Question about Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
The on/off buttons are not working anymore? Any
The on/off buttons are not working anymore? Any ideas? I can't get the cover off to see inside.
    Sniper:
  • 84 Answers
With your hose plugged into the vacuum, check your cord at the outlet, is it securely plugged in? There are no signs of cord damage? If so, you will need to take it to the shop,but it probably just has the wrong sequence in the power buttons.. turn on the main unit switch then turn on the hose switch to the canister, if no power, then hit the switch on the machine again, it should power up, if it does not, open up the bag compartment, and shut it again, making sure that the bag is aligned inside and the cover is closed tightly. Did this fixya? Let me know. You may need to contact electrolux for a replacement hose. they are really good about warranty service and will send yu a new hose at no charge if they determine that is the problem. Here is some contact info. Thanks, Rene(the Vacuum Doctor)
http://smallappliances.electroluxusa.com/node47.asp
Posted on Nov 13, 2009
I have a bissell pro heat carpet cleaner. It is model 25a3 and about 1 year old. no water comes out when I press the trigger to clean the floor. The tools attachment works fine, any ideas?
If you are getting water from the tool. But not at the floor the most likely problem is the heater is clogged with coagulated soap or minerals. You will need to separate the upper handle to get to the heater. Insure the machine is unplugged. Remove the cover from the heater making sure you don't lose the little gaskets on each screw. Clean the channels inside the heater and put the cover back on. Be aware of how you are Taking it apart so you will know how to reassemble it.
Oct 31, 2013 | Bissell 25A3 Proheat Upright Deep Heated...
Xl2600hhvacuum won't stand alone anymore, what is broken, is it a spring or some kind of catch missing
The detent that is mounted to the inside of the base cover is not working either because the screw holding has broken off or it is worn out. You could also have a worn out fan housing since that is what the detent catches to make it stand up. If the screw is broken off the only way to repair it is to replace the housing. Hope this helps.
Jul 15, 2013 | Oreck XL2600HH Upright Vacuum Cleaner...
The on off button is not working anymore on my shark garment steamer anymore
The button itself may be bad. The plug end of the power cord may have a broken wire near the plug--repair with a common replacement plug from a home center or hardware store. An AC voltmeter would be a great help in finding the problem instead of just replacing parts until it works. Good luck!
Sep 26, 2010 | Vacuums
The main brushes do not seem to be working very good anymore it clrans but doesn't do a good job
You will need to remove the gears cover from the cleaning head module and remove all debris found inside.
Aug 20, 2010 | iRobot 4150 Roomba Vacuum
When I press the botton next to power button in order to activate the bruch for carpet cleaning. The brush does not spin anymore.
HighnTools posted this solution a while ago. This might be related to your problem: I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
May 21, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Roller brush will not turn on Eureka "The Boss Power Plus" 12 amp
Depending on the model there will be a couple of screws on the top plastic cover. The cover lifts off and the belt is then serviceable. On some models you will need to remove some parts on the bottom too to get the roller out.
In any case just look for screws that hold the covers on and explore a bit. You can't break anything.
Jul 30, 2009 | Eureka Boss SuperLite Bagless Upright...
Spin brush not working anymore.
Is the shaft still on the brush block, if it broke off, then replace the block. if it is ok, then the turbine(#13) is most likely the problem. It is what drives the brushs. You may be able to take the turbine apart and clean it, if that doesn't work the replace it.
Mar 15, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Bissell pro heat cleaner
This could be due to dried out soap in the works below the dispenser. Try cleaning the hole, putting plain water in the soap dispenser to clean it out further. You could just put some soap in with the water. Be sure to run lots of rinse water through afterward to clean out the heating unit.
Aug 18, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Kenmore 33721 does not start
Same thing happened to me. After taking the cover off I noticed a wiring diagram on the inside cover. There is a fuse between the on/off button and the motor, sure enough the fuse had blown. There is no mention of a fuse in the manual! The vacuum works great again.
Apr 23, 2007 | Kenmore 33721 Upright Vacuum
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum Logo
367 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
