Question about HP DeskJet F380 All-In-One Printer
HP Laserjet F380 dried up?
I've just moved house so have only just got around to plugging in my pc and printer. I have tried to print a letter out and I'm getting the colours but no black text! I guess the printer head has dried up?
When I have an epson printer it had a self-clean function, but this one doesn't - or at least I cant find it.
Can anyone suggest anything?
  • snowy190uk Jan 08, 2008
    Sorry - I meant a deskjet F380.
    The printer heads are fixed in the printer, but the ink cartridge is the part you swap. I'll give it a go. Cheers!
  • Anonymous Feb 18, 2008
    my Deskjet F380 is doing the same thing! I too am use to the self cleaning epson and dont know how to fix the problem here with my HP. The only difference is I replaced both ink cartridges last week. I think the advice to upgrade may be the best!
    Scholar:
  • 32 Answers
Once the heads dry up on these printers, the cartridges are done for. The in built heads cant recover by force feed cleaning. Just replacing the cartridge will usually fix the problem. If not, I would personally just upgrade to a new printer.
You said Laserjet F380, but no such beast exists, its a Deskjet.
If you want a color laser, you can find them easily under $300, HP Color Laserjets like the 2600n are more reliable than the cheap ones and cost less to operate in the long haul.
Posted on Jan 08, 2008
My HP Deskjet F380 will only print blank pages. There is plenty of ink left in both cartridges. I've been on the HP help site. It didn't help. It won't photocopy either. It printed the top part...
the body of text of the test page is black ink. From what you describe, the print heads are clogged. Most HPs use cartridges that have the head built in, but if not used for an externded period they can dry up and clog.
Try repeated head cleanings (10 or more) see if any change. If none, try new HP ink cartridges
Jul 12, 2011 | HP DeskJet F380 All-In-One Printer
I"ve HP Laserjet 3005x Printer
Try a different toner cartridge
Feb 24, 2011 | Office Equipment & Supplies
Paper jamming problems with HP DeskJet F380 All-In-One Printer . The paper feeds into the paper feeder but then it seems to get off line and the paper get stuck and actually tears in the feeder. The...
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Thanks
Newton
Aug 29, 2009 | HP DeskJet F380 All-In-One Printer
HP laserjet 2430 dtn little typed letters print on the left side
Probably a bad FUSER. The teflon is probably worn off.
Also take out the toner and move the drum cover aside to look at the drum..It should be clean.
Feb 17, 2009 | HP LaserJet 2430dtn Printer
HP DESKJET380 NOT RESPONDING WHEN CLICK ON PRINT
After sitting in power save mode for a long period of time the printer might not function properly. This happens when the printer is plugged into a surge protector. Unplug from the surge protector and plug directly into the wall power socket.
Step 1:
Please try to print Self test Print from the Printer (without PC ie. remove the USB cable from the PC)
Step 2:
If the Self test Print is Ok, try to connect your printer to PC
and Print Test Page
Go to Start >> Printers and Faxes >> Select your Printer F380
then Right click Properties and Click on "Print Test Page"
If this prints Ok then all the connections you have made are correct
In case, it does not print then please check your USB cable try to change it
Step 3:
You can uninstall your Driver
and install the new driver, to download the driver for F380 All in One Printer Please click the below link
Choose appropriate Operating System
HP F380 All in One Printer Driver
I hope this will resolve your problem
all the best
Jan 05, 2009 | HP DeskJet F380 All-In-One Printer
Hp desk jet f380 not printing jobs piling up not printed
  1. Remove this F380 printer drivers.
  2. Restart PC as required.
  3. Install the CD
  4. DO NOT plug in the USB cables yet.
  5. After running the HP software, plug in the USB cable as requested.
  6. the printer should be installed by itself.
  7. wait for sometime, and the HP software should ask you to restart the PC.
  8. After restart, try printing
Let us know if this works.
thank you.
Jan 04, 2009 | HP DeskJet F380 All-In-One Printer
HP 2180 deskjet all in one problems printing
Try this :-
Resetting the All-in-One
  • Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Jul 15, 2008 | HP DeskJet F380 All-In-One Printer
Hp diskjet f380 not printing
Hi , prnter does not respond within a few seconds , the printing jobs are backlog , it must be delete all or cancelled it , so that the printer can move on.
Dec 28, 2007 | HP DeskJet F380 All-In-One Printer
Printing on Stationary with an HP Laser Jet 1320
Most printers and copiers are made for the standard 20# paper, if using a different paper then most of the time you need to specify what type ie: transparency, labels, lbs etc. so the machine can accommodate itself. ( lowering or increasing the heat in the fusing section, and pressure on the paper.)
for that machine everything is done through the pc. go to File, Print, right click on the printer, go to properties got to device settings, General, printing preferences and paper quality, there is a box there for paper options. try setting it to cardstock.
Oct 04, 2007 | HP LaserJet 1320n Printer
HP DeskJet F380 All-In-One Printer Logo
702 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
