Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
My computer says that thay is no a sound device installed
  • Stan
    Stan May 11, 2010
    Did it just stop working, or you have freshly installed the system and need the drivers?
  • 187 Answers
Anytime a peripheral (speakers) doesn't work, start by unplugging it. Turn the computer on with it unplugged. Shut the computer down again. Plug in the speaker(s). Turn the computer back on. If MS "finds new hardware," follow the prompts to reinstall. If nothing happens, update your drivers on Microsoft's update site. If that doesn't work:
Go to start, then Control panel, and then click on sounds and devices. If your screen looks different than the pic below, go to left of your screen and click on classic view. Double click on Sounds Icon. Click the hardware tab. Highlight each device and click properties. It will say if the device is working properly.
Go down the list of devices. If you find one that shows a problem, Check the driver. If it was newly installed, roll back the driver. You can also look for a new one online. If that doesn't show anything, go to system in the (control panel too). Click on device manager, then the + next to Sound/video Controllers. Look for a red x, indicating malfunction. Double click on anything with a red X and check the drivers, especially recently changed ones. Update drivers and follow troubleshooters. You can do the same with Accessories, where the speakers will be listed in device manager. Last resort is to right click on the offender and uninstall, then restart. Hope that Windows will identify the hardware and reinstall it with the proper drivers. If not, go back to Microsoft and search for optional device drivers.
Posted on Nov 14, 2009
  • wire12me Nov 15, 2009
    OOOPS. I meant to say that you should look for an exclamation point next to devices. That means they are malfunctioning in some way. The X means it is disabled. sorry. Anyway, like most things computer, there is more than one way to do things. If the above seems too hard you can try following the trouble shooting provided in help and support for Microsoft. Again, sorry for any confusion I caused.
No sound in my computer
In compaq computers its the major problem thay always gone sound drivers u should make a cd or in pendrive setup for sound drivers download sound drivers realtek ac97 for compaq it will works download here--
http://www.realtek.com/downloads/downloadsView.aspx?Langid=1&PNid=14&PFid=23&Level=4&Conn=3&DownTypeID=3&GetDown=false
Aug 24, 2013 | Compaq Presario sr1403wm AMD Sempron 3000+...
Got a problem with my speakers thay are plugd in but there is no sound comming out off them
If they are powered speakers please ensure that both the power cable and the audio cable are plugged in. If the speakers have a volume knob try slowly turning it up while you play music. If nothing still happens, try plugging the audio (green usually) into another audio device (E.g. iPod) and play music from there to test the speakers.
Jul 28, 2011 | Audio Players & Recorders
My speakers work fine. I don' t know why thay keep turning. i have the internet. How do i keep my speakers on all the the
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 16, 2011 | Audio Players & Recorders
I try to install windos 7, but thay ask Primary IDE channel for HDD Samsung SP0411N , I cant find this driver. Janis
hello, in order to install windows you need a bootable dvd, and you need to change boot priority in the bios menu to dvd drive as the first boot device, and you need to plug Hard drive to the primary IDE port in the motherboard,
Feb 16, 2011 | Samsung Computers & Internet
How to i instal sound drive for my pc?
Hello
1. Power on your computer. Ensure that there is a sound device installed on your computer. You can locate your sound device by right clicking on "My Computer." Click "Properties." Select "Device Manager." Click on "Sound." Your sound device should be listed. If there is no sound device listed, you will have to purchase and install a sound device before proceeding.
2. Insert the CD or floppy disk that contains the drivers for your sound device into your computer's CD-ROM or floppy disk drive. If you do not have the CD or floppy disk that contains the sound device drivers, there are websites such as Driver Guide and NoDevice that will allow you to download the drivers online for free.
3. Click on "Install Drivers." The sound device drivers will then be installed onto your computer. It may be necessary to restart your computer once the installation is complete.
4. Open your media player and play an audio file to ensure that your sound device drivers were installed successfully.
THANK YOU
Jan 28, 2011 | Microsoft Windows XP Professional for PC
I haveMicrosoft Windows XP Professional on my computer and in the last few day then i put my computer on its say windows installer can find why is thay
I am assuming your mean it cannot find the installation of windows...
it sounds like the boot record has become corrupted.
With the install disk in the cd rom, load your pc and choose to Boot from CD - you may need to go into the BIOS to change the CD to be your first boot device (you get to the BIOS by pressing F10 on start up)
When Windows goes through its blue loading screen follow the screen prompts until you can see the option to "Press R to repair a windows installation".
Press R
When the DOS prompt appears on the screen choose the Windows installation you wish to repair (usually 1 and press ENTER)
When prompted for the administrator password either enter the password you have specified or if you have never set a password press ENTER
Type:
FIXMBR
Choose Yes
Press Enter
Reboot yuour PC.
Hope this helps...
If not please provide the exact error message in a post
Feb 22, 2010 | Microsoft Windows XP Professional With...
When i play age of mythology every thing is fine but when people talk i cant hear there voice and when the talking person stops talking it doesnt continue to the next peron that is sepost to talk and when...
Maybe the Game doesn't contains people talking voices,but you're pretty sure just reinstall it i mean fully reinstall (you can keep the save game folder just search in where the game installed);)hope it works!
Feb 05, 2010 | Microsoft Video Game Consoles & Games
No sound device on my computer
go to the website of the computer/motherboard's manufacturer. thay will have audio drivers/codecs there for your model.
Oct 09, 2009 | Intel Motherboard
Windows Media Player cannot play the file because there is a problem with your sound device. There might not be a sound device installed on your computer, it might be in use by another program, or it might...
You might encounter this error message for one of the following reasons:
  • Your sound device is in use by another program. Quit other programs that might be using your sound device, and then try to play the file again.
  • Your sound device requires an updated driver. To determine if an updated driver is available, see Windows Update, or see the sound device manufacturer's Web site.
  • The selected sound device does not support Secure Audio Path (SAP). If you have multiple sound devices installed on your computer, try using a different one.
  • Your sound device is not functioning properly. To troubleshoot the problem, see Windows Help and Support or refer to your sound device's documentation.
  • You do not have a sound device installed on your computer. Install a sound device (such as a sound card), and then try to play the file again. If you can't install a sound device in your computer, you might be able to resolve the problem by attaching USB-based headphones or USB-based speakers to your computer instead.
SOURCES- WWW.MICROSOFT.COM
Apr 26, 2009 | Razer BARRACUDA AC-1GAMING SOUNDCARD 7.1...
Power problem
Are you movimg the speakers when thay go off ??? Are you on mains power or battery Do thay go off when loud sound is on???
Jun 04, 2007 | Altec Lansing ACS 251 Computer Speakers
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
35 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
