Question about Printronix LaserLine L1524 Printer
Our L1524 passes the diagnostics tests when we turn it on but gets stuck "Loading Fonts" with a 8344 Failed error. Ideas/Solutions?
Remove the controller boad in the back. You will see 4 SIMM'S, remove, and reset them. if this does not solve your problem, call BNL 562-688-2373 for free tech support. Ben
Posted on Feb 05, 2010
Compaq CQ 62 fails to start and fails most tests does any one know what this error code means: 98AFM9-000759-XD003G-COC603 ?
I\'m guessing from the format that it was accompanied by a blue screen with white lettering? That\'s called the Blue Screen of Death (BSOD), and it\'s not a very welcome sight among IT professionals...
Sounds like your Operating system got a bit scrambled. Could be due to a failing hard drive, wildly fluctuating voltage, or good ol\' fashioned malware/viruses. In any case, I think you\'re approaching the "factory reset" event horizon.
I would suggest a repair of the OS. The company that made your pc likely sent you an operating system restore disc or something similar, if they didn\'t they almost surely have one available. Tech support for that OEM should be able to walk you through the process of restoring your pc back to factory settings. WARNING: This will delete ALL data on the main system drive (C:). It is considered a last resort only.
If that should fail, it\'s likely the hard drive is going bad. Any SATA mobile hard drive should fit the bill, they\'re quite simple to replace too.
Jun 19, 2014 | Compaq Presario Notebook
Error on hp j4680 image on fax send report is set to on
Sir/Madam
Solution one: Print a fax test
1.Make sure the product is turned on and correctly connected to the telephone jack.
2.Make sure that there is plain white paper in the input tray.
3.On the product control panel, press the Setup button ( ).
4.Press the right arrow ( ) to select Tools , and then press OK .
5.From the Tools menu, press the right arrow ( ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
6.Review the results of the test.
·If the test lists faxing issues and solutions, the fax test failed. Follow the solutions on the printed report to troubleshoot the issue. This report is specific to your product and faxing environment, so use the solutions on the report to resolve the listed faxing issues. Repeat the Fax Test after fixing the listed faxing issues to make sure the test passes.
·If the test does not list faxing issues and solutions, the fax test passed. Continue to the next solution.
7.Try to send a fax again. If the HP fax still cannot send a fax, continue to the next solution.
In case You Still facing Problem The Visit official HP Printer website Below URL Link On:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01555948&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3692888
OR
If you Still having Problem then follow Us On:
HP Printer Support
Feb 12, 2014 | HP J4680 Office Jet All-In-One Printer
F1 error code
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a whrilpool cabrio top loading washer it flashes f1
Jul 06, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code f1/f2 --washer turns off
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*$%^
Mar 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F 2 error code
Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Oct 03, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
I have a Whirlpool Cabrio Top Loading washer model WTW6400SW1. During the past month, I have been seeing the "LD" error code ("slow to drain") but not the "F1" code during middle of the wash cycle before...
Aug 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
WTW 66005W1 cabrio, F1 error code.?????Machine error code at start and during rinse cycle. What is causing this? Any quick fix?
Jul 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio Washer Error message code F1
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$@%^
May 28, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&%$#
Oct 04, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Printronix LaserLine L1524 Printer Logo
117 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Cliff
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
