battery. If the battery is dead, the power button won't function.
Oct 21, 2010 | Apple iMac M6709LL/B Desktop
Wont boot on its own, wont boot with install disc,
As the hard disk appears to be showing up when you boot up using the install disc, I would suspect that the system is somewhat corrupted. You could reinstall the system again and if you are happy starting from scratch and wiping the hard drive select this option failing that and there is some data on the imac you could install using the preserve user data. A fresh install should sort out any problems. Hope this helps.
May 18, 2010 | Apple 20" iMac Desktop
My imac wont turn on!
It sounds like something is either corrupted on your system or one of the files in your imac may be suspect. What I would suggest is get your system disc boot the imac down holding down the c key on your keyboard. Once it is booted up go to the file menu and find the disk utility. Open up the disk utility and first of all repair your disk permissions and then run disk verify and if an error comes up choose to repair it.
If this does not work. I would suggest installing a clean system. Again with the system disk in your computer restart your machine with the c key held down on your keyboard. Choose to do an install but remember to select preserve users. This will give you a clean instal with your files and preferences intact.
Once your machine has restarted it is well worth setting a second account under system preferences under accounts as if one account becomes corrupt in the future you have a second account to fall back on.
For prevention of any problems in the future I would download Onyx from this website http://www.switchingtomac.com/tutorials/keep-your-mac-running-smoothly-with-onyx/ which also talks you through the method of using it. I use it every month just to keep my mac in tip top condition.
Hope this helps.
Apr 03, 2010 | Apple 24" iMac Desktop
Imac G5 keeps freezing on turn on
Get out your Mac OS disc and restart your computer and get that disc into the drive. You may need to restart with the disc in, but that's ok.
Just restart again with the "C" Key pressed and the computer will launch with the OS disc, and then you can access the file menu when it finishes launching.
Choose "Disk Utitlity" from the file menu and you can repair the system files on your hard disk.
then restart without the disc in the drive.
K
Sep 14, 2009 | Apple iMac 24" Desktop
When i stert my g4 imac,s screen was became blue
You need to reset your pram
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Jul 01, 2009 | Apple iMac All-in-one - 3.06GHz Intel Core...
Lenvo blue screen error message when computer starts up
Please try to unplug the laptop from power and remove the battery for over 10 seconds. Then start it up again. There are other things we can try if this does not work.
Mar 19, 2009 | Lenovo 3000 N200 Notebook
Hard Drive doesn't show up
Try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
And press & hold the power button for 2 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing.
Restart the system.
If it does not resolve the issue then you can try this :
Just remove the registry key it happen when this key is corrupted.
HLKM\System\CurrentControlSet\Enum\USBSTOR
And delete all references to the external hard drive.
And also HLKM\System\CurrentControlSet\Enum\USB
and found the keys associated with the USB to IDE value.
After restarting the system, the drive shold be detected & configured automatically by the computer.
Good Luck.
Live, Love, Laugh.
Mar 30, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Apple iMac 17" Desktop Logo
94 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
