Question about Hotpoint NVL333EY Electric Dryer
The dryer gets extremely hot on back panel and on sides. its hot enough that you cant touch it, any clue as to what it could be?
  • 6,784 Answers
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard, due to poor ventilation that will cause overheating. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
This may also be a failing thermostat. A thermostat can fail by being always on, no matter what the temperature. This switch will show continuity whether it was hot or cold. In this case, the heater will not shut off and the the dryer could dangerously overheat. As a safety precaution a second thermostat is used, This is called a thermal fuse. The power will be cut to the heating circuit if the maximum safe temperature is exceeded. In most cases, this is a one time fuse. The heater circuit will not function until the fuse has been replaced. Of course, it will be necessary to determine and repair the underlying cause of overheating or the fuse will just cut out again. The most common cause of overheating will be a clogged ventilation assembly. Be sure to inspect the entire ventilation assembly for build up. This will cause issues, if obstructions exist.
The thermostats are usually grouped together. The are typically oval in shape and about an inch and a half in size. They may be on the blower housing, under the lint trap or inside the vent line. There should be two wires connected to each thermostat.
Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals. You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
To test the thermostats or fuse, set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostats are heated to their limit temperature, they should switch off and you should get a reading of infinity. The fuse should be tested at room temperature for continuity.
Posted on Nov 13, 2009
The frezer not cool enoug
you may not have enough air circulation at the rear of the machine when you moved it. if the machine can not loose heat through the radiator at the back it looses its cooling capacity. move it back to where it was?
Jul 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Clothes not drying but back panel of dryer extremely hot
Disconnect power. Next, you will have to remove the screws passing through the front panel into the front edge of the top so the top can be swung back. Remove the screw on each side near the top which are holding the front panel onto each side panel. Set the front panel off to the side. (most times you do not have to remove any wires to do this) Use your long thin arms to reach under the left side of the drum to unhook the drive belt. Now, you can remove the drum out the front of the dryer. Inspect the heating coils for breakage. Replace them with a new element set WE11x10007. (includes instructions, but don't stretch them as much as they say, so that you can leave a little tension on them as you install them. You don't want them too long) Replace the rear drum bearing WE3X75 to get rid of the squeak. Inspect the front drum slides (which support the drum at the top of the front panel) to see if they need replacement also.
May 24, 2009 | GE DBXR463EDWW Electric Dryer
Takes long time to dry clothes
clean out hose or if it's to long cut to fit with no slack thank you for useing fixya rate me
Mar 30, 2009 | Kenmore 73952 Gas Dryer
Frigidaire dryer is overheating
Sound like the limit switch on the dryer is faulty and needs to be replaced. Hoped this helped
Mar 14, 2009 | Frigidaire Dryers
Very hot to touch on top
Sounds like you have a clogged vent hose or clogged duct work leading to the outside of the home. Make sure you have no obstructions in the exhaust system including a functioning flap on the outside wall cap.
Jan 03, 2009 | Frigidaire GLER341A Electric Dryer
Losing coldness in freezer and fridge. side panels near freezer door are extremely hot to the touch. bottom back of the fridge is extremely hot.
Condenser is in need of being cleaned badly or your fan motor to cool the condenser is not operating. Compressor is overheating. Removed the panel in back of the refrigerator and clean the condenser so air can freely pass over it for heat removal. Allow compressor to cool off before restarting it.
Jun 10, 2008 | Frigidaire Refrigerators
Dryer too hot
You will want to make sure the lint screen and vent are free and clear.
If the dryer is blowing out the vent outside the house as it should, then you have a thermostat problem.
If the operating thermostat does not open properly then the element will cycle by the hi-limit thermostat which will cause the dryer to heat more than normal.
Nov 24, 2007 | GE DWSR405EBWW Electric Dryer
Hotpoint NVL333EY Electric Dryer Logo
324 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
