Question about Tomtom GO 910
Computor does not reconise my tomtom go 910 satnav says formatting failed computor says usb device has failed
  • TED47SM Nov 13, 2009
    The problem remains
    Pressing the tt910 reset button did not help
  • 4,806 Answers
Try to reset the Tomtom.
Turn the unit off and remove the USB lead or the connector with the suction cup on it.
Turn the Tomtom upside down with the rear of it facing you. Look inside the back of the unit where the brass pins are.
Now look very closely in front of the brass pins for a very small hole which will be on the left hand side. Get a paperclip or pin and push it in that hole for 20 seconds.
That will reset the tomtom. Just turn it back on and connect it to your computer.
Hope this helps and good luck.
Posted on Nov 13, 2009
  • Lee Hodgson
    Lee Hodgson Nov 13, 2009
    Just a quick question.
    Have you got TomTom Home installed on your computer?
    President:
  • 1,653 Answers
Power on the TT 910 and then press the Reset Button on the base of the TT. It is a tiny hole with a hidden button. use a rounded object, match end or soft pencil to puch the button. Then reconnect it to the PC and the PC will see the TT. Note that you may have to reload apps and maps depending on the state of the TT.
  • Karl Wright
    Karl Wright Nov 13, 2009
    Reinstall the TT software on the PC, it has been updated recently, and reboot then plug in the TT. Turn on the TT and all should be OK.
GO 910 GPS Receiver: tomtom 910 formatting when turned on...
#1
Insert your ( memory card , flash disk , cellphone , .... ) into your computer.
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
May 18, 2010 | Tomtom GO 910 GPS Receiver
Nothing happens when i plug my usb cable into my computer with the tomtom ONE
start tomtom home if it does not start automaticlly when you turn on your tomtom and connect it to your computer..if you dont have tomtom home, you can get it HERE.
if its still not connecting try another usb cable although im not sure in that one disconnects from the home dock on the 910
( i assume your using the home dock because thats the only way a 910 will hook up to a computer)
Nov 04, 2009 | Tomtom GO 910 GPS Receiver
Tomtom 910 sat nav.
Complain to Tom Tom ,you may have a lemon,look for law suit soon
Mar 25, 2008 | Tomtom GO 910 GPS Receiver
Tomtom 910.
Mar 23, 2008 | Tomtom GO 910 GPS Receiver
Problem with conection tomtom 910 to PC
Feb 22, 2008 | Tomtom GO 910 GPS Receiver
Tomtom 910 help please
1 Have you got Tom Tom home installed on your PC?
2 Have you got Tom Tom in the home 'cradle' with the usb lead attached?
I have both and have no proba at all
Feb 03, 2008 | Tomtom GO 910 GPS Receiver
Tomtom 910
hold the on button (top left skinny button) for 2 seconds. And if that doesn't work, use a TINY pin to reset the unit.
Jan 12, 2008 | Tomtom GO 910 GPS Receiver
Tom tom go 910
TOM Tom no charge and will not turn on
leave on charge for two hours, then with the SD card out hold down the reset button at the back of unit for ten seconds and then the 'on' switch for ten seconds.
STEP 1
Connect your TomTom to your
computer True True (``````````` (``````````` 0 95250 95250 clip_image002.gif via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the
backup True True (``````````` (``````````` 0 95250 95250 clip_image002.gif you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Oct 29, 2007 | Tomtom GO 910 GPS Receiver
TomTom 910 charger question
Yes, you can.
I presume the charger has an USB connector.
5v and 2A are the correct figures for a Go910.
Aug 24, 2007 | Tomtom GO 910 GPS Receiver
Tomtom GO 910 Logo
329 people viewed this question
Top Tomtom Computers & Internet Experts
nix_bid
Level 1 Expert
Tom Chichester
Moazzem Hossain
Moazzem Hossain
Are you a Tomtom Computer and Internet Expert? Answer questions, earn points and help others
