Question about De Dietrich Ovens
The oven light on our FX5847 will not go out when the door is closed. I have manually pushed the switch when the door is open but it stay alight. Any ideas? Derek Tisdall
  • De Dietrich Master
  • 3,463 Answers
It sounds like the switch contacts are stuck together, If I were you, I would fit a new door switch.
Please leave feedback.
Thanks.
Posted on Nov 13, 2009
  • Finbarr Murphy Nov 03, 2011
    Had same problem but switch seems broken. Where do I get a new switch. Dublin
Our electric convection oven heats up and when you open the door and close again it no longer heats, fan stays on and the light goes on when door open and off when door is closed, any ideas?? Thanks
Hi, You can look at the micro switch on the oven door, sounds like it might have been installed on a normally open auxiliary rather than a normally closed aux. hope this helps
Oct 09, 2014 | Ovens
GE JKP28 oven light is always on
It is possible the relay for the light on the control board has welded points. A door switch could be bypassing the control. keeping the light on when the door is closed. Hope this helps.
Feb 10, 2014 | GE JKP28 Electric Double Oven
Oven light will not turn off
Welcome to FixYa.
Does the light shut off if you push the door closed slightly ? Or if you push the door switch closed manually. It is located on the grill of the oven...i.e.
Let me know, if so the door hinge needs adjustment. If not, it may be a control issue.
I'll watch for your reply.
Macmarkus :)
Jan 03, 2011 | Thermador SC302T Electric Double Oven
I was able to clear the locked door message, and get over working following steps above, but cannot get the lock mechanism to release, and therefore cannot close the door
Check out these steps at the following link... http://www.geappliances.com/search/fast/infobase/10004586.htm
Range - "LOC DOOR" flashes in the display
If "LOC DOOR" is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
Motorized Switch
Manual Switch
    2. Close the door.
    5. Unlock the door.
Nov 24, 2010 | GE Profile JTP18 Electric Single Oven
Oven doors will not close properly
Most of these I have seen have to have the hinges and recievers replaced to get the doors to close properly and keep the light off.
Apr 17, 2008 | Ovens
5 year old Jenn Air double oven
the door switch contacts are stuck closed causing the oven to stay on.if you can access the door switch try to wd-40 on it.if that doesnt help you need a door switch.
Aug 16, 2007 | Jenn-Air JMW9527C Stainless Steel Electric...
Ovens Logo
105 people viewed this question
Top De Dietrich Ovens Experts
ashburton
Shehu Pro
Shehu Pro
Electro Med Services...
Are you a De Dietrich Oven Expert? Answer questions, earn points and help others
