Question about Hand Tools
Trying to figure out how to change batteries in a energizer hardcase lantern tuf4d1.
What bottom section? I also can't figure out how to change the batteries.
Posted on Dec 25, 2009
  • nellie_007 Sep 05, 2010
    The instructions that are listed to replace the batteries on the other post for this flashlight are incorrect for this particular model - I think those are for the Energizer Hard Case flashlights, which are smaller
  • 288 Answers
The bottom section turns and the upper section with the handle is just a shell. these are very good lights
Posted on Dec 19, 2009
Energizer WeatherReady lantern came with batteries; worked once. Can't unscrew the top to change batteries. Possible battery corrosion? Is there a workaround fix?
Mix water and baking soda together until baking soda is dissolved.
Take a small baking pan or a bowel with a flat bottom and place the lantern in a vertical position, bottom down and slowly pour in the baking soda solution so the solution is 1/4" above the battery lid so the solution can soak into the threads of the lid. Let sit overnight. Next morning, slowly lift the lantern out of the solution without tipping it keeping it vertical, and slowly unscrew the lid over the sink. Keep in mind there will be solution inside the lantern when you first open it, so be careful not to tip it until you dry out the inside.
Aug 31, 2016 | Energizer Camping, Backpacking & Hiking
How do I get to the bulb?
Unscrew the head assembly. In the back of the assembly is a small plastic nut. Unscrew this and the bulb should fall out into your hand.
Nov 01, 2014 | Energizer Eveready Utility Lantern Uses 6V...
Wheres the expiration date on a eveready D battery?
Printed on the side or embossed on the bottom of the cell.
Apr 25, 2012 | Energizer Eveready TUF4D1E 4D Cell Lantern
I can't figure how to change the battery on this hardcase lantern took off the rubber surrounding the lantern face, but nothing else seems to come off without unscrewing, But seems like those sre rivits...
I've owned this flashlight for years. In the comment above, ignore the instruction to remove the rubber casing around the lamp area. Simply grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Apr 05, 2011 | Energizer Eveready TUF4D1E 4D Cell Lantern
This still doesn't help. how to you get the rubber off what are flanges. can you show a picture
I've owned this flashlight for years. Ignore the instruction to remove the rubber casing around the lamp area. Simply grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Mar 05, 2011 | Energizer Eveready TUF4D1E 4D Cell Lantern
Don't know how to replace the batteries.
I've owned this flashlight for years.Grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Jan 11, 2011 | Energizer Eveready TUF4D1E 4D Cell Lantern
My TUF4D1 flashlight does not have a twistoff cap opposiite the light. Unless I have to take out screws?? I still can not find out how to get into the battery compartment of this flashlight?? any body...
The front outer rubber cover is removeable. Once you take it off with your fingers, the front unscrews revealing a two piece battery case. Squeeze the top flanges together and lift out, then the battery case shown in the box just lifts out.
Oct 02, 2010 | Energizer Eveready TUF4D1E 4D Cell Lantern
Replacing batteries on Energizer Hard Case Lantern
If you have the Energizer Hard Case Lantern TUF4D1, simply grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Jul 05, 2010 | Energizer Eveready TUF4D1E 4D Cell Lantern
How to change the batteries on the TUF4D1
Feb 08, 2010 | Energizer Camping, Backpacking & Hiking
Hand Tools Logo
277 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
