Question about Craftsman Garden
How do the gas lines run from the primer bulb to the carb through the gas tank to the filter. (there's a small and a larger line entering the gas tank)
MrScary66613
  • 1990 Answers
SOURCE: Relacing fuel lines in a weedeater blower/vac
Sounds Correct on this End.
Posted on Jan 23, 2009
#1 Taper
  • 1040 Answers
SOURCE: 32 cc Craftsman (Poulan) gas line replacement
Yes, you are right. The larger line goes to the primer bulb and only goes into the tank about an inch. The coupling just keeps the line from pulling out of the tank. The smaller line goes to the carb. This line must rest comfortably on the bottom of the tank with the filter attached to the end.
Jim
Posted on Jun 08, 2009
  • 277 Answers
SOURCE: Getting my new fuel lines in correctly from gas
on weedeaters,chain saws. most are the same.
line with little filter in gas tank goes to carb. line out of carb to primer bulb
line from primer bulb to gas tank
Posted on Jun 24, 2010
roadtech7
  • 293 Answers
SOURCE: I have a model 2375LE
Yes you have the lines crossed, This is an easy fix.
The Line with the filter goes to the primer, and the line coming from the primer to the brass upper fitting on the carburetor, then the lower plastic fitting goes back to the tank.
Hope this helps
Posted on Nov 13, 2010
aquaman987
  • 927 Answers
SOURCE: wont'tay running. changed all gas
Could the primer bulb be broken, allowing air to enter the carb?
Posted on Feb 01, 2011
Where does the second gas line connect to on a mcculloch m32em leaf blower?
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Feb 22, 2011 | McCulloch 26cc Gas Backpack Blower Dual...
HOW TO ROUTE NEW GAS LINES ON RYOBI31CC,15:,CURVED SHAFT 700R,,,THANK YOU CHARLIE
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for 1/2" or so.
Feb 09, 2011 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Gas lines crumbled and don't know how to route new lines correctly
Dec 12, 2010 | Weedeater Gas Blower
Hi, I have a ryobi BC30 brush cutter my fuel lines inside my fuel tank broke so I don't know which one go where right now the filter plugs into the bottom of carb and return and another short hose go to...
Nov 06, 2010 | Ryobi Garden
I HAVE A HUSQVARNA MONDO LINE TRIMMER.WHERE DO THE FUEL LINES CONNECT.THE MACHINE HAS A WALBRO CARB.
For a machine with a remote primer bulb: The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. For a machine with the purge/primer bulb on top of the carb: The small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Oct 25, 2010 | Husqvarna 28cc Gas Line Trimmer
No gas getting from the gas tank to the carb. replaced hoses and filter already. can not even draw gas with primer button.
You either need a new primer bulb (leaking air) or you have the fuel lines routed wrong. Here is the correct fuel line routing just in case:
Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb.If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank
Oct 04, 2010 | Craftsman Convertible 25cc. Gas Line...
How to repair the gas line. which line to go to? model# 358.791050
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it possibly and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body opposite bulb end to small hole in tank with filter. This is the carb supply line. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. This is just the fuel return line.
Oct 02, 2010 | Craftsman 25cc Gas Line Trimmer
Fuel lines rotted...need to know how they connect to gas tank/primer/and carb
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Please vote on this solution.
Sep 04, 2010 | Craftsman 25cc Gas Line Trimmer
Need fuel line routing on 32cc gas trimmer
This is an ongoing issue for users, and rightfully so .On your machine.. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
Sep 03, 2010 | Craftsman 25cc Gas Line Trimmer
Replace fuel lines bubble will not prime carb. which line receives the filter?
Aug 22, 2010 | Craftsman 25cc Gas Line Trimmer
Garden Logo
65 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
