Question about HP DVD DRIVE DVD Drive
It is not showing up at all in (my computer). it open and will close, but doesn't work
    President:
  • 414 Answers
Do it only if u r a professional..
i gotta know: is ur drive pata/sata and the device make n model..
assuming that ur drive is pata, n u r a professional n aware of bios/cmos setup utility handling..!!
open up ur system cabinet and see if all the data cables n jumper settings at the back of the drives (master/slave selection)..itz most important..!!
however, at the bootup (0.29sec) start pressing briskly the key to enter cmos utility or bios setup (eg. F1/F2/F10/Del as applicable)..glance in the standard settings if r detected individually..change the 'Mode' if m/b is hybrid type(both SATA+PATA) : Native/Compatible/Enhanced (as applicable)..
see if ur device needs any additional driver or not, if so try downloading..
also try checking itz data cable for loose or faulty..
above all explanation is applicable only if itz not being detected by the m/b or system..(not for reading or writing problem)..
contact ur system admin/vendor....
Posted on Nov 13, 2009
This information is excellent but if you get to the point where you can't find the upper and lower filters and you go to your BIOS and that don't help and yet your DVD/CD ROM still physically works but the computer doesn't want to acknowledge it then try this it is FM......Make sure you have a DVD ready..... goto your Control Panel....System.....Device Manager.....place Your DVD in the Driver then Right Click on... Disk Drives....Click.... Scan For Hardware Changes...........It Worked for me when none of these things worked like I said FM....
Posted on Dec 26, 2009
    Sergeant:
  • 228 Answers
Go into device manager,accesible from start button .control panel.system.select device manager look to see if drive is in list if it is delete entry and reeboot pc it should find your drive and reinstall drivers
Dometic rm2652. Inside of fresh food section is down to 20 degrees, everything froze
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
Since this unit has no compressor and uses an ammonia mix and heat to cool, it isn't your standard household refrigerator. So be careful working around the coils.
The most common failure for your problem description is the thermoster followed closely by the lower control board. But we have also been finding more and more corrosion buildup on the terminals that is keeping the unit from functioning correctly. Suggest you ohm check the thermoster to see if it has opened. If that shows an open, then replace. If that doesn't work, then take the lower control board out and clean the terminals and connectors with a scouring pad following by the #2 pencil eraser cleaning of connectors. If that doesn't correct it, then replace the lower control board.
Sep 11, 2011 | Dometic RM2652 Refrigerator
Can't find CD icon is missing from one computer
Windows Key-E will bring up windows explorer which should show your list of available drives.
If this doesn't show your CD drive then try removing CD from drive. Does the disc tray open? If so then reboot system without disc and try the above method to find cd-drive.
If this doesn't work you may need to involve more hands on trouble-shooting.
Thanks
Jul 22, 2011 | Staples 2x1 USB Peripheral Switch
Sharp microwave oven works (lights, turntable etc) but doesn't heat.
Try to replace magnetron and diode usualy that's the most problem of microwave hope that works
May 27, 2011 | Microwave Ovens
Sigma BC 500 doesn't show the speed - it shows only 0 all the time.
The magnet and the sensor must be close to each other. It's in the instructions.
May 26, 2011 | Sigma Bc 906 Computer
My yahoo messenger is showing every time (not responding) how i can solve this problem its make me realy crazy
try to open your account in your messenger...wait until its finished loading..once its done loading and something had open ..you close it properly..try going through with your chatting..if it still doesn't work, the problem is the messenger itself..try to uninstall it..and redo the procedure in installing it again..thanks..
May 25, 2011 | Yahoo Messenger
My autocad 2011 is not opening . it says the application was unable to start correctly (oxc0150002) click ok to close the application . i use google chrome and desktop . Win 7 ultimate installed .
Try this first:
Uninstall and Reinstall the Visual C++ 2005 and 2008 redistributables. Restart the computer and try it again.
If that doesn't work:
Try using the repair option on the install software.
Uninstall autocad completely, restart the comp, reinstall autocad.
Also what version of 2011 do you have? Student Edition or just the regular one?
May 04, 2011 | Computers & Internet
No pictures will load up on any web site I go to... videos will
Ok try this...(there are as few things it could be but try this first)
1) Open "internet options"
2) And on the "general" tab click on "accessibility" and then make sure "NONE" of the four check boxes have checks in them.
3) Then click ok and ok again to close internet options
4) And then close all browser windows
5) And then open a new web page and see if it works now..
If that doesn’t help than let me know and ill tell you some more things to try
(But I have found that little setting to work most of the time)
Dec 06, 2008 | Computers & Internet
Cannot open file
Sir, I was working in a PM file. Computer shut down before closing the file. While opening the file Showing " Cannot open file. closing publication, some work may be lost. open the previously saved publication (8009:20551) "Continue" While clicking continue not opening the previously saved file.
Jul 24, 2008 | Adobe PageMaker V7.0.2 for PC
Dvd player
First, make sure the DVD Recorder is completely disconnected from the Main Supply.
Then, if you look on the base of the unit, (just underneath the front of the Disc Insert/Eject Tray), there is a small slot, (approx 25 x 8mm), in which you can see a small, white, plastic lever probably situated near the right-hand side of the slot.
Then move this lever gently to the left, and then turn it on and the tray opens by pushing the button.
Jan 14, 2008 | Televison & Video
Computers & Internet Logo
430 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
