Question about Evesham Axis 64 3200+ Choice (AXIS643200+CHMAR04) PC Desktop
On boot up 1st black screen with boot up options safe mode normal etc then windows xp logo and loading bars ,briefly then repeats cycle. if i get to boot from cd it thinks for a minute then repeats recovery disc and /or windows xp does not work
    President:
  • 2,600 Answers
Follow this fix and see if it corrects the problem.....
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Nov 13, 2009
  • Evesham Master
  • 4,924 Answers
Ok ...I believe that the ram memory is doing the trick on you ...replace it and it will work ...its not dead ..cause in that case it would not boot at all ..but its almost there ..
My gx60 isn't bootin up..it says loading project..how do I fix this
From your photo, it looks like windows XP has fully loaded. I would assume the "Loading Project" is from a program, not windows. I would boot up in safe mode and try to do a system restore to when your computer was working. Here's how to boot up in safe mode:
* Press F8 key repeatedly while booting up, right before windows begins to load up. Black screen with white letters usually.
* You should get a few options. Select boot in safe mode with networking.
* once XP loads, Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
Feb 09, 2015 | Computers & Internet
How do i start in safe mode
  • If computer is on then turn off the computer and again turn on your computer and press the F8 key repeatedly from your keyboard. You must press F8 before the Windows logo appears. It will display the Advanced Boot Options screen.
  • From Advanced Boot Options screen, choose Safe Mode option then press Enter.
  • It will open your windows in safe mode.
Aug 24, 2012 | Microsoft Windows XP Home Edition English...
I have a Dell Inspiron 2650 laptop with operating system windows xp profesional. That happened after I downloaded a software called orbit downloadable. I went into my computer and clicked start,...
try to run windows f12 boot format it should be runing on f2 this way you can go straight to problem then asked to run windows again after you restart .
Feb 04, 2011 | Dell Inspiron 2650 Notebook
Starting problem
Immediately after seeing the Dell logo, keep tapping the 'F8' key,
until you see a "menu" (white text over a black background)
giving "startup" options for Windows XP.
Select "Safe Mode" and see if you can start in that mode.
Then, use "System Restore" to go "back" in time, to the most-recent checkpoint (date/time) where your computer _DID_ work.
Restore to that point, and restart.
Jul 17, 2010 | Dell Inspiron 1525 Notebook
Hello I wonder if you can help. When we switch
Had a similar problem like this several times. Try choosing safe mode. Safe mode will load the required drivers. After safe mode finishes the loading process, restart your computer and choose to start windows normally. The problem you mention usually happens when the computer is turned off without using normal shut down procedures. Also happens when you have a sudden power outage.
Oct 24, 2009 | Computers & Internet
Windows xp will not load on my computer....
It could be your hard drive problem. Which I called it, "Crash." I would suggest you try to format the hard drive and reload the operation system with your installation CD.
Jul 22, 2009 | Acer Aspire™ T180 PC Desktop
The screen is frozen at the Window XP screen
See if you can boot in safe mode. Turn on computer and repeatedly press F5, select the safe mode option if you can get in then the problem might be you have too many start up programs trying to load when windows start. Find out which ones you do not need and prevent them from starting up when you log on.
Mar 03, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Inspiron B130 won't boot
plz try to boot through safe mode, if you can then log in normally.
if you cant boot from safe mode then you have to reload or repair your os.
Dec 23, 2008 | Dell Inspiron B130 Notebook
Trying to restore dell 4400 and cannot get to a dell screen for f-12
If you boot from the XP CD and choose the first repair option it will load to a DOS prompt. From there type "chkdsk /r" and press enter. This will run checkdisk on your hard drive and repair any problems that it finds. It will take 45 minutes or more depending on the size of your drive. Once it finishes type exit to reboot and remove the CD. Your computer should boot normally.
Oct 30, 2008 | Dell Dimension 4400 PC Desktop
Compaq armada e500 boot up
Try tapping the F5 or F8 key (could be either one) right after you power up. This should take you to a short text message with a couple of choices to continue; you'll find the Safe Mode option there which will prevent the continuation of the unsuccessful boot routine. If you can reach the Safe Mode, run Restore and go back to an earlier point in time, you may have to go back several times because if you have picked up some kind of malware, it may have been backed up with everything else.  Unless it is a really smart bug, you might be able to circumvent it.
Aug 22, 2008 | Compaq Armada E500 Notebook
Evesham Axis 64 3200+ Choice (AXIS643200+CHMAR04) PC Desktop Logo
71 people viewed this question
Top Evesham Computers & Internet Experts
Lakshman P
Anwarul Haque
Anwarul Haque
Are you an Evesham Computer and Internet Expert? Answer questions, earn points and help others
