Question about Nokia 5220 XpressMusic Cellular Phone
How to get Nokia 5220 to use MicroSD card as main memory
Hi
How can I get my Nokia 5220 XpressMusic to use my memory card as it's primary memory.
Thanks!
When i play radio or music player in my nokia 5220, the message show up "not enough memory" eventhough i 've deleted many data in my phone. How to resolve it?
have you checked if there are any firmware updates available for your device via Nokia Suite? if there are any, please update to the latest version offered. Failing that, you can try re-installing your current firmware thru Nokia Suite.
You should also save any photos/videos/music to your memory card, or if you don't have one, then invest in one as your device does support microSD memory cards.
to re-install, select check for updates, and it will say there are no updates, and next to the text saying there is no updates, there will be a paragraph within that paragraph in blue text will be "re-install".
Jun 08, 2014 | Nokia 5220 Red Xpressmusic Unlocked GSM...
Not enough memory in my music player can you help me please !! thx !!
If the built in memory isn't satisfactory, you can allways buy more.
This phone supports microSD cards, up to 8GB. They will cost around 10-15$.
Apr 17, 2011 | Nokia 5220 XpressMusic Cellular Phone
How to re-format nokia 5220 xpressmusic.. camera standby, not enough memory , and i can't send messages :) thanks.
Save your data ,and then type the following after removing your memory card.
*#7370#
It'll restore your phone.
Also, formatting your memory card through your computer, after saving the necessary data will also clear reqistry and other files
Mar 13, 2011 | Nokia 5220 XpressMusic Cellular Phone
ERROR NOT ENOUGH MEMORY IN NOKIA 5220
Pls move some of the files you have on your phone to your memory card to free some space.
good luck.
Feb 19, 2011 | Nokia 5220 XpressMusic Cellular Phone
My micro sd of nokia 5220 xpress music is locked & forgot password,how i unlock the card without any data loss.
you can use this link to Know about password memory.
(wiki.answers.com/Q/How_do_you_remove_micro_sd_password).
Take care.
Jun 17, 2010 | Nokia 5220 XpressMusic Cellular Phone
Nokia 5220 Xpress Music Phone unlocking
For unlocking Your Nokia 5220 Express music mobile follow this instructions
Warning: Do not enter any wrong unlock unlock codes on your Nokia 5220 XPRESSMUSIC mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 5220 XPRESSMUSIC without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5220 XPRESSMUSIC.
3 - Compose #pw+CODE+1#.
4 - The Nokia 5220 XPRESSMUSIC would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 5220 XPRESSMUSIC mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 5220 XPRESSMUSIC
Each Nokia 5220 XPRESSMUSIC mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia 5220 XPRESSMUSIC mobile phone at www.mobileunlocksolutions.com.
, get the instructions here about unlocking the mobile here in this site http://www.mobileunlockguide.com/ at free cost ...
To unlock your mobile get the unlock code here in this site http://www.mobileunlocksolutions.com/unlock-your-phone/rs1wp2/ at cheap cost & unlock your mobile in easier way ..
Apr 21, 2010 | Nokia 5220 XpressMusic Cellular Phone
My nokia 5220 hangs
If the memory card is full, the phone may hang. Sometimes the memory card may also develop errors and as a result, freezes the phone. In Sony Erricson phones, the phone sometimes turns off and on.
The solution to this is to format the phone, how ever all data in the memory card will be lost.
If possible, you can backup your data in a pc.
Jan 03, 2010 | Nokia 5220 XpressMusic Cellular Phone
Can't format Nokia 5220 xpress music!!
sometimes will cannot format your memory card,if any of the files present in your memory card is opened by your phone and in use. Also be aware of the fact that if you format your memory card, not only the data present in it will be wiped out but also the mobile softwares/applications installed onto your memory card.
If you couldn't format from your mobile, remove it, put it into a suitable adator, insert into the memory card reader, connect to your PC and format it. Simple...
I hope this is helpful to you
Sep 16, 2009 | Nokia 5220 XpressMusic Cellular Phone
Nokia 5220 XpressMusic Cellular Phone Logo
133 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
