Question about Kenmore Refrigerators
Have kenmore refig model 59671103101 refrig temperature to low. light work, fans run freezer works good. Cleaned vents & coils ?
  • 2,237 Answers
If the freezer is fine, check for air flow to fridge. if you get none, see if there is any frost on the back wall of the freezer. if there is some frost, the coils are iced up and need thawing. if there is no frost, there may be an obstruction in the vent. also may be thermostat in fridge- it opens and closes the vent from the freezer.
Posted on Nov 13, 2009
We've just returned from having the refrig off for 5 months. The fan is working, but the refig is warm and freezer freezes. We just have soda cans in the refig. WAZ ZUP? Kenmore # 70852991 Mgt 2001 ...
freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Nov 12, 2010 | Kenmore 64802 Top Freezer Refrigerator
Kenmore refrig/freezer. freezer side is cold,
Check your condenser coil (should be below the refrig.). If dirty, you can clean it with a condenser brush from Home Depot or Lowe's. Turn the appliance off while cleaning. Be careful not to damage the refrigerant tubing (copper). If this doesn't solve the problem, then there may be an issue with the defrost thermostat, defrost heater(s) or the main temperature control assembly.
Contact an appliance service company.
Feb 17, 2010 | Kenmore Refrigerators
Frigidaire top-mount refig. freezer won't get cold ,temp.stays around 26 degrees, refrig. don't keep milk cold enough
check that the evaporator fan motor ,located in freezer is working.it circulates the cold air.also check that the coils behind freezer back panel are not iced up,this would indicate a lack of defroting due to,timer,heating element,or bi-metal.lastly when the refrig is running those coils should get frost over them all,if not you may be low on refigerant
Jan 20, 2010 | Frigidaire FRT17G5CSB Top Freezer...
My kenworth refrigerator (model 59671103101) does not stay cold on top. I cleaned the coils and the lights, fan and freezer works.
you need to replace the main control board, but w/o a model number and make,( you mean it's a kenmore,not a kenworth) I can't give you a board number
Nov 14, 2009 | Televison & Video
We have a refig.. with top freezer. Freezer works fine, refrig. is not working, motor still runs when turned up. About 8 years old. What could be wrong?
Make sure the fan in the freezer is running. if it is . More than likely the vent has ice in it. take the bottom out of the freezer and you can get to it. throw the ice and then check the drain. is right behind the vent.
Sep 23, 2009 | GE Refrigerators
The fridge portion is not cold, the freezer normal, I cleaned out the coils, they were dirty. What are the problems. Thanks Rusty
Could be a few things. Find the refrig vent that comes from the freezer into the refrig, usually it is in the upper left corner of the refrig compartment but could be in a few other places. When the unit is running make sure you feel air coming out of that vent. If not you probably have an issue with the defrost cycle and the coil in the freezer is iced over and blocking the air. Also check to make sure the evaporator fan in the freezer is running. Feel for air at the vents in the freezer and listen for a fan running.
Sep 08, 2009 | Kenmore Refrigerators
Cleaned coils,lower fan, drain lines. Checked door seals, temperature reset, both fans are runnign but
Need a New Compressor. That is the only way of Cooling. If it was working and not cooling it could be the Condensor or low on Freon.
May 12, 2009 | Refrigerators
Freezer works, refrig does not cool
hi they only thing that could cause this problem is dirty coils at the back.clean all the coils at the back. thanks the appliance doc.
Oct 17, 2008 | Kenmore 50522 / 50524 Side by Side...
Kenmore 50392
We were low on freon . This refrig's internal fans don't run until the proper temperature is reached
May 21, 2008 | Kenmore 53092 / 53094 Side by Side...
KENMORE TRIO 2004 59675523400 REEFER/FREEZER NOT COOLING
It is the compressor that has failed. The hum is it trying to start and the following click is the overload protector opening. What is the temperature where the refrigerator is located? Allow the compressor to cool down before trying to restart it. If it still does not restart after it has cooled off it is done.
May 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
146 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
