Question about Invicta Subaqua Noma Iii S
Removing bracelet screws on Invicta Subaqua Noma III bracelet
Are the screws on the bracelet removable? I cannot get them to budge. Is there a trick to doing it?
escapement
  • 2334 Answers
SOURCE: SUBAQUA NOMA 3 SCREWS LOOSEN AND THE BRACELET
What 3 screws? Give me: Make, model, all the numbers on case back. Explain in detail what 's wrong. Where screws are/were located and so on.
Posted on Feb 05, 2010
  • 3 Answers
SOURCE: How do you remove the links from an invicta
it's not much harder then normal push pins, just a little trick..push the pin out, doesn't matter which way. You will probably have to pull it out with pliers once you get it started.
once that pin is out, the band still won't come apart. There is another pin, a tube actually that the other pin went thru. it connects the center links. to remove it, you have to first remove the outer links. to do this you push them inwards, toward where your wrist would be if you were wearing it. (the links are actually two pieces-the center 'snake-skin' piece, and the outer bars. the outer bars are connected behind the center piece) the outer bars are what you push inward, they will pop out once the first pin is out.
Now you will just have the center piece connected to the adjacent center piece. That second pin (the tube) will just about fall out if you turn the band on its side. Now the bracelet will come apart.
To put back together, just line up the to center pieces, slide in the tube, then put the outer links in from behind the center piece (this actually locks the tube in place) then put in the long pin.
Ideally it will slide in halfway easily, then carefully tack it in fully. if it doesn't get in halfway jiggle the links and tap lightly. Don't use too much force until it's past 2/3 inserted or you will bend the pin.
Posted on Jun 11, 2010
genebur2
  • 63 Answers
SOURCE: What powers my subaqua noma iii gmt limited
It has an automatic movement powered by the movement of your arm.
Posted on Nov 07, 2010
SOURCE: Hi i just got an
I have had the same problem with one of my SANIIIs, As you have probably figured out, there are two small screws that are part of this assembly, lower one is the pivot point, upper is the latch. There are also very small rubber bushings (upper & lower) in the pivot of the crown protector, if they are worn it will present side to side movement or "slop" they need to be replaced in this case (I Just went through this on an older Valjoux 7750 SANIII - same problem, latch would not stay closed), you can order the part from Invicta or take from a donor watch in the mean time (Invicta will take several weeks to months to fulfill a part order) The upper screw goes through a small cylinder or cam, there is a little (very little - but it is there) to move that cylinder outward towards the upper pusher or top of the watch. After you loosen the top screw (loose not remove) you can adjust this play w/two precision screwdrivers, one to tighten the upper screw one to lever the cylinder toward the top of the case by leaning one screwdriver w/ just a slight pressure against the crown and the cylinder to widen the area between the pivot screw and the latch cylinder. Don't overtighten the screws to try to add friction to the assy - the threads & heads are fragile, you can damage the case or strip them - or worse snap the head off. Hope that helps.
Posted on Dec 20, 2010
escapement
  • 2334 Answers
SOURCE: I have an Invicta subaqua
Browse through my Tips and Tricks. You will find there link to all Invicta watch manuals.
Posted on Feb 27, 2011
How to set date and day on INVICTA SUBAQUA NOMA III
Pull the stem out 2 clicks sets the time, pull the stem out just 1 click
turn it forward sets the day and turning the stem backwards sets the
date. I hope this helps
Jul 12, 2014 | Invicta Subaqua Noma Iii S
I need screws for invicta subaqua noma 3 band model # 6510
Good day I had purchase parts direct from Invicta and found that is easier then looking around for the parts here is the info;
Message Invicta Customer Service . Mon - Fri . 9am - 5pm EST
Email service@invictawatch.com
Call 800-327-7682 . Mon - Fri . 9am - 5pm EST
Fax 954-921-2508 or 954-862-5461
Write Invicta Watch Group
Attn: Customer Service
One Invicta Way (3069 Taft St.)
Hollywood, Florida 33021
U.S.A.
#PS
or you can also check them at their web-site http://invictawatch.com most parts are really low cost with the exeption of the mechanic parts
Apr 17, 2012 | Invicta Subaqua Noma Iii S
INVICTA SUBAQUA NOMA 3 SCREWS LOOSEN I have had five screws fall out of my watch in the last 9 months. Initially they fell out 3 months after purchase. Conveniently outside of the 30 day return policy. At...
I have an invicta subaqua noma 3 model no.0736 that I am trying to replace the bracelet/band and would like to know how to change it , how many screws do I remove and what screws do I remove, can you help me?
Dec 21, 2010 | Invicta Subaqua Noma Iii S
What powers my subaqua noma iii gmt limited edition model # foo27
Nov 07, 2010 | Invicta Subaqua Noma Iii S
SUBAQUA NOMA 3 SCREWS LOOSEN AND THE BRACELET OPENS ANYBODY ELSE
Feb 05, 2010 | Invicta Subaqua Noma Iii S
Removing links
Watches either have screws in the links that you can remove to remove a link. Or they have a pin in each link that you must push out to remove a link. Some have a "hairpin" looking keeper that you remove. Hope one of these will work for you. Good Luck
Dec 14, 2009 | Invicta Subaqua Noma Iii S
Invicta Subaqua Noma Iii S Logo
628 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Invicta Watch Expert? Answer questions, earn points and help others
