Question about Samsung SP50L6HX 50" DLP HDTV
There is no output from the lamp. on startup we get a 2 second burst of audio but no picture and that is it. the bulb is a genuine philips replacement. I have measured the voltage at the bulb plug and it shows about 15v. At the side of the bulb assembly is a enclosed assembly with a fan on it and that is showing a red led which momentarily goes out when it tries to start.
  • Samsung Master
  • 5,138 Answers
If the Lamp is New and TV will not come on Ballast board it is what turns Lamp on. Call Encompass Parts 1-800-638-3328 Ballast is connected to Lamp
Posted on Jan 14, 2010
I have bought 3 lamps, ranging from $35 to $98 and the tv picture is still not working properly. I am about to order another lamp, cost $189. is it just all bad lamps?
buying cheap lamps is never a good idea. they use knock off bulbs that rarely if ever work right. go to www.projectorlamps.com and talk to them. they only sell lamps with real bulbs inside. Genuine Osram, Philips and Ushio brand. No knock off junk like everyone else. Projector Lamps and TV Lampson Sale ProjectorLamps com stocks Superior...
Sep 30, 2015 | Televison & Video
Bulb or Ballast?
If your old lamp is still working fine and the new lamp is not, then you bought a defective lamp. Get your money back or exchange the lamp.
May 17, 2012 | Panasonic PT-52LCX66 Projection Television
I have a Philips 50PL9126D/37. I began having my screen go black (audio still playing) and a red light appeared in my blue power button. I removed the back of the television and checked the lamp, which was...
You cooould have a bad ballast, but it's probably either that you put the lamp in wrong, or you have a defective lamp though. There's a 33% chance that any of those are the case. Unplug the TV for 30 seconds. Plug it back in. Try turning it on again. Make sure you didn't over tighten the lamp during install. Especially the screw on the side. It should be a tight connection. Send the lamp back and get a new one. Usually they come with a warranty. If the new one doesn't work, it's either the ballast, or the power supply.
Jun 16, 2011 | Televison & Video
The picture goes off, the power/standby light
Sony KDF-60XS955 picture goes and power/standby light light flashes
Most likely you have bulb failure. First step in troubleshooting is "Change the Lamp or Bulb". Lightning, power line bumps and collisions with vacuum cleaners can all shorten lamp life. Rough handling in shipment can also happen without your knowledge.
+90% of all Sony LCD Rear Projector "No Picture or Intermittent Picture" faults are related to bulb failure.
If new lamp does not improve the situation, then hands-on troubleshooting by someone that has parts and knows how the unit works is the only practical remedy.
easyab
Mar 14, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Replacement Lamps/Bulbs for Philips 50P8341 Rear Projection TV
These are both CRT type TV's(3 picture tubes drive the image) with different screen sizes and the CRT's are not interchangeable
Oct 24, 2009 | Philips 50P8341 50" Rear Projection...
Wrong model number listed in my original question
I gave you exact and correct lamp part number of KDF-E55A20 and explained in previous reply that there is no difference between XL-2200 and XL-2200U lamp. both are same, first on came with new TV and second one is its replacement number.
KV-36FV26 is CRT TV and has no lamp inside.
May 18, 2009 | Sony KV-36FV26 TV
Lamp reset.
there are 2 clocks 1 for lamp and 1 for total, the total you cant change. dark picture, make sure your got same wattage lamp for replacement, I find original Philips lamps the best. if it continues follow manufacture instructions on cleaning mirror and lens.
Apr 12, 2008 | Zenith E44W46LCD 44" Rear Projection...
Bulb Shattered...After replacement does nothing!!!!!
Did you get any anwsers as I'm having the exact same problem with my projector, the noise for few seconds, the light flashing...
Thanks
Dec 19, 2007 | InFocus ScreenPlay 4805 Multimedia...
Samsung SP50L6HX 50" DLP HDTV Logo
61 people viewed this question
Jerry Greenberg
Jerry Greenberg
