Question about HP f2105 21" LCD Monitor
2105 monitor turns black when starting windows xp You see the startup screen short, then the desktop, but also turns black.
  • HP Master
  • 4,924 Answers
Ok ..its a matter of settings ...I would try to hook it up in anpther monitor to see if it behaving the same ...I suspect that you played with the color modes and another settings and now it does that ...if it is doing the same in another one ...you have to reinstall it ...( repair ...or better install without formating to evoid data lost ) cause it is a matter of the driver setting in color and image management and ..you can not rol back without seing what is going on ...or even at least reinstall the driver ...
Posted on Nov 13, 2009
My window xp has no monitor
Is the screen black from the moment you turn your PC on? Or do you see the BIOS splash screen and Windows loading, but when Windows starts it goes black?
Jan 21, 2013 | Computers & Internet
When starting the computer the screen stays black. Only the green light is on. It gives short the bios start up screen, after that it's only blach.
windows cant start up ...try to press F8 kay before startup to open in safe mode and if that cant be you will need to reinstall or repair your windows.
let me know more about
techbelkin
Jan 08, 2011 | BenQ FP937S 19" LCD Monitor
Monitor screen is almost completely black - i can only see the desktop very slightly. is there a light bulb that can be replaced to fix this?
Change the display resolution in Windows To change the display resolution to the highest resolution, use the following actions.
  • In Windows 7 , click Start , click Control Panel , find the Appearance and Personalization area , and click Adjust Screen Resolution . Move the slider bar until the highest resolution for the monitor is set, and click OK .
  • In Windows Vista , click Start , click Control Panel , find the Appearance and Personalization area , and click Adjust Screen Resolution . Move the slider bar until the highest resolution for the monitor is set, and click OK .
  • In Windows XP , click Start , click Settings , and then click Control Panel . Double-click the Display icon, and select the Settings tab. Move the slider bar until the highest resolution is set, and click OK .
If the screen is still blurry, please contact an HP support technician for further assistance.
Also see To troubleshoot this problem, make sure the AC adapter is connected. For specific steps, see HP Notebook PCs - Troubleshooting Black Screen Displays with No Error Messages During Startup or Boot .
Nov 02, 2010 | HP G60-127NR Notebook
Dell Dimension 3000 Video problem
There may be a problem with your windows installation. Search Google for Hirens boot CD, it is a free download and should contain a live XP installation. When you turn on the computer tap the appropriate button to reach the boot menu, then insert the CD and select your CD drive. Once booted it should display a live XP.
Alternatively you may have your monitor set to an incompatible resolution. If tapping F8 won't display the advanced boot menu then try finding an auto setup on your monitor or change the resolution using the monitors controls. If the advanced boot menu does display then select low resolution mode.
Hope this helps,
www.PuterCare.com
Jul 02, 2010 | Dell Dimension 3000 PC Desktop
Windows xp will not load on my computer....
It could be your hard drive problem. Which I called it, "Crash." I would suggest you try to format the hard drive and reload the operation system with your installation CD.
Jul 22, 2009 | Acer Aspire™ T180 PC Desktop
No sreen after startup window
Boot your system into safe mode and reduce the resolution to your monitor. It is set to high and blacksout because of memory. Besure to use F8 in order to enter safe mode before windows start.
Good Luck
Fehdi
Mar 28, 2009 | Dell Computers & Internet
Dell desktop running windows XP
You should be left-clicking when the option for safe mode comes up...
Dec 15, 2008 | Dell Inspiron 8500 Notebook
No Signal when desktop wants to load
It does not hate that monitor. I believe the problem is in the settings on your video. Your monitor cannot display them. You will most likely need to start your computer in safe mode and change the display settings on your video card or, alternatively, download updated video drivers. Also, if you can't get Windows to start in normal or safe mode, one of the options you get when you press F8 on startup is to start in VGA mode. That will get you in so you can tweak your settings, which are probably set to a resolution too high for your monitor.
Sep 11, 2008 | ViewSonic VA1916w LCD Monitor
Blank Monitor
Start pressing F8 at boot
When the Windows Startup menu appears, select ENABLE VGA MODE
This will boot the system in 640 x 480 resolution but the video driver will be installed. Once at the desktop, either reset the display to the normal resolution settings or reinstall the video driver.
Aug 06, 2008 | Relisys RLT1720 17" LCD Monitor
HP f2105 21" LCD Monitor Logo
155 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
