Question about Photography
Tripod head I cant get the head for my tripod to unscrew off the tripod itself?
  • Anonymous May 01, 2009
    can't unscrew my mark 7g please help
  • 24 Answers
Not all tripod heads will come off the tripod. some are made on the tripod so if you remove the head, you will have two non functional parts.
Posted on Jan 30, 2009
2 Suggested Answers
SOURCE: How to Unscrew SLIK tripod head from the rest of tripod?
I found the info on the following site worked for a Slik 35D tripod, and I expect it would work for most tripods. http://eit.tamu.edu/TDD/tddtripo.htm
Posted on Sep 12, 2007
How to remove the head of a Giottos camera tripod
Most tripods have a 1/4" thread attached to the centre column, which then screws into the base of the head (some may have a 3/8" thread, but the principle is the same).
Grasp the head firmly in one hand, the shaft firmly in the other, and rotate the head counter clockwise to remove the old head. If it has been in situ for some time, it may be stiff to rotate.
Once you have removed the old head, lubricate the threads on the centre column, then attach the new head, rotating this one clockwise.
If the old head will not unscrew under firm manual pressure, remove the centre column and place in a vice, packing it with wooden battens to protect it. Then attempt to unscrew the head, using a mole grip or similar if necessary.
Sep 12, 2016 | Giottos Photography
Whilst trying toromove the 168 ball head from my manfrotto art055 tripod the head became loose on the central column. How can I fix it back
There is a video at: http://bogentripodparts.com/repairs.htm
the one on the right shows you. It is usually remove the 3 screws and a little force to unscrew the head.
Apr 02, 2014 | Manfrotto Photography
Remove 3130 head from 3021 tripod
The head is mounted on the base by a 3/8" screw. The head is held in place by 3 set screws in the base. Turn tripod upside down, loosen (or if completely removed, do not lose them) those 3 screws, turn tripod rightside up and unscrew head from tripod. If unable to turn head, loosen screws a little more. If scres are removed and heaf still not comeing off, Use pipe wrench or afjustable pliers wrapped in cloth to preven maring and loosen. (looking from top, or birds eye view, turn head counter-clockwise
Apr 23, 2011 | Bogen Manfrotto 3130 Micro Fluid QR Head...
Tripod head
If the head is loose on the tripod follow these instructions:
There are three small set screw (grub screws) that are under the head, net to the center column. You will have to raise the center column and look under the head. These are slotted screw heads and a small to medium screwdriver should work. You don ot have to remove the grub screws completely, but you should back them out at least half way. The head will unscrew off the center column. The gray part below the head is half the head attachment and half the center column end plate so it should separate in the middle line between the two.
If screws came out elsewhere, we will need to know the model number of the head that came apart.
Jun 01, 2010 | Manfrotto (Distributed by Bogen) 055XDB...
Bogen tripod head stuck on tripod.
May 12, 2010 | Photography
How to remove pan head from velbon 530, it feels very tight
I have the Hakuba HG-503MX which came with basically the same pan head you have already attached to the center column. First remove the center column from the tripod, with the pan head attached. Tighten the knob that prevents the pan head unit from rotating 360 degrees on the center column and gripping the head with one a hand and the center column near the plastic plate firmly twisting the head counter clockwise. The pan head will unscrew from the plastic plate which sits on top of the center column, given enough force. My pan head was also very tightly screwed onto the shaft, since it came already attached to the tripod. Hope this is helpful.
Aug 10, 2009 | Velbon EL Carmagne 530 Tripod
Head will not tighten on AF2100 Pistol grip
one of the treads in the tripodas head is broken try unscrewing the grip the other way to remove it, then examine the grip, if one of the threads on the part of the grip that screws in to the head, is broken then you might be able to get a new grip, and that might work, but there might also be damaged threads inside the tripod head, in which case you neet to replace the head if you can, but if you cant, then I do not think that you can repair that tripod
Aug 01, 2009 | Slik PRO 700 DX Tripod
701RC2 going on 745B sticks
Hey SkipHall,
As in most Manfrotto tripods this tripod should have 3 set screws underneath the head mounting surface. Unscrew these set screws and you should be able to unscrew the current head off the tripod by holding the center column and turning the head counter clockwise. Installation of the new head should be the reverse. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 16, 2008 | Manfrotto 745MF3 Tripod
Below the tripod head you will see what looks like a "sandwich" of two chromed pieces of metal.  The lower one is the top of the tripod's center column.  The upper one is the bottom of the tripod head. Using wrenches or other tools, unscrew the upper one counterclockwise to separate it from the lower one. There is a 1/4" threaded stud which holds them together.
If you plan on replacing the head with a pro head like a Manfrotto, you will need a reducing bushing.  Most heads expect a 3/8" stud, and this tripod's thread is a standard 1/4" stud. The adapters are available through Wolf, Adorama, B&H, and the like.
Sep 03, 2007 | Slik 505QF Tripod
Photography Logo
1,287 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Tony
Are you a Photography Expert? Answer questions, earn points and help others
