Question about Malber WD1000 Front Load Washer/Dryer
I lost manual . there are a lot water inside. how
I own wd1000 and i lost manual . there are a lot water inside. how to release the water? also the maschine door knob was broken, how can i get it fixed?
    President:
  • 1,185 Answers
To get the water out , bring the machine forward
Take the drain hose out of the waste pipe
Remove any clips holding it to the back of the washer
Lower the hose into a bucket and the water will drain out under gravity
As for the knob it is a replaceable part but you will need to contact Malber
Posted on Nov 13, 2009
How do you get the water to drain in the Malber WD100 washer/dryer combo?
Hi. I''m assuming you are referring to a WD1000.
To initiate the drain cycle: Rotate far right knob CLOCKWISE to Position 4. It may take 30-45 seconds to recognize the knob's new position, but then it will begin an 11 minute Slow Tumble/Pump Out cycle. During this cycle you'll see the internal drum slowly rotate CW for 60 seconds, pause, then rotate CCW for 5 secs - then repeat. All this time the pump will run and you'll hear water running down the drain. When you hear no more water you can rotate same knob to "straight up", and stop the machine. To turn power off, press the rightmost button.
Sep 21, 2014 | Malber WD1000 Front Load Washer/Dryer
Door latch stuck on volvo c70
It sounds like the actuators (usually stiff wires) from the door handles and locking knob are OK, which means the latching mechanism itself is probably jammed or broken.
You'll need to remove the upholstered panel covering the inside of the door (search online for "how to remove a door panel") and investigate, pulling on various rods or cables to get the latch to release. You may have to temporarily remove part of a plastic water shield under the door panel to gain access.
If you can get the latch to release, unbolt it from the door (usually from its side), spray every part of the mechanism that you can access with a light lubricant like WD-40, and see if that helps. Try operating the latch manually by pushing with a screwdriver to see what happens. Look for any broken or jammed components or connectors.
If it still doesn't work, but all the related handles and knobs appear to be connected and moving properly, then the latching mechanism itself is probably at fault. Removing it is usually a matter of disconnecting all the control wires or cables, but take notes on how they connect so you can re-assemble everything). New latches are available from the manufacturer, or you can probably find a used one online. These are normally very reliable items, so I wouldn't hesitate to buy a used one.
Apr 11, 2014 | 1999 Volvo C70
The water remains inside and is not draining out. The clothes are not drying. The moment I openened the door, water flooded the entire room. I am using for for a year now.
looks to me that you may have a faulty water valve. check that the water pressure is at least 20psi and that you have no dirt in the water fill hoses screens.
Feb 06, 2011 | Malber WD1000 Front Load Washer/Dryer
2000 cadillac deville remove door panel
2000-2001 Deville Door Panel Removal:
1. Position window fully downward and ensure manual lock knob is in unlock position.
2. Disconnect locking clip at front of manual lock knob, by insertingsuitable flat bladed tool into top service notch.
3. Remove manual lock knob.
4. Remove inside handle bezel by holding inside handle to open position, inserting sutiable flat-bladed tool at front lower corner and prying outward.
5. Remove bezel.
6. Remove inside door handle mounting screw.
7. Disconnect eight retainers around outside edges of door trim panel using clip zip tool No. J-36796, or equivalent.
8. Slide door trim panel upwards to release alignment datums, eight retainers, armrest steel retainer clips and inner belt mouldings (see fig #7 amd #8).
9. Disconnect electrical connector(s).
10. Reverse procedure to install.
Hope this help (remember rated this).
Mar 28, 2010 | 2000 Cadillac DeVille
Hotpoint electronic 800 delux 9525. can not open the door help
Make sure there is no water left inside washer.
If it still will not open, then you need to remove the top cover, and release the door manually from inside at the front where the door latches in.
Can be caused by the belt being off the pulley,or a broken ****** assy.
Jan 12, 2010 | Hotpoint Washing Machines
Malber WD1000
door handle broke at plastic insert. Looking for replacement parts.
Jul 05, 2009 | Malber WD1000 Front Load Washer/Dryer
2003 toyota sienna lift door knob broken. how to open the ldoor
The handle that broke had a little 'finger' that actuated the release mechanism. The only way to open the back hatch is to remove the inner panel and push on the release mechanism.
Once off, you can either a) buy a replacement handle (expensive) or b) do what I did and simply make a piece of L-shaped metal to lever the release mechanism from the outside.
If your handle is completely off of the door you can look up under the little plastic cover (that hides the handle) and see the slot on the right side that the release handle inserts into. You need to stick the lever into that slot, and angle it down about 30 degrees from horizontal to get under the latch mechanism, which unlocks the hatch if you pry it upwards.
Jan 09, 2009 | 2003 Toyota Sienna
Rubber circular tube inside front has hole
just get a new door seal for it.
On line they will not be to expensive
Jun 05, 2008 | Malber WD1000 Front Load Washer/Dryer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
281 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Dan Webster
Dan Webster
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
