Question about Lexmark C510 Laser Printer
Error message reads "34 short paper". What does this code mean and what can I do to correct it? Thanks
  • Official Brand Answer
  • 3,344 Answers
This error means that the type of paper that is configured in the printer is different from the one you have chosen in your computer to send for printing. Make sure that the paper size is the same in both places the computer program you are using and the printer. For example if I have a Letter size word document that I want to print but the printer has A4 configured then I will get the 34 short paper error but If I change the paper in the printer and the setting to letter size then everything should print fine.
Posted on Feb 01, 2010
Lexmark C510 34 short paper error
The error means that the printer has determined that length of paper in source specified on second line of display is too short to print formatted data. If this error occurs again, press Go to clear message.Ensure paper size setting in paper menu is correct for paper size.
Dec 04, 2012 | Lexmark C510 Laser Printer
HELLO. I HAVE A GE MICROWAVE MOD JE1860WB. THE MONITOR READ "F3" CODE. WHAT IS THAT?
The F3 code means that the Key panel also called touch pad is shorted. This code usually comes up when when the Microwave detects the shorted panel continuously for over 60seconds.
To correct this error, you have to Replace the key panel also called the touch pad.
Thanks.
Sep 14, 2011 | GE JE1860 Microwave Oven
T632 printer error : 34 short paper. What does that mean? Don't see 34 as a valid error code.
This error message means that the printer has determined that the length of the paper in the source specified on the second line of the display is too short to print the formatted data. For auto-size sensing trays, this error occurs if the guides are not in the correct position.
Please try to do the following
? Press Go to clear the message and continue printing. The printer does not automatically reprint the page that prompted the message.
? Make sure the Paper Size setting in the Paper Menu is correct for the size paper you are using. If MP Feeder Size is set to Universal, make sure your paper is large enough for the formatted data.
? Press Menu to open the Job Menu and cancel the current job. Please see also the media guidelines on the user manual p.29
For further assistance, please contact Lexmark Technical Support.
Aug 02, 2011 | Lexmark T632 Laser Printer
• Press Go to clear the message and continue printing. The printer does not automatically reprint the page that prompted the message.
• Make sure the Paper Size setting in the Paper Menu is correct for the size paper you are using. If MP Feeder Size is set to Universal, make sure your paper is large enough for the formatted data.
• Press Menu to open the Job Menu and cancel the current job. Please see also the media guidelines on the user manual p.29
Apr 21, 2011 | Lexmark C543DN Laser Printer
Depending on which paper tray you select, one of two error message is flashing on the readout: E70 or -A4. We cannot detect a paper jam. What do these codes mean and how do we correct it?
the error means that the size of the original does not match the size in the paper tray. select the tray you want use withe paper select key then make your copies
Feb 14, 2011 | Copystar CS-1500 Copier
1995 jeep grnad cherokee codes 34 55
34 = speed control circuit. The solenoid for the speed control is not operating correctly, due to a defective solenoid or short in the wire connection. 55 = end of diagnostic message's.
Sep 20, 2010 | 1995 Jeep Grand Cherokee
Printing blank pages on Lexmark C510 printer. Throws a 34 Short Paper error first, prints out a blank page. I have replaced the black toner, but problem continues. Demo page printed colors successfully but...
For 34 Short Paper error, reseat the tray guides and make sure it is set properly. Also, set the correct settings in the computer. For blank pages, always double-check the paper settings and again the settings in the computer. For not printing black, print the Print Quality page and see what color is not printed or not showing. If Print Quality shows black, try printing any document from any application in the computer. Check if you still have the problem. If problem is not resolved, leave a comment so I can get back to this.
Apr 09, 2010 | Lexmark C510 Laser Printer
34 short paper
The printer does not auto detect your paper size and so when your Legal size document was printed on Letter size paper, you get a 34 Short Paper message.
Feb 07, 2009 | Lexmark C510 Laser Printer
F3 Error Message
It needs a new key pad it is shorted the ge website has a list of error codes f3 is the keypad
Jan 31, 2008 | GE Advantium 120 Convection/Microwave Oven
34 incorrect media
34 Incorrect Media message appears if the printer has detected a mismatch between the type of media requested by the user and the type of media actually loaded in the paper tray.
To attempt a resolution for this issue, please do the following:
  1. Press the green GO button on the printer operator panel. Printing will resume, but the printer must go through a POR (Power On Reset) in order to clear the message.
    NOTE: The printer does not automatically reprint the page that generated the error message.
  2. Verify that the media you are using is supported by your printer in terms of size, weight, and input source.
  3. Using the printer operator panel, verify that the type of media loaded in the paper tray matches the Paper Type setting in the Paper Menu. Detailed instructions for navigating through the printer menus and changing the media type setting are provided in the C510 User's Guide.
    • If the media type setting is incorrect and cannot be changed, there may be an issue with the media type sensor. Proceed to step 5.
  4. Using the printer's operator panel, verify that the paper loaded in the paper tray is the size listed under Paper Size in the Paper Menu. Detailed instructions for navigating through the printer menus and changing the paper size setting are provided in the C510 User's Guide.
    • If the paper size changes to an incorrect setting or cannot be changed, it is likely that the paper size guides in either the 250-sheet or the 530-sheet paper tray are not set correctly. Remove the media from the tray and verify the location of the media guides.
  5. Power the printer off and then back on again.
  6. Resend the print job to the printer.
  7. If the error persists, you will need to contact Lexmark Technical Support for assistance. Please obtain the printer serial number before contacting Lexmark. If possible, call from near the printer as this will allow for the most accurate possible diagnosis.
Hope this will help you please let me know if it worked and don't forget to vote..
Cheers
Dec 18, 2007 | Lexmark C510 Laser Printer
Lexmark C510 Laser Printer Logo
978 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
