Question about Neff U1421 Double circotherm Electric Oven
I have a Neff U1721 circotherm oven. The lights come on and the fan works but it does not heat up. What could be the problem?
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
For all Free appliance repair videos visit our VIDEOTUTORIALS Nefffan oven element video1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Posted on Jan 12, 2010
  • Neff Master
  • 3,463 Answers
If the fan is working o/k, and it is an electric oven, then you need to fit a new oven element locted behind removeable cover at rear of oven compartment.
Please leave feedback.
Thanks.
Posted on Nov 13, 2009
Neff oven not heating have replaced fan element
it has to be the temperature control itself...thats the only other component, aside from the high-heat cut out switch which rarely goes bad.
Jun 05, 2010 | Neff U1721 Double circotherm Electric Oven
Lower oven not giving out any heat, fan working, light working
If fan is working ok, then you need to fit a new oven element, located at rear of oven behind a removeable cover.
Please rate my soution.
Thanks.
Nov 18, 2009 | Neff U1721 Double circotherm Electric Oven
Main oven fan is working. red light showing but oven not heating.
If the fan is working o/k, then you need to fit a new oven element, located at rear of oven behind removable cover.
Please rate my solution.
Thanks.
Oct 09, 2009 | Neff U1721 Double circotherm Electric Oven
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
Neff U1721 Double Oven - No Heat
If the fan is running then it is unlikely to be the clock/timer. Yopu need to check if there is voltage to the element but you MUST be careful to avoid an electric shock. There is sometimes a thermal cut out in line with the supply from the thermostat and that would need to be checked. If all OK the thermostat is the likely offender
Oct 13, 2008 | Neff U1721 Double circotherm Electric Oven
Neff u1721 fan door problem
yes it is a heat resistant adhesive and ive never had any success in regluing them
Nov 06, 2007 | Neff U1721 Double circotherm Electric Oven
Neff single oven
fan heating heating element gone replace it ;Ire close bye
Sep 04, 2007 | Neff U1721 Double circotherm Electric Oven
Neff U1421 Double circotherm Electric Oven Logo
490 people viewed this question
Top Neff Ovens Experts
ashburton
paulcarew
bobby1964
Level 1 Expert
Are you a Neff Oven Expert? Answer questions, earn points and help others
