Question about JVC KW-AVX810 Car DVD Player
An error message apears on the screen telling tha the unit have to be reset or initialized . When you reset the unir the problem is solve but you lose all the setting and memories . It happens frecuently . Thanks IG
  • gomezcarrasc Nov 13, 2009
    The problem is NOT that the radio reset itself , the problem is that the unit suddenly stop working the ipod , the bluetooth and the ipod and a message appears telling that the unit has to be initialized . Then when i reset it, the problem is solve, bit all the settings and memories are deleted .
    Thanks
    IG
    President:
  • 1,462 Answers
The issue could be with the broken or loose power connection. Many radios lose their presets or gets corrupted leading to reset the settings, if power is interrupted. This could be at the fuse box, or inside the radio or somewhere in between them.
If you can get at the radio wiring harness and identify the continuous power input wire (the one that feeds the clock and presets is different from the switched line that powers the radio), you could try running a new wire from a different unswitched fuse or a new fused line directly from the battery into that line, perhaps using one of those clip-on wire tap things. If the problem goes away, you know the problem is not the radio, but somewhere between the battery and the radio. A loose connection inside the radio is harder to diagnose.
So performaing a wire diagosis for loose connection would solve your problem...
Please leave me comment, if you need further assistance
Thanks for using FixYa!
Rnj VINODKUMAR
Posted on Nov 13, 2009
  • Vinod Kumar
    Vinod Kumar Nov 13, 2009
    Yes, i mean to say that..This happens because when the unit has loose power connection, then the unit looses all the settings and leading you to reset the unit...
    First, try whether you get the problem when the car is stable, ie, when the car is not moving..If the unit doesnt stuck then you have to check the connection..
    If the unit asks you to reset, when the car is stable, leave me comment and we will move to next sugestion...But this happens mostly due to loose connection...
Sharp ar5516 f2 error
We have bought this machine on Date-28/07/2011 and it is still in warrenty. now already 11,000 copies put it And the now machine shows F2 indication after starting and the company not repairing it. And the after sell service of company is not good.We tell the company to change the the machine or repair and they neither repairing it nor changing the part.
I request you to solve my problem please.
Nov 14, 2011 | Office Equipment & Supplies
Need to reset replace drum message on Xerox Workcentre Pro 416
You can replace the chip on the drum unit. Or the drum unir itself.
Google a business called " the parts drop". They will have both the chip and or the drum cartridge. It is not resettable with a diagnostic code.
Aug 19, 2010 | Xerox WorkCentre Pro 416DC Copier
P1i Unable to connect via usb
Such questions, This is not ERROR, but unit has malfunctions, you should contact your local Sony Ericsson authorized repair outlets, allowing engineers to help you solve the problem!
Hope this initial info helps
Aug 08, 2009 | Sony Ericsson P1i
Sony cyber-shot dsc-w50 problem
When “FLASH error” (Self-diagnosis Code E : 91 : ** ) occurs, to prevent any abnormal situation caused by high voltage, setting of the
flash is changed automatically to disabling charge and flash setting.
After fixing, this setting needs to be deactivated. Flash error code can be initialized by the operations on the Setup screen.
Method for Initializing the Flash Error Code
Initializes the setting to the default setting.
1 Select [OK] with v on the control button, then press z.
The message “Initialize all settings Ready?” appears.
2 Select [OK] with v, then press z.
The settings are reset to the default setting.
• Make sure that the power is not disconnected during resetting.
Jul 26, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Resetting EX-V7 error message
Hey Go here
http://world.casio.com/qv/download/en/ex_v7_firmup/
Download the latest firmware. Install it. Like the rest of the people. It seems like we all dropped it. And updating the firmware seems to help a bit.
Meaning you can now use tha Camera and take pictures, but when you turn it on, you will get the same error message for like a second. Then the Camera is back to normal.
If its under warranty take it back. And dont tell them it was dropped.
Cheers !
Mar 14, 2008 | Casio Exilim EX-V7 Digital Camera
Pdal OS ianvalid image error
this pblm can be solved by resetting d mobile in master clear option. after resetting power off d mobile and on after 5 min,and connect to the net upgrade ur os, b4 upgrading remove memory stick and upgrade , this will be solved....
Jan 19, 2008 | i-mate PDAL Pocket PC
Camera error #B03
According to the manual(page 52 on this site, and around 45 in the manual itself), when ever such an error repeatedly apears, you must contact a Kodak rep. Since its batteries that bring up this message i would suggest the obvious of changing batteries, even if new. sounds like a pickle... you can also try to disconnect everything from the camera(cards cables batteries etc) and leave it with all hatches open in a dry dark place for a couple of days, let the camera sit in the corner and get a grip on itself ;] this should reset it and sometimes solves the problem. Good luck in any case, hope it works out...
Feb 08, 2006 | Kodak EasyShare CX7430 Digital Camera
JVC KW-AVX810 Car DVD Player Logo
47 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
