Question about JBL Venue SUB10 Subwoofer
I have a powered subwoofer the Venue 10 and it is blowing fuses. A technician quated $119 plus parts to repair it. Is there a simple solution or is it worth the money to get it fixed?
4 Suggested Answers
MECP Guy
  • 344 Answers
SOURCE: My jbl venue series subwoofer 10 keeps making a popping noise
sounds like the capacitors need to be replaced make sure you replace them with the same value mF
Posted on Feb 15, 2010
idrvnsx2
  • 60 Answers
SOURCE: Describe your Venue SUB10 Subwoofer
You can remove the screw near the volume knob and the screw near the on/off switch - then slide out the amp remove the black and white wire - then check the fuse - if its blown look for we repair amps - ebay - if its good then it probably still needs work - it should turn red when plugged in and no signal and green when signal is present - which means amp is on.
Posted on Nov 03, 2011
idrvnsx2
  • 60 Answers
SOURCE: need a replacement amp circuit board for a jbl
The boards can be repaired - look for we repair and your model number on ebay -
Interested in your Infinity sub repair; could I send you some images to verify infinity TSS-1100 has no light, seems blown to me, not sure if it has the screw you mentioned
Hi my name is MIchael and I repair the following amps JBL PB10, PB12, PS10, PS12, TSS-1100,TSS-1200,VENUE SUB12, E250P. If it has the screw near the on/off switch. If your amp is blowing the fuse, has bad sound, no sound, doesn't power up or if the output is low or muffled. We can fix it - please check ebay and search WE REPAIR JBL PB10, PB12, PS10, PS12, TSS-1100,TSS-1200,VENUE SUB12, E250P - you will find us ... Edwards Electronics ....
Oct 24, 2011 | Infinity TSS-1100 System
Describe your Venue SUB10 Subwoofer Problem: The subwoofer won't turn on at all. The red light doesn't even come on. Could it be the fuse in the subwoofer? If so, where is the fuse located?
Sep 11, 2011 | JBL Venue SUB10 Subwoofer
How and where can I get a circuit board for jbl venue sub 10
There is a guy on Ebay who repairs these - not sure but I don't think the board is available - you could check with Harmon - they own Infinity and JBL
Aug 18, 2011 | JBL Venue SUB10 Subwoofer
Keeps blowing fuse
Blown Fuse - Means Short - Needs To Be Checked By Tech - One On Ebay who repairs these units.
Jan 05, 2011 | JBL Venue SUB10 Subwoofer
Keeps blowing fuse
Suspect an overload in the power supply stages or in the main amp section caused by a faulty semi-conductor. You might see damage or burnt parts too.
Apr 05, 2010 | JBL Venue SUB12 Subwoofer
Need a replacement amp circuit board for a jbl venue sub 10 - part # is 104HKTS1400v-E
Nov 22, 2009 | JBL Venue SUB10 Subwoofer
When i turn my infinity servo subwoofer ssw 10 on and it just blows the fuse
Then it has developed an electrical fault and will need to be repaired by a technician. Sorry to bring you bad news.
Do you mean the house fuse, or the fuse built into the back of it?
If it is the fuse in the back of it, are you definitely replacing it with the same rated fuse?
Apr 26, 2009 | Audio Players & Recorders
No power
Generally, if a fuse blows it is indicative of a fault with any of the components. If the fuse is on the AC side, then chances are it is the power supply, if it is on the DC side, then it is the amplifiers side.
I tend to suspect that you cannot find a replacement board. And if ever available from the manufacturer would probably cost just slightly less than buying a new set.
Your alternative is to seek the services of qualified audio technician who is willing to do component level repair. Circuit design would not differ much from basic amplifier hence replacement parts would reasonably be available versus entire PCB.
But then again, you must consider the cost/time of repair. If cost of repair plus downtime would not be to your liking, perhaps your best bet would be to purchase a new unit.
The cheapest alternative would be to do a DIY (do-it-yourself) which would require that you be familiar with basic electronics circuitry & components, use of & access to a DVM and use of a soldering iron.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 24, 2007 | JBL PB10 Subwoofer
JBL Venue SUB10 Subwoofer Logo
138 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
