Question about Panasonic Lands Phones
I have a Panasonic KXTD146E 6CS interface module. Only the first 3 ports are working. Any ideas where I can get the circuit diagrams so I can try to rectify the problem?
  • 3,741 Answers
You will have to get the service manual for getting the diagram and all other trouble shooting
click this link directly to get the service manual
http://www.printcopy.info/?l=en&mod=docs&brand=Panasonic&gID=16912
also click this link for more help
http://www.printcopy.info/?l=en&mod=docs&brand=Panasonic&prefix=KX-TD
to get repair manual click this link directly
http://www.manualsparadise.com/service-manuals/Panasonic_KX-TD146E_KXTD146E/users-owners-manuals/ReWrite-SPFM-.Dyn.M28981399KYWRDS_Panasonic_KX-TD146E_KXTD146E_service_manual_repair_manual_schematic_diagram_owners_manual_users_manual_parts_list.html
check out all the links one by one.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Nov 13, 2009
98 Buick park avenue, electric door locks work intermittently, lock while engine running and won't unlock!
Do you know how to use a wiring diagram an a DMM - digital multi-meter to test automotive electrical circuit's ? That's how one would go about solving a problem like this . Testing B+ power ,plus ground circuit's . Without testing the circuit's we'd only be guessing .Lock's are controlled by a electronic module. Could also have DTC'S - diagnostic trouble codes stored. Free wiring diagrams here http://www.bbbind.com/free_tsb.html
Enter vehicle info. year , make , model an engine size . Under system click on body & accessories ,then under subsystem click on power lock's . Click the search button then the blue link. Do the power windows work ?
The power door lock sub-system is comprised of the following components:
• The class 2 serial data link
• The door lock actuators (motors/manual levers)
• The power door lock switch
• The driver door module (DDM)
• The left front power door lock switch
• The passenger door module (PDM)
• The rear door module (RDM)
• The remote function actuator (RFA) module
• The right front power door lock switch
• The simple bus interface (SBI)
If you know nothing of the stuff i posted ,your best bet would be to take your vehicle to a qualified repair shop.
Driver Door Module (DDM)
The driver's door module (DDM) directly controls the driver's door lock actuator motor. The DDM receives and forwards the driver's door switch lock request messages to the remote function actuator (RFA) via the serial data link. The RFA receives the request message and examines the message for lockout prevention criteria. If the conditions are proper, the RFA sends a lock or an unlock command message back to the DDM. The DDM forwards door lock messages received from the RFA to the passenger door module (PDM) and the rear door module (RDM) over a simple bus interface (SBI) line. The DDM also contains a class 2 serial interface which communicates with other vehicle system modules. The left front door power window and the outside power mirror are also controlled through the DDM. Battery voltage is always applied to the DDM through the retained accessory power (RAP) circuit breaker located in the underhood Maxifuse® block.
Could be a simple problem , but one never know's till they do all the testing .
Electric Testing Techniques You Need to Know
Common Repair for Chevy Olds Pontiac Power Door Locks
Dec 07, 2017 | Buick Cars & Trucks
Tip
Whirlpool duet F70 and F71 error codes.
F70 and F71 are two logic board error codes that point at a communication error between the main logic module and the control pad (user interface and CCU), and between the motor control unit and central control (MCU, andd CCU that is main control module).
Repair is difficult, as motor, wiring and voltages from control modules must be tested.
Try first doing a reset, by disconnecting power cord or tripping circuit breaker and leaving power off for five minutes.
If that does not help and errors come back, then the best thing to do is calling the service number listed on the user manual.
Here extensive explanation of error codes and relative troubleshooting:
F70: CENTRAL CONTROL UNIT HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving
F71: USER INTERFACE HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
4. Replace Central Control Unit if drum is not moving.
To get parts and diagrams try entering the full model number in one of the websites below:
Enter the model number ..
To contact a repairer, call the number listed on the owners manual or use the Fixya directory (US only)
on Nov 05, 2010 | Whirlpool WFW8300SW
Turn signals do not work, have replaced module, still do not work
Find a wiring diagram an get a DVOM - digital volt ohm meter an do some electrical testing . Videos on you tube on basic automotive electrical testing , how to read a wiring diagram . Then go http://bbbind.com/free_tsb.html free wiring diagrams . What component controls windows an door locks , I know what does , what to see what you think does . The speedometer not working is probably the step motor inside the instrument cluster . New instrument cluster ! Replace the turn signal switch.
The vehicle is equipped with power door locks. Each lock actuator is powered and controlled by the door module mounted in the individual door. The driver door module (DDM) is the master control for the door lock system but the rear integration module (RIM) contains the program that determines when the lock functions are permitted.
The vehicle is equipped with power windows controlled by the door modules. The DDM receives a window switch request, over the SBI serial data, from either the passenger door module wired to the window switch pressed or from the driver door switch assembly. The DDM checks the Class 2 serial data to see if the status information is correct (i.e. ignition switch position) to permit window operation.
If the status information to permit window operation is correct, the DDM sends the command to the door module controlling the window to move the window as requested.
Windows Power and Ground
The windows are powered by discreet power and ground circuits. These circuits are in the same dedicated connector as the window motor drive circuits.
These systems are very complex and are able to set DTC'S in the controlling module .Your best bet is to take your vehicle to a qualified repair shop .
DTC B3142 LF Unlock Switch Circuit Low DTC B3147 Passenger Unlock Switch Circuit Low DTC B3152 LF Lock Switch Circuit Low DTC B3157 Passenger Lock Switch Circuit Low DTC B3172 RF Window Up Switch Circuit Low DTC B3177 RF Window Down Switch Circuit Low DTC B3182 LR Window Up Switch Circuit Low DTC B3187 LR Window Down Switch Circuit Low DTC B3192 RR Window Up Switch Circuit Low DTC B3197 RR Window Down Switch Circuit Low DTC B3377 LF Window Up Switch Circuit Low DTC B3382 LF Window Down Switch Circuit Low DTC B3387 RF Window Up Switch Circuit Low DTC B3392 RF Window Down Switch Circuit Low DTC B3397 LR Window Up Switch Circuit Low DTC B3452 LR Window Down Switch Circuit Low DTC B3457 RR Window Up Switch Circuit Low DTC B3462 RR Window Down Switch Circuit Low DTC B3467 LF Window Express Down Circuit Low DTC B3472 RF Window Express Down Circuit Low DTC B3527 Window Lockout Switch Circuit Low
DTC'S are intended to point the qualified technician in the correct diagnostic path. You may have a communication or network problem . Are you familiar with class two serial data bus communication network . The simple bus provides a means for information exchange among the vehicle door modules. Door module information on inputs and commanded outputs are converted to serial bus interface data for exchange among the door modules. The DDM can also take information from modules connected to the class 2 serial data circuit and relay the command to the simple bus interface. The vehicle power mode message (ignition switch position) from the DIM is an example. The DDM periodically addresses each module on the simple bus interface. When a module does not respond to the DDM, the DTC for that module is set. You can't just replace these modules , some need to be programmed . Dealer only ! First check codes , power an grounds etc....
Jun 29, 2016 | 2000 Buick LeSabre Custom
Can I have optical ports on CISCO1941?
Yes, but you will need to add interface card EHWIC 1GE SFP CU, in addition to the interface card, a SFP module will be required to make the optical ports working.
Jan 30, 2015 | Cisco 1941 Router - CISCO1941-SEC/K9
I have a front loader MHWE3000VW12 it's giving me a code F70 Ineed to know what it means
Thanks
Jul 26, 2012 | Maytag Washing Machines
Whirlpool duet getting error code F70 and F71. When hitting start button, getting a clicking sound and nothing is happening. Cannot open the washer door as it is locked with clothing inside it.
Hi jreib29,
Hope this helps.
Thank you for using FixYa.
Sep 17, 2011 | Whirlpool Kitchen Ranges
ZyXEL IES-1000 with AAM1212 ADSL 12 port module step-by-step guid
Going through the GUI would take too long, so use CLI to add the commands below. After that, check the GUI and see how those changes appear.
VLANs:
On all equipment use 802.1q tagging. The example below puts adsl ports 1 to 10 in vlan10 and ports 11-12 in vlan2. These vlans are 802.1q tagged on the ethernet ports.
switch vlan set 1 1~12:X enet1~enet2:FT DEFAULT
switch vlan set 2 1~10:X 11~12:FU enet1~enet2:FT VLAN2
switch vlan set 10 1~10:FU 11~12:X enet1~enet2:FT VLAN10
switch vlan set 17 1~12:X enet1~enet2:FT VLAN17
switch vlan pvid 1~10 10
switch vlan pvid 11~12 2
switch vlan pvid enet1~enet2 1
switch vlan priority * 0
switch vlan gvrp * disable
switch vlan frametype * all
switch vlan cpu set 1
ATM circuit:
Each port requires one or more VPI/VCI circuit. You could map different circuits to corresponding vlans. The config below creates a primary circuit 1/35 on each port. On ports 5 and 9 is another circuit 1/32 mapped to vlan10
adsl pvc set * 1 35 super DEFVAL
adsl pvc set 5,9 1 32 10 0 DEFVAL
Remember a dslam is just a switch, bridging packets from a VC onto a VLAN or straight onto ethernet.
Mar 27, 2009 | Zyxel IP Express IES-1000 (91004098002)
All 4 ignitors just stopped working on the stove top...no more 'clicking' sounds
1 Check to be sure unit is properly connected to power supply.
2 Check for a blown circuit fuse or a tripped main circuit breaker.
3 Check to be sure ignitor is dry and clicking. Burner will not light if ignitor is damaged, soiled or wet. If ignitor doesn’t click, turn control knob OFF.
4 Burner ports may be clogged.
Dec 03, 2007 | Maytag MGR6775 Stainless Steel Kitchen...
HDMI Signal gone
The HDMI interface may have suffered a malfunction, this offten happens due to stray voltages on the ground plane. If you do not have electronics experience I would suggest taking the set to the shop and having it repaired
Aug 24, 2007 | Panasonic PT-52LCX65 44" HDTV
Firewire port
If the physical connector is broken, replacement cost for that part is about $30.00 (connector is mounted on a circuit board which needs to be replaced.) If the connector is good, but the firewire interface in the camera is bad, repair involves replacement of the main circuit board, which is between $400 and $500. These are parts costs, they don't include labor.
Aug 17, 2007 | Panasonic AG-DVC30 Mini DV Digital...
Lands Phones Logo
24 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
