Question about Olympus C-3000 Zoom Digital Camera
My C-3000 is not opening the lens...the top screen is flashing 81 (the number of pics available on the card) the front screen is blank...I've changed the batteries and flipped through the power mode dial a bunch of times...what now?
    President:
  • 2,761 Answers
If the camera hasn't recently been dropped, your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Posted on Nov 15, 2009
Ve 2512 printer can adjust machine to print 4x6photo. Print picture on 81/2 /11 only
What photo editing software program are you using? Photo dimensions are usually set in software. You can set what size paper you want in the printer setup section of the printer driver.
Aug 12, 2016 | HP LJ472UTABA Notebook - Elitebook 8460p...
My brother embroidery machine's lcd screen is blank
Hi.
On page 81 of your manual it says to adjust your LCD screen brightness.
If you can't find your manual... go here and download it.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PE_770%20%20%E2%80%93%20New!_EN_1819.PDF
Jul 13, 2012 | Brother Sewing Machines
I have a Cannon PowerShot S2 IS digital camera, about 5 years old. The LCD Monitor and Viewfinder both only show a black screen with some of the Dispay Icons across the top and bottom, and after a few...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 06, 2011 | Canon Cameras
My cannon s21s has a blank screen
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 20, 2009 | Canon Cameras
Nikon CoolPix S5. Red flashing hand. Camera/Lens on/open.
If the shutter is stucked there is no external way to release it Have to show it at camera shop
Mar 15, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Flashes, lens open, not plugged in, wont take a picture.
Its is issue of bad ccd imager and this part needs to be replaced for live view to take picture with DSC-T1.
Sony will repair your DSC-T1 free of cost as per announced scheme for ccd problem.
Click Sony CCD Support for details.
Dec 22, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Casio EXILIM EX-Z70 Screen Dead when taking pics
if shoot black photos and videos, don't work shutter (repair lens unit).
Nov 04, 2008 | Casio EXILIM ZOOM EX-Z70 Digital Camera
ORITE MODEL dV3020 BLANK VIEW FINDER
You have images on the Card- Yes? The flash works -Yes? Now you cannot take pic's is that what you mean. One of many thing- are you getting error messages? Are you sure you are getting images to the card? There may be images on the card but the screen has gone down- If you hold the camera at a slight angle can you see dim images[if yes screen back light down] If No images a connector or CCD problem. Make sure you have fresh batteries Gently squeeze the casing near the bottom of the screen- it may be a loose connector. Depending on how long you have had this -get onto the Seller or Manufacturer's web site tech support- there may be a replacement available. There will almost certainly be no repair option on this type of camera
Jun 23, 2007 | Orite MG370 Digital Camera
Olympus C-3000 Zoom Digital Camera Logo
75 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
