Question about Fujitsu CELSIUS R630 PC Desktop
Sir, i am loading the software in this but after loading itwhen I check the hard disc, it shows that it doesnot have any data in it. Is there a software problem or may the steps which I follow to load are missing
    Sergeant:
    Champion:
  • 202 Answers
Its ur fault, u installation step is not correct, if ur system os wrking ok,.
plz chk, to install in othr system. if it install on it, tht's ur fault, or os fault, or other wise
itz software problem
Posted on Nov 14, 2009
External hard drive 3,5" few months it was working properly, and it says usb device not recognized and it doesnot show up. please for solution
Hello sir/ma'am, hi, most likely you have cable problems, check and see if you can find another cable. The cable is the USB data cable, that connects from your PC to the external hard drive.
Please also check if your USB port is working fine, just simply plug in a thumb drive to confirm.
If its not the cable, its the external hard drive. Usually, the red light appears or the device is reading the drive continuously with no action. let me know your progress.
Aug 13, 2010 | Verbatim VER95327 USB Hard Drive
Failes to start
try booting the computer in safe mode by pressing F8 and see if that works if that doesnot work then you need to do a windows installation kindly arrange from any computer shop
Dec 24, 2009 | Acer Aspire 3050 Notebook
We are unable to load window xp on hard disc, before we only find the 32 GB in 80 GB hard disk ... we successfully installed the window xp, but when jumper setting done in accurate place, it shows 80 GB,...
I think this model is still an IDE type. You set the 32GB limit then jump the settings to read the full capacity of the drive. If you are trying to load XP OS from a blank drive.
First prime the hard drive, you can do low level formatting and use third party software to partition and format the drive. on FAT32 partition you can only use 8GByte to make the drive bootable. Make it primary if I remembered it correctly and active. Or use the NTFS format.
You can use also if it have the manufacturers' hard drive utilities to check the hard drive integrity. I know they have it. It also equip with zero fill to renew chain and links of the drive. Then partition, format, primary and active. Then load your OS.
Check also your CD disc integrity, scratches do make a lot of troubles. And also your cdrom/dvdrom drive.
Oct 27, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Sigmatel fxd mobile data cable not working
Have you loaded the sinc disc supplied with handset to computor? Have you actually installed it? Ensure S/W compatability etc. Using correct USB data lead?
Jul 02, 2009 | Lands Phones
Getting message "pls insert disk in drive" on inserting the USB
Hello sir/Madam,
You can recover by doing the following:
go to transcend website and download this software;
(http://www.transcendusa.com/products/online_recovery.asp) and then you have to select repair and save data..
andthen also if you dont get ur full data,you can download Pen driverecovery from many sites(search on google) and recover or else email meat devgolani@gmail.com for full software..
Regards
Devesh Golani
devgolani@gmail.com
http://www.lifeproblems.uni.cc/blogs
Mar 10, 2009 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
Disc restarts computer
Hey Soumik,
You would be getting this problem due to:
1. ROM memory inside your CD/DVD Drive is not recognised by ur BIOS.
2. Would be problem with ur data cable connector.
3. Settings changed in your BIOS.
When you are inserting any cd or dvd in your drive some times it happens that ur rom memory does not load that much required files in itself.
You need to do the following:
1.First of all check ur bios settings for boot priority likewise FDD, CD/DVD Rom, HDD.
2. increase your Virtual memory that if the ROM bios is not able to load required files then it'll be loaded in virtual mem.
To increase virtual mem. follow following steps:
i. Right click my computer and select properties.
ii. Go to Advanced Tab and then select Settings button of "Visual effects, Processor Scheduling.....and virtual memory"
iii. Again select Advanced Tab
iv. In Virtual memory section select change
v. Uncheck the option for automatically manage paging file size(if it is checked)
vi. Select custom size and type initial size as 1736 and maximum size as 2048
vii. click set button click OK if any confirmation is asked.
viii. Click OK to apply the settings.
ix. Restart ur system.
3. If this doesnot take effect to ur problem then you must be aware of data cables. Try out another data cable of ur hard disk.
as well as Power cable. and then insert disk to checkout whether it is ok or still giving u the problem. if it is then there is no problem with either your system or with data cables and connectors. Replace the DVD/CD Drive.
Aug 04, 2008 | Microsoft Windows 98 for PC
DVDhandycam software lost
What is the model number of your Sony camera and the PC operating system?
Apr 14, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
Can the disc of a external harddrive be change to get your data recovery back
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Jan 14, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Software is deleted
my mp3 players software is deleted when i was downloading songs.now when i put the player to my computer it doesnot show the folder(drive)which previously was present.after this happended my player shows written in it disc error whenever i try to play the mp3 player.but the fm radio is working .so if you coukd assist in solving this problem
I need to know the website address for my logik mp3 player and voice recorder so i can download and reinstall its software. i can't find it
Dec 10, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Fujitsu CELSIUS R630 PC Desktop Logo
56 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
