Question about Sony Bravia KDL-40W4100 40 in. LCD HDTV
How do I turn off CC on Sony Bravia - Sony Bravia KDL-40W4100 40 in. LCD HDTV
This appears to be an repair issue.
We are experiencing the same problems. No matter what setting we use for the 40EX500, the close captioning does not seem to come on or off.
We have a HD receiver which has a setting to disable or enable. Setting to enable allows CC to be seen on the TV, but it cannot be turned off or on with the CC button on the Sony Remote. Disabling the box, then disables the CC completely on the TV.
I do not know what the issue is, and calling Sony directly is a waste of time, the holding times are unacceptable.
Posted on Nov 18, 2010
How can I turn off CC on my SONY 52XBR. I used the Remote control settings and selected off on the cc display, but the cc never turns off. I also used the menu button on the side of the T.V to select
If Closed Captioning is being displayed even though the CC option in the TV menu is set to Off , then it is being produced by another device, such as a cable or satellite set-top box. To remove the Closed Captioning from the TV screen, it must be disabled on the device that is decoding the Closed Captioned signal.
NOTE: Some set-top boxes may automatically display Closed Captioning on the TV screen when the set-top box sound is muted. If this is the case, turn off the Mute function of the set-top box
Oct 31, 2014 | Sony Tv Xbr Bravia Kdl-52xbr5 52 Lcd Tv...
How do i get caption only on mute
On newer Sony TVs you press the CC button to cycle through the available settings for Closed Captions (CC): On, Off, and On when
Muting.
However, it looks like your factory remote control lacks a CC button and your TV menu appears to have a simple Off/On option for what Sony calls Caption Vision. If that is the case then you would need to manually turn on Caption Vision when you mute the television. That hardly seems like the solution you're after.
If you had an aftermarket remote control that could record macros you might be able to program it so that when you press the mute button the TV would mute and also turn on Closed Captioning. This would require the proper remote control and some expertise.
Aug 19, 2014 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
How to remove closed caption on Sony Bravia TV
Check the menu of set and a box if used--both usually have that feature.
In menu look for closed captions (CC) and turn off--settings may exist for leaving it to only come on if sound is muted.
Do not if using a box for signal overlook that also having the same feature.
May 31, 2012 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
How do i set up cc for my sony bravia? It says its on but it doesnt show it.
It will depend on what CC is being broadcast.My Sony has on/off, but also a program option. The settings vary from CC1-CC4 and text1-text4.So you may have to try different settings before you can get the CC to come onscreen. Well hope this helps.
Mar 08, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
We can not get the white closed caption boxes off our sony bravia tv. we have tried turning cc on and off, but that just turns off the normal cc in black boxes.
You either have a CC button on the original remote, which you seem to have found for standard def captions usually white on black, or it is hidden in a menu for settings or preferences. Try your manual or scour your menus. HD does not transmit the codes for standard NTSC CC, so the set must create those itself. You may even find there is a choice of color, font, and size for HD shows--I like yellow with a transparent background as the least obnoxious. -Ken
Aug 18, 2009 | Sony Bravia KDL-32V4000 32 in. LCD TV
I cannot turn off the closed caption feature
First, see if your tv is muted. By default, cc comes on when muting that model of tv. Also, you can press menu and navigate to closed captioning and turn it off that way.
Jan 05, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Closed Caption on Sony Bravia
Try a master reset on the TV. With the TV powered on, prss and hold down the up button on the remote (there are 4 buttons grouped together for up down left and right) and while holding down the up button, press the power button on the TV. The unit should power off and then turn back on and ask you to select a language. Let me know if this helps and be sure to rate this solution. Thanks!
Nov 11, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
CC will not turn on....
There are usually several versions of the closed captioning. Cycle through them to see which ones work. Turn one set on...wait a few minutes...if that does not bring up the captioning during normal shows (not commercials)...try the next set.
Feb 26, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I CAN'T GET THE CC OFF OF MY TV
Remote control original is part # RM-C1200G-1H ...best to
have JVC original......$25.00......................T.
Dec 23, 2007 | JVC AV-48WP74 48" Rear Projection...
Sony Bravia KDL-40W4100 40 in. LCD HDTV Logo
380 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
