HI CAN SOMONE HELP ME WITH MY PRINTER ITS A EPSON STYLUS DX5050,WHEN I CLICK ON PRINT NOTHING HAPPENS, A WINDOW OPENS ON PC SCREEN & IT SAY STATUS PAUSED. HELP THANKS KEV
    Guru:
  • 126 Answers
STATUS PAUSED means your printer Epson is not connected. Check the port USB at the back of the PC yet connect it properly.
At the Printer Panel see if the printer is ready or not. Usually this problem occur when the port setting of the printer defaulted at LPT1.
Posted on Nov 13, 2009
EPSON STYLUS CX 7800 HOW DO I ALIGN THE HEADS??
1. Turn on the Epson Stylus CX7800
2. Load several sheets of paper
3. Windows: Right-click the printer icon on you taskbar (in the lower right corner of
your screen). Select Print Head Alignment.
Macintosh OS X: Open the Applications folder and select Epson Printer Utility.
Select your Expson Stylus CX7800 in the printer list, click OK,
and select Print Head Alignment.
Jan 15, 2011 | Epson Office Equipment & Supplies
Looking for manual for EPSON stylus DX5050 inkjet printer
You can view the online manaual by clicking this link
Hope this helps. Thanks for using FixYa.
Sep 20, 2010 | Epson Stylus DX5050 All-In-One InkJet...
Epson stylus c48
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Jul 27, 2010 | Epson Stylus C48 InkJet Printer
Epson stylus cx6600. How can I get rid of the message box telling me I am not using Epson carts. I know they are not Epson carts but there must be away of having not to click YES I want to continue using...
Hi Andy,
This helps remove the nag screen:
  1. Go to Printers and Faxes (or the equivalent screen that lists all your printers)
  2. Right click your CX6600 printer and choose "Printing Preferences"
  3. Click on the "Maintenance" tab
  4. Click on the "Speed & Progress" button
  5. Tick the "Disable EPSON Status Monitor" checkbox
  6. Click on OK
  7. Click on OK to close the Preferences window
That should sort you out and allow you to print in relative peace...
Cheers,
Martin
Jan 18, 2010 | Epson Stylus CX6600 All-In-One InkJet...
No pwr to printer.plug fuse and cable ok. epsom dx5050
if their is no power ckeck your power outlet with any currnet meter to check the voltage is avalible to operate the printer is avalible change the plug cable and try again or try with any other cable avalible check the power switch of the cable if nothing happen better to contact your service center
Oct 18, 2009 | Epson Stylus DX5050 All-In-One InkJet...
Epson Dx5050 blocks any printing once it has claimed that any ink cartridge needs replacing. How can I overcome this so it keeps printing with the warning, like Canon printers do, until the cartridge...
Unfortunately you cannot override this behaviour without installing a valid cartridge in the printer.
Epson printers do not have this sort of functionality as it would leave the printhead open to damage and foam clogging.
Sorry to be the bearer of bad news.
May 18, 2009 | Epson Stylus DX5050 All-In-One InkJet...
Need instructions for epson stylus dx5050
Here is guide for CX5000, that is same model as DX5000
User's Guide
Below you also find assembly instructions:
EPSON STYLUS CX5000 / DX5000 / DX5050
Jan 30, 2009 | Epson Stylus DX5050 All-In-One InkJet...
How to reset my epson stylus dx5050 printer
If your Epson printer needs resetting you can download the latest software Version of the SSC Service Utility (V4.3) from this link.
Install it and run it, click on configuration, select your printer from both lists ('x' is replaced by a number), close the program with the red cross. The program will run in your task bar, click your right mouse button on the icon for a menu. You can use the appropriate utility for your needs, if your printer needs maintenance due to ink pad being full, select Protection Counter and Reset Protection Counter. If your printer has locked out because you ignored the warnings and continued printing, first select Protection Counter and Clear Counter Overflow, then select Extras and Soft Reset, wait 5 minutes, then select Protection Counter and Reset Protection Counter.
Sep 23, 2008 | Office Equipment & Supplies
Dx5050
RX500 or DX5050?
Download a manual for the EPson site to learn how to operate printer.
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp?oid=-10237&infoType=Overview
May 07, 2008 | Epson Stylus RX500 All-In-One InkJet...
Epsom Printer DX5050 Language selection
I need to change my Epsom DX8400 printing instructions to English please instead of German or Dutch. Please help
Apr 11, 2008 | Epson Stylus RX500 All-In-One InkJet...
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
