Question about Dell Dimension 9100 PC Desktop
Have SATA hard drive and have added a hp1260i SATA DVD-RW. All software has loaded. All Dell downloads done. STILL Windows XPpro cannot find the drive. Anyone know how to make this drive work in the Dell Dimension 9100?
    President:
  • 2,030 Answers
You probably dont have the jumpers set correctly.
Posted on Nov 13, 2009
Testimonial: "Not by my PC right now, but this solution makes perfect sense. I will try when I get home."
I have a dell dimension 8400 with a TSST CORP TSH492B cd-rw/dvd drive. Windows only sees this as a cd-rom and automatically uses the following drivers storprop.dll cdrom.sys imapi.sys redbook.sys. I...
those are the basic drivers for all cd. dvd, and rw drives. if you are trying to use the drive to burn a cd/dvd you need to purchase software for it your download a free burning software from filehippo.com called xpburner or burnerxp i cant recall the exact name
Apr 14, 2011 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
I have a HP model dvd1040i-H16 Super Muti DVD Writer Man.Date april 2007.I'm trying to install in a Dell GX 260 is this player a IDIE Cable or Sata?I don't think Dell supports Sata is there some way to...
Should be IDE cable...IDE interface according to the specs. You computer has IDE connections so the drive should work.
Product Specification Model HP DVD1040i Lightscribe 20X DVD Burner/Black/Retail Manufacturer HP Mfr Part # DVD1040i Buffer 2MB Interface IDE
Include
  • Internal DVD ±R/±RW drive with DVD±R up to 20X, double-layer recording, DVD-RAM, and LightScribe direct disc labeling
  • Software CD including electronic user's guide
  • Quick-Start placemat
  • Getting Help guide
  • Installation screws
  • Nero 7 Essentials
Data Transfer Rate (Read)
  • DVD-ROM up to 16X (CAV)
  • CD-ROM up to 48x (CAV)
  • Data Transfer Rate (Write)
  • DVD+R up to 20X (CAV)
  • DVD+RW up to 8X (ZCLV)
  • DVD-R up to 20X (CAV)
  • DVD-RW up to 6X (ZCLV)
  • DVD+R Double Layer up to 8X (ZCLV)
  • DVD-R Dual Layer up to 8X (CLV)
  • DVD-RAM up to 12X (PCAV)
  • CD-R up to 48x (CAV)
  • CD-RW up to 32x (ZCAV)
  • Access time
  • DVD 160 ms
  • CD 160 ms (typical)
  • Supported Disc
  • CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
  • CD Text, CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM
  • OS requirement
  • Windows 2000 Professional SP4
  • Windows XP Home edition
  • Windows XP Professional
  • Warranty 1 Year Weight 3.3 lbs
    Jan 12, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
    I just installed an LG 22x Internal Super writer DVD and my computer is not recognizing it. I have a jumper connecting the other drive. It is not picking up either one. Both open but nothing else. The...
    I suppose your's is a SATA drive. Disconnect all the sata cables except for the Hard Disk and that of the Writer in question. Boot up and check if the drives works. If not take pains and try installing the drive in another PC (one of your friends'). If it still has the same problem check with where you bought it.
    Jun 20, 2009 | LG SecurDisc 20x External Double-Layer DVD...
    DVD drive wont run DVds or CDs
    I have a dell desktop computer Dimension 9150.
    My DVD drive is not working. I can run DVds.
    Can you help?
    Apr 02, 2009 | Dell DVD-rom DVD Drive
    Problems with getting bootable disks to be read - Dell/VISTA
    Solution:
    i) when you start your system press button(F8 or F10 or DEL) so that you can go into BIOS menu now     try explore BIOS menu and see whether
      a) SATA 0 - ST325082045 3.ADG
      b) SATA 1 HL-DT-STDVD +-RW GSA H31
       are just visbile(in sense, you can see them in  BIOS writen ), this will make sure system is able to        detect them, we will be assured that your a)HARD DISK b) DVD writer   are working perfectly ......
        if so without any hesitation format or reload system with  Windows Vista....
    ii) if otherwise any one of them or both are not visible in your BIOS Menu like a)HARD DISK b)DVD        writer
       try to open your computer tower and locate cables that are going to ur DVD writer, HARD DISK
       and reseat them(just remove the cable and place them again), by this way we are making sure that    no loose connections are existing..............you can even try new cables .......
       now restart ur system and go in to BIOS menu and repeat the step (i) ....
       if you are enable to see any one or both
          a) SATA 0 - ST325082045 3.ADG ....................HARD DISK
          b) SATA 1 HL-DT-STDVD +-RW GSA H31................DVD WRITER
      then you are having problem with either HARD DISK OR DVD WRITER  and you have to buy them .....
     Thanking you
    M. Sridhar
    Dec 26, 2008 | Dell Inspiron 531 Athlon 64 X2 4400+...
    Cd rom drive
    Hi
    Please use the Cd/Dvd Drive with the following specification:
    CD-ROM/DVD-ROM/Disk drive
    8X max DVD+/-RW Drive with DVD+R double layer write capability
    Or
    16X DVD-ROM drive, 16X/10X/40X CD-RW drive
    Regards
    ELLIN
    Sep 20, 2008 | Dell Dimension 8200 PC Desktop
    My dvd rw is not detected
    Sounds like you need your manufacturer's SATA drivers.
    This problem exists a lot when installing Windows from scratch on SATA hard disks. When you start the installation, Windows prompts you to "load additional drivers". It's at this point you put a floppy disk with the SATA drivers in.
    If your install is already working, but just stopped as you say... then you could hunt around the BIOS for a SATA "compatibility" mode, which will get you booting straight away. Install the SATA drivers and you can then put the drive back into normal operation instead of compatibility mode.
    This is also the reason why your other hard disk with Windows can see the SATA disk and optical drive... it probably has the SATA drivers installed.
    Aug 20, 2008 | Microsoft Windows XP Professional With...
    Dell Dimension 9100 PC Desktop Logo
    148 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
