Question about HP Computers & Internet
I installed a 2.0 usb tv tuner on windows vista and got error message that the digital signature was missing and that windows could not complete the hardware installation.
    President:
  • 2,030 Answers
Go ahead and accept it, it will be fine
Posted on Nov 13, 2009
I have a Dell desktop running Windows Vista. I cannot boot up to Windows. I have a black screen with cursor error message saying: boot device available, ta 0 installed, ta 1 installed, ta 2 none, ta 3...
That message says that the hard disk was found but nothing on it can be used - Vista is completely corrupted. You will have to reinstall it using the recovery cd that came with it when you bought it.
Feb 02, 2011 | Dell Inspiron 531s Desktop Computer
Tip
Install Unsigned Drivers on Windows 7 & Vista with Driver Signature Enforcement...
Every time when we try to install any hardware drivers which are not signed by microsoft, Windows shows a warning of Unsigned driver dialog box. The reason of showing warning message is to protect the stability of your Windows operating system as such drivers are not passed in Microsoft windows driver compatibility test.
In Window XP you can still install unsigned drivers but in Windows Vista SP 1 and Windows 7 Microsoft has introduced very restricted module of driver signature enforcement which doesn’t allow us to install any incompatible unsigned drivers.
If you want to bypass or disable Unsigned Driver warning message then Here is small freeware utility Driver Signature Enforcement Overrider which allows you to install and load unsigned drivers dynamically on your Windows 7 and Vista.
Supported Operating System
1. Windows Vista 32-bit & 64 bit
2. Windows 7 32-bit & 64-bit
Download Drive Signature Enforcement Overrider 1.3b
Please Note: User Account Control (UAC) must be disabled in-order to use this tool.
on Jan 10, 2010 | Computers & Internet
Error: code0x80070017
When you install Windows 7 (or Vista) you may get the following message:
Error 0x80070017 Windows cannot copy files required for installation. These files may be corrupt or missing. Make sure all files required for installtion are available, and restart the installation Error code: 0x80070017
This can be displayed with error code 0x80070017 or error code 0x80070570 in Windows 7 or Vista
The cause is very simple and you can probably guess from the error code in the screenshot above. The cause is that Windows cannot verify the files.
Simple Solution
  • Burn or get a new copy of the disk (Burn at a slow Speed 2x and use a quality media like (Verbatim)
  • Or if you have a current Windows installation you can install from the hard drive or from a USB drive
Check out my article on installing Windows 7 using a USB Key USB-stick-from-windows-xp/">Install Windows 7 from USB Drive
Dec 25, 2010 | Computers & Internet
Sabrent TV Tuner model TV-USBHD, TV Player not working for Win 7
CAN SOMEBODY HELP ME WITH THE USBHD  SABRENT TV TUNER SERIAL? ALGUIEN ME PUEDE AYUDAR CON EL NUMERO DE SERIE DE USBHD SABRENT TV TUNER?
Jun 01, 2010 | Televison & Video
Computer advises NOT to install as not Windows
Hi. Thanks for your question
Digital signature is a part of file added to it for security reasons. Although not every manufacturer decides to digitally sign it with microsoft. Sometimes new signatures are included in windows updates removing mysterious information about signature . As long as you know were your file comes from you are pretty safe to ignore the message from windows. Just click next and you should be just fine. If you would like to know more about this subject. This is a link to Microsoft's website "what is digital signature" - http://windows.microsoft.com/en-US/windows-vista/What-is-a-digital-signature Hope this clarified your view. Please let us know if this was helpful.
May 01, 2010 | DekCell EasyCap USB 20 Video Capture...
Arcsoft VideoImpression
This is windows Vista? What have you changed since it started crashing? The most common cause of crashing programs like this are the result of a graphics driver.
Mar 07, 2017 | Arcsoft VideoImpression 2 for PC
Tech-Com failed to initialize the capture device on Vista
I don't know if you have already solved this problem. Here is a solution I came across in one of the sites.
I too had a similar kind of problem... Now, the problem initializing the capture device was solved but still I am unable to view the TV channels.
Nov 24, 2008 | Sabrent TV Tuner / Video Capture Box USB...
Vista 64 bit OS did not accept the driver for the USB to DB25 parallel cable. Message says the driver must have a digital signature.
Until a new version for 64-bit Vista comes out, there are two workarounds:
1. Boot Windows holding down the F8 key and select “Disable driver signature enforcement”. This will let you install unsigned drivers for that session.
2. Run cmd.exe as an administrator (right-click it to do this) and then type:
bcdedit -set loadoptions DDISABLE_INTEGRITY_CHECKS
post again if you have problems.--------- Please rate this solution.---------
Oct 11, 2008 | Computers & Internet
Vista transformation
first of all uninstall your antivirus which you had downloaded on your computer
May 07, 2008 | Microsoft Windows XP Professional With...
I can't install software or USB drivers in Windows 2000 or Windows NT.
If you see an error message or the software doesn't install correctly, you may not have software installation privileges. Contact your System Administrator. In Windows 2000, do not select Block under Control Panel > System > Hardware > Driver Signing, or your driver installation will not be completed. Select Ignore or Warn instead. In Windows 2000, if you see a "Digital Signature Not Found" screen, click Yes to continue with the installation. If you select No, your camera's USB installation won't be completed.
Sep 12, 2005 | Epson PhotoPC 3000Z Digital Camera
Computers & Internet Logo
16 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
