Question about Belling 644 Electric Kitchen Range
Oven won't work!
It's a Format... I think It's a 644 but maybe a 648. Just moved in and switched it on at the wall. Hob and top oven/ grill works, but main oven doesn't. Light doesn't come on, or the fan. Also, the digital display doesn't change when I press the buttons. 0.00 and AUTO flash alternately. No manual either. Please help!
Denise (UK)
  • Anonymous Mar 18, 2014
    hob is working, but grill/top oven and main oven not working and display not working
    Problem Solver:
  • 7 Answers
Timer must be set to any time of day for ovens to work, niormally you need to press either 2 or 3 buttons together to set time, if this fails you need to bypass the timer ele ctrically
Posted on Jan 08, 2008
Fuse keeps tripping
tripping a circuit breaker indicates a dead short or insulation failure
not being able to move the main switch indicates that the contacts inside are burnt together
only option is to call an accredited electrician to test the circuits and rectify the fault
tell him to bring spare elements is case on e or both have burnt out
Mar 27, 2017 | New World Ovens
Having taken the oven out to fix a problem with the hob (720EF double oven and grill), reinstalled the oven and powered –up, the clock won’t come on and stay on, the oven and hob appear to work! Any...
Both the top and bottom oven will only work if a time (any time) has been set on the clock. Setting the time operates a contact to switch the power through. The only exception is the grill. This will work even if the time has not been set. So if the oven controls/lights and heating work, to me it means that the clock/timer is half working and the only thing that isn't is the display.
I haven't had the clock/timer to bits but a fellow blogger has said that in some timers there is an electrolytic capacitor that controls the display. When this fails as they are renowned for doing, the dispaly mal functions. If there is one then Maplin have some - VHR41W/43W and DT64U depending on value etc. Let us know how you get on.
If you need a new clock/timer they are around £80 from espares.
Jan 03, 2011 | Stoves 720EF Electric Double Oven
MY STOVES COOKER'S OVEN AND GRILL HAS STOPPED WORKING?THE HOB IS WORKING FINE.
The hob is normally totally independent of the oven. What is actually working or not working on the oven? i.e. does the grill still work, is the clock OK and can you set it, or is everything totally dead?
Oct 16, 2010 | Stoves 720EF Electric Double Oven
The top oven of our AEG D5701-4 is slow to heat.
Hi it could be the element on the grill it maybe burning out, what slows the grill to get hot quicker. best to turn of the mains or by the main switch. and get a toorch to check around the element or use a continental reader check if it is receving 240volts
Mar 09, 2010 | AEG D5701-4 Electric Double Oven
My bottom oven isn't working at all but top oven/grill and hob is working fine
If nothing is working in the bottom oven (no fan, no light, no heat) then it is most likely the oven selector switch is faulty.
If you have a light and or fan and they are working, it is a failed oven element.
Jan 15, 2010 | Ovens
Fan in main oven boken
Sounds as if your oven heating element has failed. You need to fit a new one.
Usually you have to get the back off, disconnect the old element, remove the fixxing screws and element, fit new one, reconnect and it should be fixed. Don't forget to switch the power off before starting work.
Dec 31, 2009 | Zanussi Ovens
Oven not working! Belling 614 format
the control modual is bad the oven want work without it
Jan 09, 2008 | Belling 644 Electric Kitchen Range
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Oven not working properly
It may be the oven thermostat needs replacing.
Jan 29, 2007 | Belling 644 Electric Kitchen Range
Belling 644 Electric Kitchen Range Logo
417 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
