Question about Linksys Computers & Internet
Linksys wireless 2.4GHZ router cant connect...just stopped...unsure what to do to reconnect
  • brad_melissa Nov 13, 2009
    i have attempted this many times and also have pressed the reset button
    what to do next, I have lanline
    Sergeant:
    Champion:
  • 219 Answers
The first step to reconnecting is to power off the router and leave it for a couple minutes. Power the router up and leave it for a minute or so before trying to connect.
If that doesn't work you need to log into the router and check the settings. If you can't connect by wireless you will need to use a lan cable for this step.
If you need any help through this post a comment!
Posted on Nov 13, 2009
  • dwane4444
    dwane4444 Nov 13, 2009
    OK I need the Linksys model No.
Describe your Wireless-G WRT54G Router Problem trying to reconnect my wireless router to cable use to have dsl cant get no connection
Is it saying network cable unplug on the lower right corner of your screen?. You might need to use other port from your router or use a different ethernet cable.
Aug 24, 2011 | Linksys Wireless-G WRT54G Router
Hi i bought the smc wireless router and i tries to connect it but i couldnt figure out how to connect it because i have a laptop and my internet is connected from my modem to my laptop but i cant seem to...
I'm unsure of the exact part number here but using the model number I checked the manual. This looks like it's just an access point which extends a current network you have. If you only have your laptop, this device and your internet modem it may not give you the wireless connectivity you're looking for. On a normal setup you would plug your modem into a router, plug your laptop into the router and set it up with all your DSL/Cable connection information as well as wireless on/off. You can then unplug from the router and continue life. with this one it's only connecting to an existing setup (another router or another wireless network) and extending it.
If you are looking for a solution to give you a router that connects to your modem and gives you wireless or adding multiple devices on a single connection I would recommend returning this and getting an all-in-one router such as this: http://homestore.cisco.com/en-us/Routers/Linksys-E1000-Wirelessn-router_stcVVproductId97826160VVcatId551966VVviewprod.htm?icid=linksys-specs-e1000-learnmore-btn&src2=linksys-specs-e1000-learnmore-btn
Mar 07, 2011 | SMC EZ Connect g SMCWEBT-G
Laptops stopped connecting wireless
how about to reset your router and setup it the proper address by your internet provider..
laptops only connect to the router automatically if you enable it reconnect and detect its network without manually connect internet, this procedure can see in your wireless properties by enabling it.
And also ask your internet provider if theres a problem also with their internet connection.
Jul 18, 2009 | Linksys WRT160N Wireless Router
Cannot connect to wireless router
Make sure you are connected via hardwire connection. Restart router and select 'Start->Run' and enter 'ipconfig -renew'. If you are still not able to reconnect to router try pressing and holding the reset button on the back. This will restore it to the default settings including username and password.
Feb 14, 2009 | Linksys Wireless-G WRT54G Router
Limited connectivity
You have to turned on DHCP in your router settings. i think its under the General TAB if its a linksys router
Feb 03, 2009 | Linksys Wireless-G Broadband Router
Have wireless connection, but can't get online
Linksys wireless router has many bugs: connection issues like no connection or constantly having to reset the router. It isn't compatible with many network adapters. Hope this helps!
Jan 25, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Getting wireless computor and router back on line with desk top computor
1. Disconnect power from your modem and router
2. Connect an ethernet cord from your modem's ethernet port to your router's Internet or WAN port.
3. Connect another ethernet cord from a port on your router (labeled with a "1" above it).
4. Connect power to your modem and router.
5. I'm a little unsure about how you plan to connect your wireless computer to the router. The router you selected when you created this question is not wireless-capable.
If your router is wireless-capable, go to the wireless computer. Follow the instructions for your operating system below.
Windows XP
1. Right-click on the My Network Places icon on your desktop, and select Properties.
2. Right-click on Wireless Network Connection.
3. Right-click on View Available Wireless Networks.
4. Double-click on your network from the list that appears (it should be called "linksys" if you didn't change the name).
Windows Vista
1. Click on the network icon on the lower-right of your screen (it should look like two computers with one behind another. It might have a red "X" over it.)
2. Click "Connect to a network" (it also might be labeled "Connect or disconnect")
3. Double-click on your network from the list (it should be called "linksys" if you didn't change the name.
Mac OS X
1. Click on the AirPort menu in the upper right of your screen (it looks like "("s turned on their side).
2. Click on your network in the list that appears (it should be called "linksys" if you didn't change the name).
Sep 30, 2008 | Linksys EtherFast Cable/DSL Router
Computers & Internet Logo
27 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
