Question about SanDisk Sansa e260 MP3 Player
Sound only in right ear bud now. Some headphones don't have sound at all. The same headphones work fine in other MP3 players.
I had the problem with my e260 where one side of the headphones stopped working unless I wiggled the headphone jack. It turned out to be a cracked solder joint on the headphone connector on the circuit board inside. It's an easy fix and cost nothing. However, you need a small phillips screwdriver and a soldering iron.
  1. Remove the four screws and remove the back cover.
  2. Lift out the battery.
  3. Remove the four tiny phillips screws near the corners.
  4. Lift off the black front cover. You may need to use a fingernail to separate the two covers.
  5. Remove the circuit board by carefully flexing the plastic case away from the lower connector and lift the circuit board out.
  6. Check the solder joints of the headphone jack under a magnifying glass. Resolder any that appear to be cracked.
  7. Remove any fingerprints from the screen and reassemble in the reverse order.
Good luck.
Posted on May 24, 2011
  • 80 Answers
It happens, just keep trying different head or ear phones till you get the one that will work well(both ears). I have had that kind of challenge before, mind you, the problem is not from the mp3 but from phones.
Posted on Feb 11, 2010
I have bought several pairs of headphones for my gogear but they all sound like there is a problem with the connection only getting sound through one ear sometimes
The headphone socket in the GoGear is faulty. If you can hear sounds from both ear pieces when you wriggle the headphone plug in the GoGear, then the headphone socket in the GoGear is faulty. This fault can be easily fixed by removing the circuit board in the GoGear and resoldering the headphone socket to the circuit. You need a very fine tipped temperature soldering iron to do this job.
Jan 19, 2012 | Philips GoGear HDD1830 MP3 Player
Hi, Recently I bought Plantronics MHS123 Stereo Mobile Headphones/Headset. I have tested with audio tracks from computer and portable mp3 player. I have problem with the right ear bud and no volume is...
This sounds like a definite problem of the headphones themselves. What I would suggest for you to do is to get into contact with their customer support. They have 24-hour support available by calling 1-888-PLANTRONICS. I have actually had a similar experience with a pair of their headphones and I called them up. They were very kind and helpful and had a replacement set shipped out to me right away. Good luck!
Sep 16, 2011 | Plantronics MHS123 Headset
I purchased this mp3 on 11th devmber. the music is not getting through to the headphones - can you help? is it powered by a battery & is one included as standard?
Hi mharrington9,
You may want to post the make and model of your mp3 player. Someone may have solved the same problem with the same player, and would then be able to give you a more specific answer than this one;
I assume you have replaced or re-charged the battery first, and that full power to your player did not help. If so, it is likely to be a problem with the headphones, the headphone receptacle, or the amplifier inside the mp3 player;
1) Headphone problem?
Get a different set of ear-bud headphones, and try them out. If the alternative set works but your headphones do not work, it's the headphones.
1a) Large headphones, small player?
If your headphones are large, but the power of your MP3 player is small, the player may not have enough power to drive the headphone speakers. If you run your MP3 player through an additional amplifier, you may then have enough power to get sound out of your headphones.
1b) Broken wire in ear bud jack?
Most of my broken ear-bud sets have failed because one or more of the wires has broken, usually at the plug-end. There are 3 thin wires; If you break the left-channel or right-channel wire, only one earbud goes out. If you break the ground wire, both earbuds stop working, or you may hear a very faint sound at full volume. If you like to solder things, it is possible to get a new plug, cut off the old one, and solder in a new one. But it may be easier to get a new set of earbuds.
2) Broken Receptacle?
Plug your ear-buds into a different, working MP3 player. If the ear-buds work, then
Plug your MP3 into a computer through the data cable, and try to play something through the computer.
If the MP3 works through the data cable, something is wrong with the receptacle for your ear-bud plug.
You may be able to get your MP3 player replaced under warranty, since the purchase was recent. Or, if no warranty and you feel adventurous, take the back off and try to re-solder or replace the receptacle-- Though this usually ends in irreparable damage to the MP3 player :-\
3) Broken MP3 player?
If you can't get any music to play through the data cable or the computer, something is seriously wrong with the guts of the MP3 player. Try for a warranty replacement if you can.
Best of luck, mharrington9
Dec 12, 2010 | Audio Players & Recorders
I have the GC-1020 Element mp3 player..i have had it for 3 months.All of a sudden i can only hear the music out of one ear of my ear buds,i have tried my earbuds on something else and they work fine..why...
I have the GC-1020 Element mp3 player..i have had it for 2 months.All of a sudden i can only hear the music out of one ear of my ear buds,i have tried my earbuds on something else and they work fine..why won't sound come through both ears anymore?
Aug 22, 2010 | Sears GC-1020 MP3 Player
Its either the jack or the connector in the device is the problem. You can try connecting other headphone, if this works, then the problem lies on the jack of the old headphone.
May 03, 2009 | SanDisk Sansa e200 MP3 Player
Only have sound on right side
I don't know if you used new earphones but if you did I would try to clean the inside of the mp3 player then reconnect youre earphone. If you still have the problem return to the store, then the hardware in the mp3 itself is wrong.
Dec 25, 2008 | SanDisk Sansa e260 MP3 Player
My left earbuds on my JVC gummy earphones went out.
I have this problem all the time with my JVC earbuds. This may sound a little gross but it will work. I put the ear phone in my mouth and **** on the end of it pretty hard. What I have found is that sweat or even wax will plug the little hole and prevent the sound from coming out.
Nov 16, 2008 | JVC Gumy Ear Bud Headphone - Peppermint...
Only the left ear bud has sound
Hey NoRightSound,
If your earbud headphones function normally with other devices, there are a number of reasons why this problem may be occurring, including faulty connections within the iPod itself or a potentially defective headphone jack. While both of these issues can typically be resolved fairly easily, I would first suggest contacting your local Apple-authorized service center for a complete diagnostic to pinpoint the exact cause of the problem.
Remember that if your iPod is still under the original manufacturer's warranty, you can always call Apple directly for technical support over the phone in addition to working with a technician in your area.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Apr 22, 2008 | Apple iPod classic MP3 Player
SanDisk Sansa e260 MP3 Player Logo
161 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
